| Author |
R. Jepsen
Post subject: Crack House Radio Posted: Mar Wed 07, 2012 10:39 pm |
| Member |
Joined: Feb Mon 20, 2012 10:03 pm Posts: 613 Location: Ohio
| Top |
moe cory
Post subject: Re: Crack House Radio Posted: Mar Wed 07, 2012 11:54 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 577 Location: New York, NY
This was my FIRST radio given to me in 1946 and the FIRST radio I every repaired (bad electrolytics). Its performance was very good and I used to DX a lot. Tone was OK (although the two step tone control was quite limiting --maybe you can put in a continuous tone control?). I also liked the very, very BRIGHT dial light which was a 7.5V 51 not the 6V 47s.
The chassis was very roomy underneath with detachable side panels for easy access (compare this dream to the same year 66X series with narrow, incedibly deep chassis --ugh).
Why would you want to replace the fiber sockets? Don't ask for trouble. Just deoxidize the pins, put in a set of new tube and enjoy.
You can glue (use white or carpenter's to preserve the loop from chemical reaction with stronger glues) a piece of stiff cardboard to the loop --don't get so fancy and look around for something "special." You can also use double-sided tape, but once it's down, it's down.
BTW: I recall this is the only AA6/AA5 I've ever come across that had bypass caps rated at 800 V!
Best, Maurice
| Top |
fifties
Post subject: Re: Crack House Radio Posted: Mar Thu 08, 2012 12:31 am |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 8775 Location: SoCal, 91387
R. Jepsen wrote: Unfortunately, other photos can't be posted due to the severe 256K size limit. Hay! Modern cameras are at least 5 mp.
It's an antique radio board...Takes antique camera equipment to mesh...
_________________ *******\\\\\\\\\******He Who Dies With The Most Radios Wins******/////////*******
| Top |
tubeAMP
Post subject: Re: Crack House Radio Posted: Mar Thu 08, 2012 2:00 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2756 Location: Gainesville, Florida
for the cabinet glue it together with your favorite cement sand it off use some automotive glazing sand again prime and paint it. I have heard of wiping the chassis down with naval jelly then wipe with a damp cloth. paint the metal tubes polish the glass tubes polish the metal IF cans
_________________ CAUTION: Im no expert
| Top |
R. Jepsen
Post subject: Re: Crack House Radio Posted: Mar Thu 08, 2012 5:22 am |
| Member |
Re: This was my FIRST radio given to me in 1946 and the FIRST radio I every repaired (bad electrolytics). Its performance was very good and I used to DX a lot. Tone was OK (although the two step tone control was quite limiting --maybe you can put in a continuous tone control?). I also liked the very, very BRIGHT dial light which was a 7.5V 51 not the 6V 47s. ======================================= Wow! All the way back to 1946, an amazing period for radio. I grew up in poverty so rarely had anything given to me. My first radio was a crystal set, one of those Philmore jobs where a sliding arm went across a coil wound on a block of wood. Then you had to fiddle with that cat's whisker in a madding attempt to hit the right spot on the rock. If you were lucky, you'd faintly hear three or four stations all mixed together. As a paper boy, I'd spot old fans and TV's people would put out for the trash pickup. I'd pull the chassis and tie it to the back of the bike and drag home. Having nothing, I was forced to steal books and magazines to learn electronics and cut parts out of those trashed TV's. But what about the money from the paper route? Forget it. The parents sent me out to work when I was 10 and took all the money to help support their beer & cigarettes. But by doing things the hard way and scrounging for parts & supplies, it was a good hands-on education. http://www.daveperkins.com/Philmore%20bakelite.JPGOn the two-step tone control, they gave the false impression of a bass boost by switching in a capacitor to shunt some of the high frequencies. Then later when hi-fi came along, real bass and treble control appeared by nature of variable gain amplifiers in a particular band of frequencies. That along with cross-over networks in big-box speaker systems. Re: Why would you want to replace the fiber sockets? Don't ask for trouble. Just deoxidize the pins, put in a set of new tube and enjoy. ==================================== I typically strip a chassis down and go over it with steel wool since the majority of the time, the point-to-point wiring is cracked with insulation falling off the wires. After removing the pit marks, rust, and discoloration, I like to spray them with the new Rustoleum silver metallic. Not because I'm going to stare at the chassis like some kind of fish tank, but to stop the minute rust deposits down in the metal pits and seal out the moisture. I eventually would like to abandon paint try some nickel electroplating that would be better looking and a lot more durable than paint. http://www.youtube.com/watch?v=Q8Xo43sf ... re=related===================================== TubeAMP - I like your Navel Jelly idea. I'll have to try using that product. When I do an initial chassis clean-up, one thing I've found that works great is dollar store carpet cleaner --the liquid pump spray, not the foam. You just spray it on metal or plastic and wait 20 minutes, wiping off with a paper towel. So far, it hasn't had any corrosive effect on these materials, leaves no deposits, and really cuts grease, grime, and yellow cigarette deposits.
| Top |
BikenSwim
Post subject: Re: Crack House Radio Posted: Mar Thu 08, 2012 5:35 pm |
Joined: Oct Wed 14, 2009 6:36 am Posts: 3039 Location: New York USA
Retro-tronics.com has radio backs for similar models, the cabinet is probably the same size. I bought various backs, nicely made. Don
| Top |
R. Jepsen
Post subject: Re: Crack House Radio Posted: Mar Fri 09, 2012 12:17 am |
| Member |
Nice web site except for the prices. I don't mind paying for something but I won't be made a sucker. Looks like I'll just have to hand manufacture my own and select a more durable material.
