It is currently May Wed 22, 2013 5:53 am
 Post subject: Philco Electrolytic Restuff
PostPosted: Mar Thu 08, 2012 3:11 pm
To my surprise when I cut open this cap what appeared water poured out of can.
Never have run across such a configuration :shock:
xeric
 Post subject: Re: Philco Electrolytic Restuff
PostPosted: Mar Thu 08, 2012 3:46 pm
Yes, wet electrolytic capacitors. They were the original power supply type of caps. See: http://www.faradnet.com/deeley/chapt_03.htm
Curtis Eickerman
PostPosted: Mar Thu 08, 2012 3:55 pm
Thanks Curtis, interesting reading.
I had the idea wet meant "soaked" not immersed :!:
xeric
PostPosted: Mar Thu 08, 2012 4:01 pm
I have not opened one either. Then there are also oil filled capacitors, but they are generally lower value but much higher voltage ratings for very high voltage supplies (think kilovolts). They are typically square cans. I have not opened one of those either.
Curtis Eickerman
PostPosted: Mar Thu 08, 2012 5:05 pm
Usually the rubber seal beneath the vent cap deteriorates over the decades, and those
caps are dried out by the time we get them. Or, a poor service inverts the chassis, and
finds them piddling all over the bench! It was a borax solution, which is relatively harmless.
Pete
A long journey always begins with the words, "I think I know a shortcut."
Post New Topic Post Reply  [ 5 posts ]  Moderator: Peter Bertini
Users browsing this forum: fvan and 1 guest
