| Author |
Ed Kraushar
Post subject: Re: Cheap mp3 player for feeding AM transmitter Posted: Jan Fri 27, 2012 5:19 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2025 Location: Campbellford, Ontario, Canada.
BobWeaver wrote: The LM3900 is also sold under the LM2900 number which may be more common nowadays. Digi-key still lists them under both numbers I think. I bought a bunch just a few months ago. However, any regular op amp will work too. It just requires that the non-inverting input would be biased with a voltage divider to half the supply voltage, instead of the current bias that the LM3900 uses. Thanks, I found some LM2900's. My initial Google quick search for LM3900's turned up comments on their unavailbility. Ed.
| Top |
Flipperhome
Post subject: Re: Cheap mp3 player for feeding AM transmitter Posted: Jan Fri 27, 2012 6:25 pm |
| Member |
Joined: Nov Sat 26, 2011 4:09 am Posts: 1054 Location: Texas. USA
Pbpix wrote: The OP275 is a nice opamp but isn't characterized for operation under +-4.5V (9V total).
| Top |
BobWeaver
Post subject: Re: Cheap mp3 player for feeding AM transmitter Posted: Jan Fri 27, 2012 7:28 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1411 Location: Saskatoon
Good point about the 5 volt single supply. When I tossed this thing together, I initially tested it from a separate supply and wasn't terribly concerned about the supply voltage. It was running at about 10 volts. So, I went back and confirmed that it does operate properly from a single 5 volt supply. Since the LM3900 output swings between 0.1 volt and Vcc-1 volts, that gives a 3.9 Vpp swing from a 5 volt supply, in which case it's a good idea to bias the output to about 2 volts rather than 2.5 volts. So, the 680k resistors should be replaced with 1 Meg. resistors when powered from 5 volts. (It was working fine with the 680k bias resistors at 5 volts, but 1 Meg. resistors should guarantee a little more output swing before clipping.)
| Top |
Flipperhome
Post subject: Re: Cheap mp3 player for feeding AM transmitter Posted: Jan Fri 27, 2012 8:22 pm |
| Member |
BobWeaver wrote: Good point about the 5 volt single supply. I was doing a bit of guessing you intended a single 5V supply but one could also do a double supply, like you did for testing. That isn't necessary to simply shape the same output level, and a single 5V supply is simpler, but if that MP3 output is low for the transmitter you could use the opamp to gain it up as well, in which case you'd need a higher voltage to accommodate the larger swing.
| Top |
Mike Toon
Post subject: Re: Cheap mp3 player for feeding AM transmitter Posted: Mar Thu 08, 2012 10:10 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 5938 Location: Burbank CA
Bob, I ordered one when you first posted and received it today.  Where is the spec sheet for this? 3.7 Volts?
| Top |
Pbpix
Post subject: Re: Cheap mp3 player for feeding AM transmitter Posted: Mar Thu 08, 2012 10:49 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 9334 Location: Haledon, NJ, usa
I ordered one around the same time too Jan 28th ... but have not heard a word about it since.
Was wondering what's going on.
_________________ " To be a man, Be a non-conformist, Nothing is as sacred as integrity of your own mind." Emerson
| Top |
BobWeaver
Post subject: Re: Cheap mp3 player for feeding AM transmitter Posted: Mar Thu 08, 2012 11:45 pm |
Looks as if it may have been temporarily out of stock. Hopefully, they're shipping again.
Mike, It will work on any voltage between 3.7 and 5 volts.
I never found a datasheet for this exact unit, but I did find a schematic for another one that uses the same chips and was close enough that I was able to figure out the important features. I'll dig it out and post the info shortly.
| Top |
Ed Kraushar
Post subject: Re: Cheap mp3 player for feeding AM transmitter Posted: Mar Fri 09, 2012 2:08 am |
| Member |
I ordered two Jan 17 and had them before the end of January. I run them on 5 volts and they work very well through the little circuit that Bob designed. Even works well through the phono input of my Victor RE-45.
Ed
| Top |
BobWeaver
Post subject: Re: Cheap mp3 player for feeding AM transmitter Posted: Mar Fri 09, 2012 3:57 am |
| Top |
Mike Toon
Post subject: Re: Cheap mp3 player for feeding AM transmitter Posted: Mar Fri 09, 2012 4:11 am |
| Member |
Is this real?
| Top |
BobWeaver
Post subject: Re: Cheap mp3 player for feeding AM transmitter Posted: Mar Fri 09, 2012 4:18 am |
Yes and no. The 12 volt power option requires that you add a voltage regulator IC to the board. It would mount on the big square foil pad between the electrolytic, and the clock crystal. So, as it is, you can't use it on 12 volts.
