It is currently Jun Thu 20, 2013 12:47 am
Post New Topic Post Reply  [ 107 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Post subject: Re: Andrea T-VK12 & Table Resto
PostPosted: Mar Tue 27, 2012 12:30 am
No AM Also.
Henri...give me a call. 8)
Lee
Worcester, Mass
PostPosted: Mar Tue 27, 2012 1:34 am
On my set I injected a signal and worked my way back to the tuner to figure out where it died, since I got something all the way back it figured it had to be the tuner.
Sometimes I just wiggle or pull the i.f. tubes one at a time and see where the static stops, I then figure the problem is between that tube and the last one that gave a response.
May not be the most reliable method but it's fast.
PostPosted: Mar Tue 27, 2012 3:30 am
Yeah, I wiggled away, to no avail...
I notice all I get is a faint hum out of the loudspeaker, that varies when I raise and lower the volume. No static. Because I hear a hum out of the speaker cone, does that mean the audio output transformer is operational?
Well, at least she's spankin' clean;
I think whatever is holding the set back is something trivial, IMHO. 8)
Lee
Worcester, Mass
PostPosted: Mar Tue 27, 2012 3:40 am
Do you hear a buzz if you turn on your soldering iron and briefly touch it to the center terminal of the volume control?
PostPosted: Mar Tue 27, 2012 3:44 am
Great time to break out the B&K TV Analyst. :wink:
PostPosted: Mar Tue 27, 2012 4:14 am
No, it's a great time to hit the sack.
Found out something interesting. When you switch to TV on the Input Control, the display backlights go out, of course. But, when you push in the Tone Control Knob, the backlights come on. 8)
Lee
Worcester, Mass
PostPosted: Mar Wed 28, 2012 12:32 am
Ah...screw electronic troubleshooting. Time for Cabinet work...
One coat of Danish Oil. I'll do one more when it dries overnite. 8)
Lee
Worcester, Mass
PostPosted: Mar Thu 29, 2012 1:33 am
Time to get the rf tracer and go stage by stage, see where you loose the signal. Best of luck.
Steve P
PostPosted: Mar Thu 29, 2012 4:02 am
Yup. A good buzz.
Lee
Worcester, Mass
PostPosted: Mar Thu 29, 2012 7:17 am
The buzz suggests that components downstream of that point -- output tube, transformer, speaker -- are working, so you can shift your focus upstream.
The TV's sound section is not much different than an FM radio and you can use straightforward techniques to trace where an injected signal is not getting through. In the Archives section of this website is a downloadable copy of Elements of Radio Servicing, a popular text that describes such techniques:
http://www.antiqueradios.com/archive.shtml
Last edited by philsoldradios on Mar Thu 29, 2012 11:47 pm, edited 1 time in total.
PostPosted: Mar Thu 29, 2012 8:32 pm
does the rastor have snow or is it just blank? if snow the osc tube working if just blank then suspect the osc tube.
PostPosted: Mar Thu 29, 2012 11:19 pm
Blank raster. I'll check the Osc Tube after dinner.
Thanks. 8)
Lee
Worcester, Mass
PostPosted: Mar Fri 30, 2012 3:34 am
I had a problem somewhat like that, wiggled the heck out of the osc tube eventually it started working. That was the crosley with the inductor tuner, I cant recall if I ended up with a new tube or what the deal was exactly.
PostPosted: Mar Fri 30, 2012 4:20 am
By Osc Tube you mean thye 6J6 in the Tuner Section. I checked that. All the tubes in the Tuner are new.
Lee
Worcester, Mass
PostPosted: Mar Fri 30, 2012 4:13 pm
I would start by checking the voltages at that tube. this is when a TV analyst is great as you can inject RF/IF/composite and narrow it down. If the radio is dead and I presume its a spit system, then you can narrow it down to before the pick off point which is prob pretty close to the tuner. If that is the case I would still focus on the osc, Try a lot of tube wiggling and voltage checking.
PostPosted: Mar Fri 30, 2012 6:39 pm
I have a philco split chassis set that won't pass a signal if the OSC tube is in the wrong spot in it's socket. Whenever it dies I go and wiggle the osc to fix it. Some sets are finicky like that even after socket cleaning.
Tom C.
PostPosted: Mar Fri 30, 2012 9:58 pm
Tom C.
Sounds like the contacts in the socket are loose and not putting enough pressure on the tube pins. Sometimes you can bend the contacts in the socket and tighten them.
PostPosted: Mar Sat 31, 2012 12:01 am
What did you clean your power transformer with to make it look new?
Doug
PostPosted: Mar Sat 31, 2012 12:20 am
I did the voltage check. They came out fine.
Lee
Worcester, Mass
PostPosted: Mar Sat 31, 2012 12:32 am
Doug
Spray Nine. Wash, Rinse, Blow Dry, Bake in Oven 2-3 hours @125 F.
Lee
Worcester, Mass
Post New Topic Post Reply  [ 107 posts ]  Moderators: Mr. Detrola, 7jp4-guy Go to page Previous  1, 2, 3, 4, 5, 6  Next
Users browsing this forum: Tom Schulz and 2 guests
