It is currently May Wed 22, 2013 4:35 pm
 Post subject: building a solid state stereo decoder
PostPosted: Feb Tue 14, 2012 2:52 am
To anyone who has built one of these, two questions. 1: Did you use the "dead bug" method to mount the I.C.? 2. Do you need a ground plane for it to work?
 Post subject: Re: building a solid state stereo decoder
PostPosted: Feb Tue 14, 2012 5:21 am
I built one many many years ago. I don't think dead bug method had been invented yet, but it should work fine. I used a PC board. A ground plane isn't necessary because the frequencies are no higher than about 53kHz.
PostPosted: Feb Tue 14, 2012 5:37 am
I used perfbord , no gound plane needed , use hi quality caps , silver mica or polystyrene for the tuned circuits , the beter Q you have the beter and easer it is to tune .
Mark
PostPosted: Feb Wed 15, 2012 10:47 pm
Okay, thanks. What should the range of the variable tuning resistor be? That's enough to get me started.
PostPosted: Feb Thu 16, 2012 12:44 am
Which IC are you using? Way back when I built mine, I think I used an LM1800 which has been obsolete for a long time. Looks like the later FM decoder chip TDA1591 is also nearly obsolete.
Are you referring to some specific construction article from somewhere?
PostPosted: Feb Thu 16, 2012 4:25 am
I've built several stereo decoders using the LM1800 with great results. The circuit is simple and uses no coils or inductors. Also known as ULN2244. You can buy the NTE-743 replacement for around $10 from a variety of domestic sources. Real LM1800's are sometimes listed on ebay for $5.00. Off-shore warehouses have them cheaper but you have to buy in quantity.
Here's a typical circuit shown driving buffer amps for low-Z output.
PostPosted: Feb Thu 16, 2012 6:46 pm
That circuit is similar to one I built and it does work good. For the LED I just used a red 12 volt panel mount LED assembly from Radio Shack which eliminates the need for a dropping resistor. I suspect one could use that pin to drive a transistor and then use the transistor to drive just about any bulb or indicator you want to use.
PostPosted: Feb Sat 18, 2012 5:10 pm
Here is one using an MC1310P chip. There is a typo, two pin 13 and no pin 3 http://www.circuitstoday.com/stereo-decoder-circuit
Users browsing this forum: bill hamre and 2 guests
