It is currently May Sun 19, 2013 9:28 pm
Post New Topic Post Reply  [ 186 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10  Next
 Post subject: Re: Got Collections? New Finds? Let's See 'em.....
PostPosted: Sep Fri 23, 2011 4:31 am
Picked up a Sears 4 band radio cassette for $3
http://www.flickr.com/photos/62410145@N08/6174248420/
PostPosted: Nov Sat 26, 2011 10:12 pm
Found a 2200 that cleaned up very nice, not a mark on it and it sounds just beautiful. I think it's a keeper.
Frank
PostPosted: Nov Sun 27, 2011 1:38 am
A few multi-band portables
PostPosted: Nov Sun 27, 2011 1:40 am
A few lower cost communications type solid state receivers
PostPosted: Nov Sun 27, 2011 1:44 am
And some more complex solid state radios
PostPosted: Dec Sat 24, 2011 6:10 am
I dont have anything that would come close to the
collections on the thread. But I do have this 70s Sanyo
close by. I have some older ones buried in storage.
I'll see about digging them up.
PostPosted: Jan Mon 09, 2012 4:19 pm
Couple different Sony Watchman's and a few radios
PostPosted: Jan Sun 22, 2012 7:21 am
This is a good looking radio I've got today.
PostPosted: Jan Sun 22, 2012 10:05 pm
Is that solid state? It looks more like a 4 tube set.
PostPosted: Jan Mon 23, 2012 12:13 am
I was going to ask the same thing. There was a period during the end of the tube era when Japan built many models of ultra-small, 4-tube battery sets to compete with the American transistor sets. It would be interesting to see the back with the cover off of this set.
PostPosted: Jan Mon 23, 2012 4:05 am
Jinkei, Nice pictures, I also like your radio. The patina is cool looking.
Seems like if it was a tube set, it would have some ventalation in the back of the case.
PostPosted: Jan Mon 23, 2012 4:55 am
Not really and in fact very few do. That goes for the medium and larger size portable tube sets as well.
PostPosted: Jan Mon 23, 2012 12:20 pm
Hi, there!
Thanks for the comments. I also thought it must be a four-tube radio.
Actually,,, just take a look at inside! Who the hell spoiled the radio :evil:
PostPosted: Jan Mon 23, 2012 1:23 pm
Jinkei - Do you think Hilton retro-fitted a transistor chassis into that cabinet or is it homebrew?
PostPosted: Jan Mon 23, 2012 3:18 pm
Hi Dave,
This is a homebrew.
At first, I wondered if it's a manufacture-made. But when I tried to tune the station, I knew it's a homebrew.
The dial numbers graved on the front increases counter-clockwise, while rotate the dial counter-clockwise,
tuning frequency decreases. Oh my God! :shock:
Jinkei
PostPosted: Jan Mon 23, 2012 10:11 pm
It's been bastardized;
the cutout for a speaker is a dead giveaway, and no manufacturer would have made such a Mickey-Mouse battery arrangement.
Surprising that they didn't just incorporate a nine volt rectangular battery, with a snap connector.
Jinkei Ohta, if you can locate a tuner from a parts Transistor set that will tune opposite of what you have, AND has the correct shaft (that's the major trick), you could at least get it to tune correctly. That, or locate a four tube circuit, and use that case for it.
PostPosted: Feb Sun 19, 2012 5:45 pm
Found a couple of Channel Masters, both Sanyo I believe? I like the looks
The bigger one came with the box and still sealed earphone, but has a minor issue with the volume knob, but both sound and look great and have their leather cases.
Frank
PostPosted: Mar Sun 04, 2012 5:16 am
I picked up this little fella today. It's a Motorola Weatherama, about 6" wide by 5" tall by 2" deep.
When I got it home and put 4 AA batteries in it actually worked!
The Beacon Band doesn't do much but the Standard Band picks up a few AM stations rather clearly.
The base can be rotated to the top and it has a broken slide switch on the lower right corner(slide still works).
PostPosted: Mar Sun 04, 2012 6:11 am
Upon closer inspection the antenna appears to be inside the rotating base, and found a date stamp on the circuit board of 1957.
Can take 4 mercury or 4 penlight(AA) batteries. Also has a headphone jack on the back.
Heres another photo angle.
PostPosted: Mar Thu 08, 2012 2:13 am
Inactive
Found this Regency TR-1 in a box of misc. transister radios, had to look twice. Cell phone photo.
Post New Topic Post Reply  [ 186 posts ]  Moderator: Dave Doughty Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10  Next
