| Author |
Rich K.
Post subject: refinishing Atwater Kent Type "E" speaker - DONE!!! Posted: Mar Sat 10, 2012 7:11 pm |
| Member |
Joined: Aug Tue 30, 2011 11:25 pm Posts: 932 Location: Charlevoix, Michigan, USA
I will soon be refinishing my A-K Type "E" speaker, using metallic gold for the base and "spokes" and Krylon dark brown camouflage for the rest. Only problem is, I can't seem to get the fabric out of the holes in the backing. It is still in good shape and I don't want to wreck it, but it is glued in solidly. I'm worried that masking tape will be too hard to remove. How can I paint around the cloth without getting paint on it, and still get to the edge of the metal?
| Top |
Alan Douglas
Post subject: Re: refinishing Atwater Kent Type "E" speaker - advice wante Posted: Mar Sat 10, 2012 9:49 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 23511 Location: Pocasset, Cape Cod, MA
I would first paint as close to the cloth as reasonably possible, using an artist's brush. If the color is the same (as it should be) no one will notice the contrast. Then you can make some masks, and spray the remainder of the housing.
Don't go wild with the gold.
| Top |
Rich K.
Post subject: Re: refinishing Atwater Kent Type "E" speaker - advice wante Posted: Mar Sun 11, 2012 2:46 am |
| Member |
Okay, I seem to have found a good, working method. I cut five discs out of cheap photo paper, each one 4.300" across, which is big enough to cover the fabric and sort of "snap" into place under the edges of the holes. I'll post photos when I have both the radio case (A-K 40) and the speaker done, hopefully some time this week.
| Top |
Rich K.
Post subject: Re: refinishing Atwater Kent Type "E" speaker - advice wante Posted: Mar Wed 14, 2012 3:13 pm |
| Member |
Done, and looking good (to me, at least...) Before:  After:
| Top |
Tube Radio
Post subject: Re: refinishing Atwater Kent Type "E" speaker - advice wante Posted: Mar Sun 18, 2012 3:42 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 7846 Location: Warner Robins, GA
OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO nice Makes me want to redo my AK-40 and model E speaker. Only problem with mine is in some spots on the radio I would have to recreate the wrinkle finish.
| Top |
Rich K.
Post subject: Re: refinishing Atwater Kent Type "E" speaker - advice wante Posted: Mar Mon 19, 2012 2:04 pm |
| Member |
If the scuffed spots with missing finish are small, they kind of blend in with everything else once the radio is repainted. My set had a few "bald patches", but they were small and unless you know what to look for, you can't tell they're there.
| Top |
Nick D.
Post subject: Re: refinishing Atwater Kent Type "E" speaker - advice wante Posted: Mar Mon 19, 2012 3:05 pm |
| Member |
Joined: Jun Wed 01, 2011 9:05 am Posts: 6729 Location: "Amish Country", PA
If you want to ass more splash and dash, you should paint the bacground on the AK badge... black of course.
_________________ Majestic - Crosley - Zenith ~CONSOLE FREAK~ Philco - American Bosch - RCA
| Top |
Rich K.
Post subject: Re: refinishing Atwater Kent Type "E" speaker - advice wante Posted: Mar Tue 20, 2012 12:38 am |
| Member |
Nick D. wrote: If you want to ass more splash and dash, you should paint the bacground on the AK badge... black of course.  Errr....shouldn't that be "add"??? I was trying to keep the color scheme as close to original as I could get it. I think I got it pretty close, at that. I just got done repainting the case for my Atwater Kent 35 today. Same dark brown as the 40, with a slightly lighter brown on the top panel. I found a latex paint in a small "sample" size at Ace Hardware, their own brand, color is called "Treehouse", which is a perfect match for the green color on the inside of the case. I post photos once the radio is repaired and assembled, and once I have the Type "M" horn repaired and refinished.
| Top |
Nick D.
