It is currently May Mon 20, 2013 10:26 pm
 Post subject: Suggestions for painting the white grill on this Arvin...
PostPosted: Mar Fri 02, 2012 5:16 am
Any suggestions as to a good paint/technique to use... or should I just leave it as is?
 Post subject: Re: Suggestions for painting the white grill on this Arvin..
PostPosted: Mar Fri 02, 2012 11:37 pm
I wouldn't repaint it,it looks pretty good.
I had a similar grill and cleaned the crud off with a pencil eraser.
Phil
I've been doing so much for so long with so little I can now do anything with nothing!
PostPosted: Mar Sun 04, 2012 7:45 am
Leave it as it is. I see the worn places, but it really doesn't look bad.
If it was a lot worse, the best way would be to mask the grille off. Set a couple of hours aside for that task. Time consuming to get it 100% masked right. Even then you'd have to carefully spray on the paint. An airbrush would be ideal. A spray can might load it up too much at once.
I don't think it would look all that great either with a spray can. Painting would be a last resort thing to do.
JMO- YMMV
Gary Rabbitt
PostPosted: Mar Sun 04, 2012 4:50 pm
JMO- YMMV
Yeah, maybe it's not as worse that what it appears to be. I think I was looking for suggestions had it been really worse. How would I best repair those worn spots had they been deeper.
PostPosted: Mar Mon 05, 2012 2:10 am
Is it wear or dirt? Have to washed/cleaned the cabinet yet?
PostPosted: Mar Mon 05, 2012 2:27 am
I already washed the cabinet. Those dark areas are where the paint has worn a bit thin.
PostPosted: Mar Mon 05, 2012 2:33 am
Okay, I was looking at the area around the dimple for the knob, and I saw some dust there, I think.
PostPosted: Mar Mon 05, 2012 3:27 am
A few more. That dust was eventually cleaned (missed the first scrubbing).
PostPosted: Mar Mon 05, 2012 12:03 pm
It 's fine,leave it like that.
I based my observations on the way I do things....I get ahead of my self, and miss things. :lol:
PostPosted: Mar Mon 05, 2012 1:59 pm
But what if he wants to sell it on Ebay, as a shiney radio that brings-in 5x the actual value?! Paint that thing up, all of it! You'll make a bundle!
Yes, I'm Kidding. :wink:
Users browsing this forum: Prutser and 0 guests
