| Author |
Blustar1
Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic) Posted: Feb Wed 15, 2012 5:15 pm |
"Yes that's EGM, but I believe they are out of the transformers... Norm bought a large quantity and has been supping Bill so are available with the kits..."
Yes. If I'm not mistaken, Norm may have purchased a bunch of those transformers from Cheneyelectronicsstore.com a while ago. I'm not sure if that store still stocks them.
| Top |
Blustar1
Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic) Posted: Feb Wed 15, 2012 6:21 pm |
Mike3 said: "Still need the tubes .. Osc, and tuning cap... anyone have x-tra of these?"
I have a Fox 1.0Mhz can crystal and a 60-240 pF Arco compression cap that I can send you w/o charge. Just PM me with your address.
| Top |
bill hamre
Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic) Posted: Feb Wed 15, 2012 11:50 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2548 Location: aston, pa, usa
Just general info. I was able to get a kit together for Rocketeer, all but U-1. It was because 35Z5 made it easy to do as usual. I took the liberty of 25 ohm in place of 27 ohm on the two new resistors. I hope that fly's!
EDIT- New caps shipped were 50wvdc. Had them laying around thanks to Tom S who gets me parts from time to time.
_________________ "All glory is fleeting" - George Patton
KB3QNN 73
| Top |
rocketeer
Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic) Posted: Feb Thu 16, 2012 12:46 am |
| Member |
Joined: Mar Tue 30, 2010 2:24 am Posts: 5214 Location: Lehighton, PA.
| Top |
Norm Leal
Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic) Posted: Feb Thu 16, 2012 2:15 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 29137 Location: Livermore, CA
Right, that's what Tom specified. It's a low cost, fixed, 5 volt regulator. A person could use LM317 but it would take a couple resistors to adjust to 5 volts.
_________________ Norm
| Top |
35Z5
Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic) Posted: Feb Thu 16, 2012 2:22 am |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 8700 Location: Chesapeake VA
I sourced my LM7805 from a junk Zenith TV PCB from the '90s... Have to watch out though, LM7809 & LM7812 are fairly common in those application...
| Top |
Mike3
Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic) Posted: Feb Thu 16, 2012 3:29 pm |
Joined: Apr Fri 24, 2009 2:14 am Posts: 508 Location: Charleston SC .. USA
Thanks Blustar1... PM coming I probably should know .. but who is Tom Bavis.. I can't seem to find his profile to PM for tubes...
Thanks Mike
| Top |
jth877
Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic) Posted: Feb Thu 16, 2012 4:03 pm |
Joined: Sep Fri 30, 2011 3:55 am Posts: 174 Location: Saratoga, NY
I have a couple of questions regarding the build. I'm just about done with the assembly and was thinking about using a 3 prong power cord and grounding the transmitter through it. Is that OK, or will I get noise? If I can't ground to the receptacle ground, can I ground it to the aluminum base in the project box? I assume so.
The second question is about the antenna length. the L2 coil in my kit is 1000uh as the 680uh was unavailable, what length of antenna would be a good place to start from?
| Top |
Blustar1
Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic) Posted: Feb Thu 16, 2012 6:03 pm |
jth877 wrote: "I'm just about done with the assemble and was thinking about using a 3 prong power cord and grounding the transmitter through it. Is that OK, or will I get noise?"
You should always use a two conductor cord with ground with these transmitters, and tie the aluminum base to ground as well.
| Top |
bill hamre
Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic) Posted: Feb Thu 16, 2012 9:22 pm |
Post Office told me that the rocketeer kit should arrive on Saturday.
Larry, let me know if you need anything. Some parts in the regular kit are back ordered and that affected a hand full of kit builders including rocketeer.
KB3QNN 73
| Top |
bill hamre
Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic) Posted: Feb Thu 16, 2012 9:30 pm |
I may need to send him more transformers?
_________________ Norm ------------------------------------------------------------------- I was feeling around the bottom of the last box in the dark in my shed and got the rocketeer transformer but I need to check in daylight as I think I'm running out again. I'll let you know asap.
KB3QNN 73
| Top |
Norm Leal
Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic) Posted: Feb Thu 16, 2012 10:14 pm |
Bill
I'll be away two weeks. Will need to send transformers beginning of March. I still have plenty. For me best to send 12 by priority mail. Regular mail would cost $50 to your location. I don't mind $10.95 but $50 is too high.
| Top |
bill hamre
Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic) Posted: Feb Fri 17, 2012 5:12 pm |
That's good Norm.
KB3QNN 73
| Top |
K4YDO
Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic) Posted: Feb Sun 19, 2012 6:07 am |
Joined: Nov Mon 28, 2011 2:55 am Posts: 132 Location: Florence, SC 29506
Reported completion earlier. Just learning to attach photos. Works great. Ed Attachment:
| Attachments: |
| Top |
Blustar1
Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic) Posted: Feb Sun 19, 2012 6:22 am |
| Top |
jth877
Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic) Posted: Feb Sun 19, 2012 6:24 pm |
Is there a good source for an equivalent transformer? I fried mine on the first power up.
| Top |
Blustar1
Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic) Posted: Feb Wed 22, 2012 1:26 am |
Wow! The audio from that xmitter always sounds best on my '29 Atwater Kent Model 55C radio console (which explains why I use that receiver the most). Special thanks to Tom (35Z5), Norm Leal, Bill Hamre, Dave Doughty and others whose contributions to this forum are invaluable.
| Top |
rocketeer
Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic) Posted: Feb Wed 22, 2012 1:54 am |
| Member |
bill hamre wrote: Post Office told me that the rocketeer kit should arrive on Saturday.
Larry, let me know if you need anything. Some parts in the regular kit are back ordered and that affected a hand full of kit builders including rocketeer. After digging thru all my stuff this what I still need. Maybe someone could point me in the right direction? X1 - Crystal Osc (1000Kc) - FOUND D1, D2, D3 - 1N4007 - THEY WERE THERE IN THE KIT ALL ALONG L1 - 1mh coil - FOUND L2 - 1mh (1000Kc) -FOUND L3 - 470uh - FOUND Two 7-pin tube sockets - FOUND 12CS6 tube - FOUND Thanks, Larry
_________________ kb3wbb
My radio files free download page: http://www.enter.net/~rocketeer/radio/radio2.html
| Top |
Blustar1
Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic) Posted: Feb Wed 22, 2012 2:55 am |
Hi Larry. I have one Fox 1.0 Mhz can crystal & two 7-pin tube sockets that I can send you w/o charge. Just PM me with your shipping address.
| Top |
rocketeer
Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic) Posted: Feb Wed 22, 2012 3:06 am |
| Member |
| Top |
Users browsing this forum: psbot [Picsearch] and 1 guest |