Post subject: Re: refinishing Atwater Kent Type "E" speaker - advice wante Posted: Mar Tue 20, 2012 1:30 am |
| Member |
LOL! Little slip of the hand right there... 'D' and 'S' only have a little crack between them.  If you made the backround of the AK badge black, it would make the color scheme visually much more analogous between the radio and the speaker. It would be the visual equivalent of the knob on the radio.
| Top |
BOB BONCHAK
Post subject: Re: refinishing Atwater Kent Type "E" speaker - advice wante Posted: Mar Tue 20, 2012 2:41 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1287 Location: SOUTHLAKE, TX, USA
Anyone know where to get a close to original grille clothe for the Type E speakers? BOB
| Top |
Rich K.
Post subject: Re: refinishing Atwater Kent Type "E" speaker - advice wante Posted: Mar Tue 20, 2012 9:11 pm |
| Member |
BOB BONCHAK wrote: Anyone know where to get a close to original grille clothe for the Type E speakers? BOB Last I knew, the "E" speakers did not have grille cloth. The "F" speakers, however, do. I have even seen some "E" speakers that were all brown, instead of brown and gold, that had the cone varnished or clear lacquered so that the wood grain could be seen.
| Top |
Tube Radio
Post subject: Re: refinishing Atwater Kent Type "E" speaker - advice wante Posted: Mar Wed 21, 2012 5:41 am |
| Member |
Rich K. wrote: If the scuffed spots with missing finish are small, they kind of blend in with everything else once the radio is repainted. My set had a few "bald patches", but they were small and unless you know what to look for, you can't tell they're there. Someone had in the last painted mine a lighter shade of brown, but I can still tell some of the areas where the wrinkle has worn off.
| Top |
Art Hoch
Post subject: Re: refinishing Atwater Kent Type "E" speaker - advice wante Posted: Mar Sat 31, 2012 11:17 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2358 Location: McPherson, Kansas
Rich K. wrote: BOB BONCHAK wrote: Anyone know where to get a close to original grille clothe for the Type E speakers? BOB Last I knew, the "E" speakers did not have grille cloth. The "F" speakers, however, do. I have even seen some "E" speakers that were all brown, instead of brown and gold, that had the cone varnished or clear lacquered so that the wood grain could be seen. *************************** Both of my E speakers have grill cloth on the back side of the speaker. One of mine is a green/black paint scheme. Wood grain on the cone??? I don't have any of that.
| Top |
Rich K.
Post subject: Re: refinishing Atwater Kent Type "E" speaker - DONE!!! Posted: Mar Sat 31, 2012 11:33 pm |
| Member |
Yes, they did have grille cloth on the back of the speaker, but I don't recall the "E" series having grille cloth on the front, just a decorative metal grille. The cones are made of wood veneer, but I have only seen the clear finish over the wood grain on earlier ones that are marked "Type E" on the round medallion on the front. I believe the green/black color scheme was to match a later radio. The brown/brown speakers matched the Model 35, the brown/gold ones matched the Model 40, but I can't remember what the black/green ones were supposed to match.
| Top |
Tube Radio
Post subject: Re: refinishing Atwater Kent Type "E" speaker - DONE!!! Posted: Apr Sun 01, 2012 12:30 am |
| Member |
How thin is the wood veneer on the AK model E speaker? Mine seems to be made of thick paper at least that's what it feels like.