| Top |
BikenSwim
Post subject: Re: Crack House Radio Posted: Mar Fri 09, 2012 1:16 am |
| Top |
JerryHawthorne
Post subject: Re: Crack House Radio Posted: Mar Fri 09, 2012 4:43 am |
Joined: Feb Sun 24, 2008 4:21 am Posts: 2046 Location: Sedona, AZ
Just made my own back for a Philco, labor, many hours, cost per labor, nothing. An almost empty can of spray paint, almost nothing. Just depends on how much time you have and the proper tools. Scroll saw, dremel grinder, and sand paper. Fun, couldn't put a price on it. Jerry
_________________ A friend in need is a pest. Bill Slee ca 1972
| Top |
R. Jepsen
Post subject: Re: Crack House Radio Posted: Mar Fri 09, 2012 8:28 pm |
| Member |
| Top |
R. Jepsen
Post subject: Re: Crack House Radio Posted: Mar Fri 09, 2012 8:38 pm |
| Member |
JerryHawthorne wrote: Just made my own back for a Philco, labor, many hours, cost per labor, nothing. An almost empty can of spray paint, almost nothing. Just depends on how much time you have and the proper tools. Scroll saw, dremel grinder, and sand paper. Fun, couldn't put a price on it. Jerry It's too bad some of us can't team up and combine our skills, knowledge, and access to parts and tools. That would be awesome! Good job on your Philco back cover. Do you have any photos available? I need a way to manufacture such items myself.
| Top |
R. Jepsen
Post subject: Re: Crack House Radio Posted: Mar Fri 09, 2012 10:21 pm |
| Member |
BikenSwim wrote: Radiomuseum.org has pictures of the front and back so you know what the back and everything should look like, and the ads for it. http://www.radiomuseum.org/act_main.cfmI also just use Faststone Image Viewer (free) to quickly re-size pictures to 640 x 480 and 96 DPI resolution for any web sites. http://www.faststone.org/FSViewerDetail.htmDon Faststone is one great program with a lot of nice features. This will certainly make processing images a lot easier. I like being able to scroll through pix using the mouse wheel and then a left-click expands into a larger view. I've been using irFanView which is a bit cumbersome. Thanks!
| Top |
JerryHawthorne
Post subject: Re: Crack House Radio Posted: Mar Sun 11, 2012 12:10 am |
R. Jepsen, I sent you a second PM. Jerry
| Top |
JerryHawthorne
Post subject: Re: Crack House Radio Posted: Mar Sun 11, 2012 12:38 am |
A comment on tube sockets, I agree with another poster, leave them in! One caution, the rectifier socket. Don't spray anything in it for cleaning. With the HV on that, it could well release the latent smoke out of your radio. I just smoked my second and didn't do anything to it. With the sandwich construction, stuff can get between the parts. Still waiting for a replacement for a loctal one. Leave them in and just be careful around the rectifier. Jerry
| Top |
R. Jepsen
Post subject: Re: Crack House Radio Posted: Mar Sun 11, 2012 3:05 am |
| Member |
Too late my friend. The chassis has already been stripped down and tube sockets knocked out with a hammer. I've gone over it with steel wool and going to try my hand at electroplating with nickle. http://www.youtube.com/watch?v=Q8Xo43sfLgY
| Top |
amptramp
Post subject: Re: Crack House Radio Posted: Mar Mon 12, 2012 9:04 pm |
Joined: Jun Fri 26, 2009 2:27 am Posts: 167 Location: Mississauga
If you do the complete chassis in nickle, will you be able to solder anything to it? There is often an parallel RC network going from negative grounding point to chassis ground. I would mask it (and it may be necessary to mask it as the solder may contaminate the nickle plating solution). Have you considerd tin plating?
| Top |
R. Jepsen
Post subject: Re: Crack House Radio Posted: Mar Mon 12, 2012 9:35 pm |
| Member |
All good questions and things to consider. I guess I'll need to experiment and find out the answers. I will examine the chassis and determine any points that need solder and if a solder lug can be substituted. Thanks for the thoughtful tips.
| Top |
gary rabbitt
Post subject: Re: Crack House Radio Posted: Mar Tue 13, 2012 7:05 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 13103 Location: Tennessee,USA
Poof
_________________ Gary Rabbitt
| Top |
R. Jepsen
Post subject: Re: Crack House Radio Posted: Mar Tue 13, 2012 10:07 pm |
| Member |
That's an excellent suggestion. Unfortunately, I have a printer I've kept running since the Windows 95 days and it has no scanner.
| Top |
R. Jepsen
Post subject: Re: Crack House Radio Posted: Mar Thu 22, 2012 9:26 pm |
| Member |
Work on the Crack House Radio is progressing. I've finally finished mapping all the components and wiring so have now started removing and cleaning all parts that will be reused.
Living up to it's name, practically all wiring is cracked with insulation falling away or has hardened and become inflexible. Many wires have lost their color code over the years with blue looking a lot like green.
Below is the RCA 56X2 refurbished 1st IF transformer with new leads and the RF coil with all terminals cleared of old wiring and de-soldered. Next, the 2nd IF will have to be taken apart for similar treatment.
| Attachments: |
| Top |