| Top |
Pbpix
Post subject: Re: Cheap mp3 player for feeding AM transmitter Posted: Mar Fri 09, 2012 6:19 am |
| Member |
BobWeaver wrote: Yes and no. The 12 volt power option requires that you add a voltage regulator IC to the board. It would mount on the big square foil pad between the electrolytic, and the clock crystal. So, as it is, you can't use it on 12 volts. So I guess that's why you loose the time setting when it's shut off... right. Or am I over-stating the obvious.. if so sorry Seems to me that the RED BATT plug was meant to be connected primarily to a battery back-up only for that reason. The 12V in ( with a regulator added to the board LM7805?) would have been the normal power in.. and so ...if a BATT was connected to the RED plug ...the time wouldn't be lost.. right? If so... are the other regulator parts already on board now.. so you only add a Lm7805? or LM317? .. or what?
| Top |
BobWeaver
Post subject: Re: Cheap mp3 player for feeding AM transmitter Posted: Mar Fri 09, 2012 9:08 am |
Originally, I thought that the red battery plug was for the clock too. But there's a power switch on the front of the unit, and when it's switched off, it disconnects the red connector and it kills the clock. So, if there is a means to keep the clock going, it would have to be connected somewhere else. I'm beginning to suspect that the clock function just happens to be part of the main controller chip, but hasn't been properly implemented on this particular circuit board. Though, it may be possible to find some other point to connect a backup battery.
| Top |
Mike Toon
Post subject: Re: Cheap mp3 player for feeding AM transmitter Posted: Mar Fri 09, 2012 8:52 pm |
| Member |
I'm impressed. This player has enough power to drive two large speakers.
How tough is it? I'm using this with a 6V supply. Because the 7805 needs 2V difference, I'll use three diodes to drop 2V. (Four new alkaline batteries could supply almost 7V.) As the batteries discharge, say to 5V, will the player quit at 3.7V?
| Top |
BobWeaver
Post subject: Re: Cheap mp3 player for feeding AM transmitter Posted: Mar Sat 10, 2012 2:38 am |
I think 6 volts is pushing it a bit. Most of these logic circuits don't like anything any higher than 5.5 volts max.
When I first got mine going, I was powering it from 3 AAA batteries, so it was about 4.5 volts. When the batteries started to get weak, it was cutting out around 3.5 volts. Now, I'm using a 5 volt wallwart that's designed for running USB powered devices.
| Top |
Mike Toon
Post subject: Re: Cheap mp3 player for feeding AM transmitter Posted: Mar Sat 10, 2012 3:49 am |
| Member |
BobWeaver wrote: Now, I'm using a 5 volt wallwart that's designed for running USB powered devices. That's what I used and was happy. Install in in a portable radio and the voltage drops quickly with 4 "C" cells. A quick check, it drew 120mA.
| Top |
Sam T
Post subject: Re: Cheap mp3 player for feeding AM transmitter Posted: Mar Fri 16, 2012 1:55 pm |
Joined: Feb Sun 27, 2011 4:23 am Posts: 503 Location: Alabama Gulf Coast 36551
What are these board connectors called? I want to get some matching plugs but not familiar with the terminology. Attachment:
Thanks -Sam T.
| Top |
Pbpix
Post subject: Re: Cheap mp3 player for feeding AM transmitter Posted: Mar Fri 16, 2012 8:13 pm |
| Member |
Easy wrote: What are these board connectors called? I want to get some matching plugs but not familiar with the terminology. Thanks -Sam T. Not sure but they look like they might be a variety of "MOLEX" brand connector.... maybe the "P4-MB" ?
| Top |
rxradio
Post subject: Re: Cheap mp3 player for feeding AM transmitter Posted: Mar Fri 30, 2012 7:03 pm |
| Member |
Joined: Jun Tue 10, 2008 6:06 pm Posts: 273 Location: Edmond, OK
Easy wrote: What are these board connectors called? I want to get some matching plugs but not familiar with the terminology. Attachment: connectors.jpg Thanks -Sam T. If anyone has found a source for these plugs, please post a link..I went all over looking for them at R/S and computer stores...no luck. Even the google search has not found anything this small. yet. Dale
| Top |
Flipperhome
Post subject: Re: Cheap mp3 player for feeding AM transmitter Posted: Mar Fri 30, 2012 9:08 pm |
| Member |
rxradio wrote: If anyone has found a source for these plugs, please post a link..I went all over looking for them at R/S and computer stores...no luck. Even the google search has not found anything this small. yet. I can't really answer the question but I think those connectors are the same 'type' as found on sound cards, except those are 4 pin vs the 2 pin versions they're using. I just thinking that if you can find the ones used on sounds cards that might give you a product line to search in for the 3 pin version.
| Top |
Users browsing this forum: No registered users and 1 guest |
