Page 1 of 1
[ 9 posts ] |
| Author |
rocketeer
Post subject: Tube glass loose in base - fix? Posted: Mar Wed 28, 2012 6:56 pm |
| Member |
Joined: Mar Tue 30, 2010 2:24 am Posts: 5144 Location: Lehighton, PA.
What do you guys use to repair a tube where the glass has become loose in the base but where the tube is perfectly good otherwise? I've read where superglue is not the way to go so that's out. Hi-temp silicone? Something else?
Thanks, Larry
_________________ kb3wbb
My radio files free download page: http://www.enter.net/~rocketeer/radio/radio2.html
| Top |
Philco Fan
Post subject: Re: Tube glass loose in base - fix? Posted: Mar Wed 28, 2012 7:25 pm |
Joined: Jul Tue 18, 2006 5:23 am Posts: 4888 Location: Roseville,Ca
A little DAB or two of super glue is o.k.,just don't encircle the whole tube or it will crack if it gets hot like an output tube or rectifier tube. Phil
_________________ I've been doing so much for so long with so little I can now do anything with nothing!
| Top |
Bill njb
Post subject: Re: Tube glass loose in base - fix? Posted: Mar Wed 28, 2012 9:59 pm |
Joined: Oct Tue 06, 2009 8:41 pm Posts: 764 Location: Ceres, CA 95307
I repair mine with Elmors glue. I put a coat around the glass and base and wipe off the excess with a damp cloth. Stand the tube on it's base (in a small container) overnight. Bill
| Top |
Tom Bavis
Post subject: Re: Tube glass loose in base - fix? Posted: Mar Thu 29, 2012 2:24 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 3852 Location: Rochester NY USA
I've used silicone, but only when the base was REALLY loose - so there was room to get it inside. I always use it for plate/grid caps...
| Top |
Alan Douglas
Post subject: Re: Tube glass loose in base - fix? Posted: Mar Thu 29, 2012 2:41 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 23520 Location: Pocasset, Cape Cod, MA
| Top |
eeprof
Post subject: Re: Tube glass loose in base - fix? Posted: Mar Thu 29, 2012 4:55 pm |
Joined: Mar Sat 28, 2009 8:27 pm Posts: 350 Location: Georgia
I agree with the previous posters but I use Titebond II and use a small syringe to inject it into the crack between the glass and the base. I have found that small glass syringes are extremely useful in the shop for lubricating, contact cleaners, injecting glue into small places like tube bases and loose veneers. The glass is better since it will not react with certain solvents and, unlike plastic, can be thoroughly cleaned when done.
| Top |
codefox
Post subject: Re: Tube glass loose in base - fix? Posted: Mar Thu 29, 2012 9:32 pm |
Elmers is is for the past few dacades. I like to let it dry for a week.
| Top |
decoradioman
Post subject: Re: Tube glass loose in base - fix? Posted: Mar Fri 30, 2012 3:40 am |
Joined: Nov Mon 03, 2008 10:47 pm Posts: 377 Location: Little Rock, AR
I use JB weld applied with a toothpick since it is dark. A little messy and you have to hustle to wipe off the excess with an old tee shirt but it does a job that you cannot see the repair.
| Top |
Dick Parks
Post subject: Re: Tube glass loose in base - fix? Posted: Mar Fri 30, 2012 4:13 pm |
| Member |
Joined: Jan Wed 13, 2010 5:11 pm Posts: 219 Location: Oakton, VA
I have tried Gorilla Glue - it works but is messy unless you wipe it clean right away. Uses water as a kind of catalyst.
_________________ Nothing is easy - everything is hard.
| Top |
Who is online |
Users browsing this forum: No registered users and 1 guest |
