Page 1 of 1
[ 7 posts ] |
| Author |
radiojohn
Post subject: Schematic for a 1950 Moterola 646 Series b Radio Posted: Feb Wed 22, 2012 7:45 am |
Joined: Mar Sat 26, 2011 4:28 am Posts: 188 Location: Lompoc, CA
Does anyone know where I can get a schematic for this radio!! Just picked it up and would like to start working on it!!Actually its an Emerson 646 Series B I got the maker of the radio mixed up!!
Thanks in advance
| Top |
cwtravis
Post subject: Re: Schematic for a 1950 Moterola 646 Series b Radio Posted: Feb Wed 22, 2012 2:28 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2565 Location: Northern Panhandle, WV
| Top |
radiojohn
Post subject: Re: Schematic for a 1950 Moterola 646 Series b Radio Posted: Feb Wed 22, 2012 11:30 pm |
| Top |
radiojohn
Post subject: Wires on 1950 Emerson 646 Series b Radio Posted: Feb Fri 24, 2012 12:15 am |
Hi, I have another Question on this radio!! I have a shematic but its not very good!! The question is where do these two wires that are circled get connected? Can't really tell from the Schematic its to small and hard to read!! Any help would be great!!Image is clickable!! Thanks in advance, John
| Top |
glasdave
Post subject: Re: Schematic for a 1950 Moterola 646 Series b Radio Posted: Feb Fri 24, 2012 9:51 am |
| Member |
Joined: Feb Tue 24, 2009 8:20 am Posts: 7727 Location: Aurora Colorado
You came make the schematic larger by using your ctrl key and the plus sign. And where do the wires end up?
_________________ I move the world just one step on...
| Top |
radiojohn
Post subject: Re: Schematic for a 1950 Moterola 646 Series b Radio Posted: Feb Fri 24, 2012 4:43 pm |
Yep I tried that still can't read it to clearly!! The blue wire is connected to V-4 3v4 with orange wire you see in the picture. the orange wire goes to the transformer and the tan wire is connected to the tube socket right next to the IF cam,if that helps!Tan wire is connected ito the tube socket V-3 IU5!! right under the green wire in the back with a knot in it!!need to know where the other ends go!!Both the tan and the blue wire look like they are connected to pin 7!!
Thanks again hope this helps
| Top |
fifties
Post subject: Re: Schematic for a 1950 Moterola 646 Series b Radio Posted: Feb Fri 24, 2012 11:59 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 8701 Location: SoCal, 91387
I have a couple of these. There should be six wires exiting from the back of the chassis; a green, from it's own hole, going to the antenna loop, and from the larger hole, beige or yellow going to the other side of the loop, red and white to the B battery terminals, and yellow and black to the A terminals. Exiting above the board and connecting to the output transformer are a blue, and red.
_________________ *******\\\\\\\\\******He Who Dies With The Most Radios Wins******/////////*******
| Top |
Users browsing this forum: fffagal and 11 guests |
