It is currently May Thu 23, 2013 5:33 pm
 Post subject: Stain Problems
PostPosted: Jan Fri 27, 2012 6:41 pm
Just finished up striping and sanding a radio down. Wiped it down with Lacquer Thinner before I applied the stain and have some areas that barely took the stain and sticks out like a sore thumb.
Any ideas what might be the problem?
Dereck
KF5LJW
 Post subject: Re: Stain Problems
PostPosted: Jan Fri 27, 2012 6:48 pm
Site Admin
A picture is worth a thousand words. There are many types of wood and finish used on radio cabinets - raw wood, veneer, plain plywood etc. The striping that you're talking about .... is that the trim that you've applied a toner to? Is the striping toner not sticking?
cheers
Looking for an old friend - Dan Lafleur, from Carp, Ontario, who attended Earl of March High School.
PostPosted: Jan Fri 27, 2012 8:53 pm
OK here is a pix, poor quality pix but the problem is on the upper right hand corner. The big white spot on rounded corner. It is a mahogany wood.
Dereck
KF5LJW
PostPosted: Jan Sun 29, 2012 12:52 am
What did the spot look like before?
Looks like glue was used there
PostPosted: Jan Sun 29, 2012 2:12 am
I wonder if reflowing the lacquer would help it or hurt it. Maybe some of the more experienced guy's would have some idea's.
101st Airborne 502nd Infantry....
PostPosted: Jan Sun 29, 2012 3:03 am
Bingo, that was it. I realized it after posting. On the section I had a hairline crack I repaired with thinned out wood glue to get it down into the crack. To clean up I just used water and a rag, and forgot to re-sand it and finish up with denatured alcohol. I realized my mistake when looking at it closer and seen the crack because the stain sat into the crack, darkened it, and caught my eye. So I sanded it again, cleaned it up with alcohol, and then reapplied to stain.
Note To Self: Clean it stupid.
All is well now.
THX
Dereck
Dereck
KF5LJW
Users browsing this forum: Tlc and 0 guests
