It is currently May Sat 25, 2013 12:20 am
Post New Topic Post Reply  [ 440 posts ]  Go to page Previous  1 ... 12, 13, 14, 15, 16, 17, 18 ... 22  Next
 Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic)
PostPosted: Feb Wed 15, 2012 5:15 pm
"Yes that's EGM, but I believe they are out of the transformers... Norm bought a large quantity and has been supping Bill so are available with the kits..."
Yes. If I'm not mistaken, Norm may have purchased a bunch of those transformers from Cheneyelectronicsstore.com a while ago. I'm not sure if that store still stocks them.
PostPosted: Feb Wed 15, 2012 6:21 pm
Mike3 said: "Still need the tubes .. Osc, and tuning cap... anyone have x-tra of these?"
I have a Fox 1.0Mhz can crystal and a 60-240 pF Arco compression cap that I can send you w/o charge. Just PM me with your address.
PostPosted: Feb Wed 15, 2012 11:50 pm
Just general info. I was able to get a kit together for Rocketeer, all but U-1. It was because 35Z5 made it easy to do as usual. I took the liberty of 25 ohm in place of 27 ohm on the two new resistors. I hope that fly's!
EDIT- New caps shipped were 50wvdc. Had them laying around thanks to Tom S who gets me parts from time to time.
KB3QNN 73
PostPosted: Feb Thu 16, 2012 12:46 am
Thanks Bill. U-1 is the LM7805 voltage regulator, right? Is this what I need?
http://www.radioshack.com/product/index.jsp?productId=2062599
kb3wbb
My radio files free download page:
http://www.enter.net/~rocketeer/radio/radio2.html
PostPosted: Feb Thu 16, 2012 2:15 am
Right, that's what Tom specified. It's a low cost, fixed, 5 volt regulator. A person could use LM317 but it would take a couple resistors to adjust to 5 volts.
PostPosted: Feb Thu 16, 2012 2:22 am
I sourced my LM7805 from a junk Zenith TV PCB from the '90s... Have to watch out though, LM7809 & LM7812 are fairly common in those application...
PostPosted: Feb Thu 16, 2012 3:29 pm
Thanks Blustar1... PM coming
I probably should know .. but who is Tom Bavis.. I can't seem to find his profile to PM for tubes...
PostPosted: Feb Thu 16, 2012 4:03 pm
I have a couple of questions regarding the build. I'm just about done with the assembly and was thinking about using a 3 prong power cord and grounding the transmitter through it. Is that OK, or will I get noise? If I can't ground to the receptacle ground, can I ground it to the aluminum base in the project box? I assume so.
The second question is about the antenna length. the L2 coil in my kit is 1000uh as the 680uh was unavailable, what length of antenna would be a good place to start from?
PostPosted: Feb Thu 16, 2012 6:03 pm
jth877 wrote: "I'm just about done with the assemble and was thinking about using a 3 prong power cord and grounding the transmitter through it. Is that OK, or will I get noise?"
You should always use a two conductor cord with ground with these transmitters, and tie the aluminum base to ground as well.
PostPosted: Feb Thu 16, 2012 9:22 pm
Post Office told me that the rocketeer kit should arrive on Saturday.
Larry, let me know if you need anything. Some parts in the regular kit are back ordered and that affected a hand full of kit builders including rocketeer.
KB3QNN 73
PostPosted: Feb Thu 16, 2012 9:30 pm
I may need to send him more transformers?
I was feeling around the bottom of the last box in the dark in my shed and got the rocketeer transformer but I need to check in daylight as I think I'm running out again. I'll let you know asap.
KB3QNN 73
PostPosted: Feb Thu 16, 2012 10:14 pm
Bill
I'll be away two weeks. Will need to send transformers beginning of March. I still have plenty. For me best to send 12 by priority mail. Regular mail would cost $50 to your location. I don't mind $10.95 but $50 is too high.
PostPosted: Feb Fri 17, 2012 5:12 pm
That's good Norm.
KB3QNN 73
PostPosted: Feb Sun 19, 2012 6:07 am
Reported completion earlier. Just learning to attach photos. Works great. Ed
PostPosted: Feb Sun 19, 2012 6:22 am
Looks good too Ed.
PostPosted: Feb Sun 19, 2012 6:24 pm
Is there a good source for an equivalent transformer? I fried mine on the first power up.
PostPosted: Feb Wed 22, 2012 1:26 am
Wow! The audio from that xmitter always sounds best on my '29 Atwater Kent Model 55C radio console (which explains why I use that receiver the most). Special thanks to Tom (35Z5), Norm Leal, Bill Hamre, Dave Doughty and others whose contributions to this forum are invaluable.
PostPosted: Feb Wed 22, 2012 1:54 am
After digging thru all my stuff this what I still need. Maybe someone could point me in the right direction?
X1 - Crystal Osc (1000Kc) - FOUND
D1, D2, D3 - 1N4007 - THEY WERE THERE IN THE KIT ALL ALONG :oops:
L1 - 1mh coil - FOUND
L2 - 1mh (1000Kc) -FOUND
L3 - 470uh - FOUND
Two 7-pin tube sockets - FOUND
12CS6 tube - FOUND
kb3wbb
PostPosted: Feb Wed 22, 2012 2:55 am
Hi Larry. I have one Fox 1.0 Mhz can crystal & two 7-pin tube sockets that I can send you w/o charge. Just PM me with your shipping address.
PostPosted: Feb Wed 22, 2012 3:06 am
Thank you, PM sent.
kb3wbb
Users browsing this forum: Google [Bot] and 2 guests
