It is currently May Sun 19, 2013 6:07 pm
 Post subject: Tube glass loose in base - fix?
PostPosted: Mar Wed 28, 2012 6:56 pm
What do you guys use to repair a tube where the glass has become loose in the base but where the tube is perfectly good otherwise? I've read where superglue is not the way to go so that's out. Hi-temp silicone? Something else?
kb3wbb
My radio files free download page:
http://www.enter.net/~rocketeer/radio/radio2.html
 Post subject: Re: Tube glass loose in base - fix?
PostPosted: Mar Wed 28, 2012 7:25 pm
A little DAB or two of super glue is o.k.,just don't encircle the whole tube or it will crack if it gets hot like an output tube or rectifier tube.
Phil
I've been doing so much for so long with so little I can now do anything with nothing!
PostPosted: Mar Wed 28, 2012 9:59 pm
I repair mine with Elmors glue. I put a coat around the glass and base and wipe off the excess with a damp cloth. Stand the tube on it's base (in a small container) overnight.
Bill
PostPosted: Mar Thu 29, 2012 2:24 am
I've used silicone, but only when the base was REALLY loose - so there was room to get it inside. I always use it for plate/grid caps...
PostPosted: Mar Thu 29, 2012 2:41 am
I like Elmer's also.
PostPosted: Mar Thu 29, 2012 4:55 pm
I agree with the previous posters but I use Titebond II and use a small syringe to inject it into the crack between the glass and the base. I have found that small glass syringes are extremely useful in the shop for lubricating, contact cleaners, injecting glue into small places like tube bases and loose veneers. The glass is better since it will not react with certain solvents and, unlike plastic, can be thoroughly cleaned when done.
PostPosted: Mar Thu 29, 2012 9:32 pm
Elmers is is for the past few dacades. I like to let it dry for a week.
PostPosted: Mar Fri 30, 2012 3:40 am
I use JB weld applied with a toothpick since it is dark. A little messy and you have to hustle to wipe off the excess with an old tee shirt but it does a job that you cannot see the repair.
PostPosted: Mar Fri 30, 2012 4:13 pm
I have tried Gorilla Glue - it works but is messy unless you wipe it clean right away. Uses water as a kind of catalyst.
Nothing is easy - everything is hard.
Post New Topic Post Reply  [ 9 posts ]  Moderator: Peter Bertini
Users browsing this forum: Phil Wiesing, terry h and 3 guests
