Tube Radio wrote:
I doubt connecting a stetson source the way he did would cause distortion. Now it may be possible that the op could try two resistors and a capacitor in series with each resistor which would keep any dc voltage on one channel from affecting the other channel.
That's an interesting thought.
My experience, though, is that whatever one is at, 0 or offset, the other is too and, in any case, they see a 20k load between the two. That is, presuming a single ended output. All bets are off if it's BTL, but I doubt it and, if it were, he'd have troubles with mono signals as well, which he said sounded ok.
I know my sister’s iPod works into my Twin Triode Transmitter because we did it and the only difference there is I used 100ks because it's operating into a negative feedback node. I do the same thing on the Reactance Tube FM Transmitter and my heptode job used 10ks just like the configuration he made.
