It is currently May Sat 18, 2013 1:33 pm
 Post subject: 6DJ3 tube
PostPosted: Mar Sat 31, 2012 11:58 pm
have a 6DJ3 tube but can't find any info on it anywhere.anybody know what is is?
thanks
Visit us on the web at: sunshineradiomuseum.org
W2HJC
 Post subject: Re: 6DJ3 tube
PostPosted: Apr Sun 01, 2012 12:16 am
I can't find anything either, but it sounds like a damper tube.
PostPosted: Apr Sun 01, 2012 12:19 am
whats a damper tube?don't know what that is.thanks
W2HJC
PostPosted: Apr Sun 01, 2012 12:21 am
Have you looked closely? It may be a 6DJ8 with wear on the 8 making it look like a 3.
PostPosted: Apr Sun 01, 2012 12:23 am
no it definitely says 6DJ3.thought the same thing but the 3 is pretty clear.
W2HJC
PostPosted: Apr Sun 01, 2012 12:36 am
heres a pic of the tube with number
W2HJC
PostPosted: Apr Sun 01, 2012 12:52 am
Didn't find 6DJ3 but you pictured a high voltage rectifier.. Should be similar to 1B3 or 3A3 with 6 volt filament.
PostPosted: Apr Sun 01, 2012 12:57 am
thanks Norm.wonder what it was used in?
W2HJC
PostPosted: Apr Sun 01, 2012 2:18 am
I sent this thread to Tom, 35Z5. He has a CD which lists most all tubes. He might have more information.
This tube would have been used to rectify high voltage for a CRT (Cathode Ray Tube) either in an oscilloscope, TV etc..
PostPosted: Apr Sun 01, 2012 2:32 am
ok thanks.wil be interesting to see what he comes up with.wonder why it isn't listed anywhere?
W2HJC
PostPosted: Apr Sun 01, 2012 4:49 am
Someone at GE was having fun with the etcher, the only 6Dxx registered is the 6DJ8 already mentioned... GE registered the 3DJ3 on 8/25/69, I have little doubt this tube is anything else...
It's defiantly a oddity, maybe a collectors piece though not likely worth a great deal...
PostPosted: Apr Sun 01, 2012 1:49 pm
thanks 35Z5.guess I will sit on the shelf as a display.would be interesting to know why they did make it and for what just so I could have the history of the tube to go with it.thanks again everybody
W2HJC
PostPosted: Apr Sun 01, 2012 3:25 pm
Could measure current drawn by the filament with 3 volts applied? 3DJ3 draws .3 amps. A tube with a higher voltage filament should draw less.
Search the internet for 6DJ3. Also errors there.
PostPosted: Apr Sun 01, 2012 11:55 pm
Uh, the tube number shown in the picture looks like a 3DJ3 to me.
Color TV hv rect.
FrankB
WB7ELC
Member: TCA
"I know that all that is wrong with it is one little part".
Post New Topic Post Reply  [ 14 posts ]  Moderator: Peter Bertini
Users browsing this forum: BigBandsMan and 1 guest
