Page 1 of 1
[ 15 posts ] |
| Author |
Lou deGonzague
Post subject: Halli SX-28 Made for FCC-Rare? Posted: Mar Sat 17, 2012 10:07 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 6980 Location: Latham NY
Is this considered a rare set?
| Top |
Rundfunksender
Post subject: Re: Halli SX-28 Made for FCC-Rare? Posted: Mar Sat 17, 2012 10:42 pm |
Joined: Dec Sun 06, 2009 12:29 pm Posts: 32 Location: California
Yep,you don't see them that often ! Could you also add pictures of the chassis and underside ?
Nick
| Top |
rocketeer
Post subject: Re: Halli SX-28 Made for FCC-Rare? Posted: Mar Sat 17, 2012 11:30 pm |
| Member |
Joined: Mar Tue 30, 2010 2:24 am Posts: 5141 Location: Lehighton, PA.
| Top |
Curmudgeon
Post subject: Re: Halli SX-28 Made for FCC-Rare? Posted: Mar Sat 17, 2012 11:38 pm |
| Member |
Edit: Post similar to previous.
| Top |
Lou deGonzague
Post subject: Re: Halli SX-28 Made for FCC-Rare? Posted: Mar Sat 17, 2012 11:49 pm |
Yes, I did see that web page, very good. I have to get this set into the shop and have a good look yet but it's all original underneath.. no repairs have been made.
| Top |
Burnt Fingers
Post subject: Re: Halli SX-28 Made for FCC-Rare? Posted: Mar Sun 18, 2012 12:08 am |
Joined: Oct Sat 20, 2007 3:36 am Posts: 13596 Location: New Hampshire
Scarce but not rare, most were used in nice safe and warm rooms on US soil mainly during the war when the FCC had monitoring facilities all over the country. Others were used in mobile equipment to help catch the bad guys. When they were sent to surplus many followed FCC hams home I have a SX-17F which also has a single audio tube as well as an AC-DC switch for 117VAC/6VDC and a S mter zero switch on the front panel. I dont know if Halli privided a vibrator PS for the 17 or 28 FCC. Carl
| Top |
Lou deGonzague
Post subject: Re: Halli SX-28 Made for FCC-Rare? Posted: Mar Sun 18, 2012 11:40 pm |
Here are more pics of bottom and top, caps are all original it looks.
| Top |
Rundfunksender
Post subject: Re: Halli SX-28 Made for FCC-Rare? Posted: Mar Mon 19, 2012 1:46 am |
Hey Lou It looks all original underneath except for that modification on the top near the front panel.Whats the serial no. on your SX-28 ? Regards, Nick
| Top |
Hue Miller
Post subject: Re: Halli SX-28 Made for FCC-Rare? Posted: Mar Mon 19, 2012 1:50 am |
Joined: Mar Sun 14, 2010 2:51 am Posts: 22 Location: Newport, Oregon, USA
Does this receiver have the cabinet? Reason why i ask is, i have not seen the FCC label before altho the FCC FBIS and so on used tons of them. IF you have no cabinet, i wonder if this rec came out of the "SSR-1" package, which was an SX-28 together with McLoughlin sideband demodulator packaged together in a metal desk. This was rated "SECRET" during WW2. I have photos of this unit, but i don't think you can see the label with good enuff resolution. -Hue
| Top |
w3jn
Post subject: Re: Halli SX-28 Made for FCC-Rare? Posted: Mar Mon 19, 2012 4:53 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2719 Location: Athens, Greece
Looks like it was either modified to single-ended audio, or that was a factory mod, judging from the hole plug on the chassis on the left side in your last pic. Hard to tell exactly, but does it have a pair of 6V6s or just one?
| Top |
Rundfunksender
Post subject: Re: Halli SX-28 Made for FCC-Rare? Posted: Mar Mon 19, 2012 5:34 am |
The FCC version had SINGLE ended output using one 6V6 as opposed to the regular SX-28 which had Push Pull output . Nick
| Top |
philsoldradios
Post subject: Re: Halli SX-28 Made for FCC-Rare? Posted: Mar Fri 23, 2012 7:15 am |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 3700 Location: Woodinville, WA USA
Rundfunksender wrote: The FCC version had SINGLE ended output using one 6V6 as opposed to the regular SX-28 which had Push Pull output . Any idea why? Phil Nelson Phil's Old Radios http://antiqueradio.org/index.html
| Top |
Rundfunksender
Post subject: Re: Halli SX-28 Made for FCC-Rare? Posted: Mar Fri 23, 2012 10:19 am |
To save battery power as many of these were used in mobile operations .Federal agents driving around in cars mounted with th SX-28/S-27 (FCC versions) rcvrs listening to clandestine transmissions ! Nick
| Top |
Curmudgeon
Post subject: Re: Halli SX-28 Made for FCC-Rare? Posted: Mar Sat 24, 2012 1:04 am |
| Member |
philsoldradios wrote: Any idea why?
"These SX-28s were built for FCC monitoring posts where several receiving stations would be in operation. Each operator would be using earphones to prevent listening interference to an adjacent monitoring station. Since the audio requirements were minimal, the Push-Pull audio output 6V6s were replaced with a single-ended 6V6 audio output." From: http://www.radioblvd.com/SX28Notes.htmlAbout 5/8 down the page. Bill
| Top |
Burnt Fingers
Post subject: Re: Halli SX-28 Made for FCC-Rare? Posted: Mar Tue 27, 2012 6:27 pm |
The battery power savings also played a big part and it was easier to have just one model built to spec as was the SX-17FCC that even had the Battery/AC switch on the front panel. Leading up to and during WW2 and the Commie hunts after there were quite a lot of mobile installations.
| Top |
Page 1 of 1
[ 15 posts ] |
Moderator: Sandy |
Who is online |
Users browsing this forum: Ed in SoDak and 0 guests |
