It is currently Jun Thu 20, 2013 7:36 am
 Post subject: How can I make a very directional AM antenna?
PostPosted: Mar Thu 29, 2012 2:09 am
I am using a modulated 560 kHz radio signal to find a defective (buried) lawn sprinkler system valve. I connected a signal generator to the wire going to the defective valve at the timer, earth grounding the other lead, and use a radio to follow the wire along the ground. It works fine except the radio is too sensitive to narrow the location down to a small area. Reducing the generator signal level or the radio gain does not help. What I think I need is a very directional antenna that I can aim at the buried wire. I can adjust the generator signal level from millivolts to about 20 volts so antenna sensitivity is not critical. Any ideas?
 Post subject: Re: How can I make a very directional AM antenna?
PostPosted: Mar Thu 29, 2012 5:41 am
I would think the internal rod/coil antenna in a small transistor radio would be very directional.
If not, you can try building an external loop antenna, but that gets a bit more cumbersome.
viewtopic.php?f=10&t=189686
PostPosted: Mar Thu 29, 2012 2:26 pm
Just about any transistor radio with a built-in ferrite rod antenna will work as a direction finder. They produce a very sharp and deep null when oriented lenghwise toward the signal. There will be another null 180 degrees in the opposite direction but, in this case, you know that the valve isn't toward the sky.
PostPosted: Mar Sat 31, 2012 12:29 am
How deep is the wire? A DC current of about 10 amps through the pipe, (car battery old headlight in series)
and a compass or even a dipping needle will find it in a jiffy.
Dipping needle
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
Users browsing this forum: Flipperhome and 0 guests
