It is currently May Thu 23, 2013 1:09 pm
 Post subject: Supreme Audiolyzer model 562 help needed
PostPosted: Mar Thu 29, 2012 10:30 pm
got one at a meet, unfortunately, it is a variant to the 2 schematics that Steve Johnson has on his site, using 6sn7, 6ac7, 6sg7, 6sq7 and 80. Some one has monkeyed with it, but looks to be some cap changes/replacements, but loose wires make it somewhat hard to rebuild. I know that it is a variant, and not just someone slamming tubes in it, the resistor from pin 1 to 3 (2K) is missing, and a wire is in its place, that wire is definitely factory wired. Anyone with suggestions/schematics, I may have to rebuild back to the closest version I have a schematic to, that would make this a winter-time 2015 project! thanks
 Post subject: Re: Supreme Audiolyzer model 562 help needed
PostPosted: Mar Fri 30, 2012 2:02 am
Supreme manufactured these for a few years. The main difference outwardly is the later versions had a four position meter select switch. The early runs had a three position switch. There were major circuit changes between the two versions but I don't know how many different circuit changes were made in the later series over the years. Check your switch to see if you have an early version or a later version.
Steve Johnson
PostPosted: Mar Fri 30, 2012 4:46 pm
thanks, Steve, I have the 4-position meter switch version. The closest schematic is the Beitman from your webpage, but there are differences, both in some of the circuitry and the tube line-up. At this point, unless I luck across the schematic or manual, I will have to rebuild to the Beitman schematic...
PostPosted: Mar Fri 30, 2012 5:07 pm
Randy,
If you are going to use that one go and download it again.
The one I had posted there was scanned years ago. I just replaced it with a higher resolution one.
http://www.supremeinstruments.org/data.htm
Steve Johnson
PostPosted: Mar Fri 30, 2012 5:20 pm
thanks, Steve, got it! And thanks again for your excellent website!