| Top |
BOB BONCHAK
Post subject: Re: refinishing Atwater Kent Type "E" speaker - DONE!!! Posted: Apr Sun 01, 2012 1:13 am |
HI ALL: I should have mentioned this in my earlier post! The speaker I have is a Model Type E-3, not a Type E. I thought that all "E" versions were the same, just upgrades. Have discovered that the "E" and the "E-3" are quite different. My E-3 has a large (about 12" daim.) cloth in the front, and those ellipitcal cloth pieces in the back. My front cloth has two (finger) holes in it, which cannot be repaired. Rear cloth pieces are intact but discolored. Looks like the original cloth was "gold toned", having observed the cloth that was behind the metal frame. Have done numerous internet and fabric store searches with no luck. The speaker works well with my (restored) Model 44, so I would like to restore it to as original condition as possible. Any suggestions/recommendations would be greatly appreciated. BOB
| Top |
Ron in Radio Heaven
Post subject: Re: refinishing Atwater Kent Type "E" speaker - DONE!!! Posted: Apr Sun 01, 2012 2:02 am |
| Member |
Joined: May Wed 03, 2006 4:47 am Posts: 3233 Location: Radio Heaven, North Carolina, near Charlotte, 28106-3015
The AK cone speakers came in three sizes, E, E2 & E3. Only the E3 had cloth on the front. The E speakers had several cone finishes, I have them with paper surface, leatherette and wood grain.
I have Es with brown & gold paint scheme, black & green and all dark brown.
I'd really like to fine one of the Es in black and silver and the model 37 painted the same way. Like the setup below.
| Attachments: |
_________________ 73, Ron w4ron http://radioheaven.homestead.com/menu.html http://antiqueradiocharlotte.homestead.com
| Top |
Rich K.
Post subject: Re: refinishing Atwater Kent Type "E" speaker - DONE!!! Posted: Apr Sun 01, 2012 2:05 am |
| Member |
Tube Radio wrote: How thin is the wood veneer on the AK model E speaker? Mine seems to be made of thick paper at least that's what it feels like. It is pretty thin. If you undo the tiny nut and bolt that hold the speaker cone onto the reed, and pull the cone off (you will have to remove the front part of the case first, which can be a bit tricky...), you will see the individual strips of wood veneer on the back of the cone. It caught me by surprise, too! Mine had a bit of a dent in it that I had to carefully steam out from the back with a damp cloth and an iron. Got the dent warm (not hot...) and a bit damp (but not enough to cause it to delaminate), pushed the dent back in from the front, and held it in place until it cooled down enough to stay put.
| Top |
Rich K.
Post subject: Re: refinishing Atwater Kent Type "E" speaker - DONE!!! Posted: Apr Sun 01, 2012 2:08 am |
| Member |
Ron in Radio Heaven wrote: The AK cone speakers came in three sizes, E, E2 & E3. Only the E3 had cloth on the front. The E speakers had several cone finishes, I have them with paper surface, leatherette and wood grain.
I'd really like to fine one of the Es in black and silver and the model 37 painted the same way. Like the setup below. Ah! See, you learn something new every day! I knew about the full sized "E" and the "E2", but not the "E3". Never even seen one before. I knew the "F" had front grille cloth, though (wasn't that A-K's competition for the Crosley "Dynacone"?)
| Top |
Tube Radio
Post subject: Re: refinishing Atwater Kent Type "E" speaker - DONE!!! Posted: Apr Sun 01, 2012 2:27 am |
| Member |
Rich K. wrote: Tube Radio wrote: How thin is the wood veneer on the AK model E speaker? Mine seems to be made of thick paper at least that's what it feels like. It is pretty thin. If you undo the tiny nut and bolt that hold the speaker cone onto the reed, and pull the cone off (you will have to remove the front part of the case first, which can be a bit tricky...), you will see the individual strips of wood veneer on the back of the cone. It caught me by surprise, too! Mine had a bit of a dent in it that I had to carefully steam out from the back with a damp cloth and an iron. Got the dent warm (not hot...) and a bit damp (but not enough to cause it to delaminate), pus hed the dent back in from the front, and held it in place until it cooled down enough to stay put. Maybe I need to look mine over better. I had to reglue the center of the cone back to the cone and is nowhere near perfect having I suppose been damaged sometime before I got the speaker. Will that affect sound any?
| Top |
Users browsing this forum: No registered users and 0 guests |
