Page 1 of 1
[ 11 posts ] |
| Author |
Noble
Post subject: Cleaning Control Knobs Posted: Feb Wed 16, 2011 6:54 am |
Joined: Dec Mon 13, 2010 7:29 am Posts: 161 Location: New Zealand
Cleaning knobs one by one can become frustrating and a fine knurled grip pattern can make things difficult. Denture cleaner of the immerse and soak for a while type, is designed to efficiently clean both plastic and metal without damage.
With this in mind I recently gave a complete set of rather intricate knobs the treatment simultaneously with an excellent result and no other work being called for. If you have your own teeth, it is worth purchasing the stuff for this very purpose. Simply read the instructions and soak for a shine, no sweat!
| Top |
morseguy
Post subject: Posted: Apr Tue 19, 2011 11:22 pm |
| Member |
Joined: Aug Mon 28, 2006 3:07 am Posts: 993 Location: Boston area
I surprised no one chimed in on this. I am soaking knobs right now in dish detergent and warm water right now. This is my usual method.
Your idea sounds good though.
| Top |
Johnnysan
Post subject: Posted: Apr Wed 20, 2011 12:36 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 11441 Location: Albuquerque, NM 87123
I picked up some denture cleaner at an estate sale, but haven't tried it yet.
My usual routine is to soak knobs for 45 minutes or so in a mason jar with hot water and baking soda; works fine most of the time. An old toothbrush gets the knurled knobs clean.
| Top |
Radio Fixer
Post subject: Posted: Apr Wed 20, 2011 9:08 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1343 Location: England
Small ultrasonic cleaner and a dab of detergent in warm water works fine for me.
| Top |
Chuck Schwark
Post subject: Posted: Apr Wed 20, 2011 5:56 pm |
| Moderator |
Joined: Jan Thu 01, 1970 1:00 am Posts: 5869 Location: Evanston, IL
Dawn dishwashing liquid in warm water soak for 10 mins.
Toothbrush and toothpick (if needed).
Chuck
_________________ Chuck Schwark,
The Philco Repair Bench
Schematic Photocopy Service
www.philcorepairbench.com
| Top |
divad41
Post subject: Posted: Apr Sun 24, 2011 3:05 am |
| Member |
Joined: Aug Sun 15, 2010 4:33 am Posts: 693 Location: Oahu, Hawaii
I also use the 'soak in H20/Dawn' approach. Sometimes I leave it soak for overnite or longer if really grungy. And have found the the dis-cardable vibrating toothbrushes help worry the multi-decade grime out of the inside corners.
I usually use a different one than the one I brush my teeth with... I think... er, wait a minute, I gotta go check the colors just now...
| Top |
Ken G
Post subject: Posted: Apr Sun 24, 2011 4:11 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 14582 Location: ID 83301
I have switched to Westleys tire cleaner for the most part . It will however dull bakelite . Most of the time no soaking is needed with the stuff .
| Top |
Brooklyn Antique Radios
Post subject: Re: Cleaning Control Knobs Posted: Apr Mon 02, 2012 4:29 am |
Joined: Jul Sat 04, 2009 7:45 am Posts: 331 Location: Brooklyn, NY
Go-Jo on plastic and Bakelite with a toothbrush for in and out of crevices, rinse with water and let dry. Followed by a spray of novus polish # 1, let dry and with a shoeshine brush you can buff them up like glass. Vin
| Top |
Post subject: Re: Cleaning Control Knobs Posted: Apr Tue 03, 2012 4:15 am |
What do you folks use on wood knobs? I was told by an ARF member to use nothing. He said that any cleaning or polishing liquid if it found even a slight crack could further the knobs demise. Vin
| Top |
jgj6331
Post subject: Re: Cleaning Control Knobs Posted: Apr Tue 03, 2012 1:19 pm |
| Member |
Joined: Nov Thu 08, 2007 4:37 pm Posts: 4386 Location: Central Georgia
If you're going to use a toothbrush, cut the bristles off to a length of 1/8" to 1/4" with scissors first. It will stiffen the bristles and you'll be surprised how how much better it works with this quick and easy haircut. I use Windex and a dish washing soap with the modified brush. Some folks swear by flux brushes with the bristles trimmed - but the old toothbrushes are free - and I'm cheap!!!!
_________________ JG Jackson
"Uva Uvam Videndo Varia Fit"
| Top |
Noble
Post subject: Re: Cleaning Control Knobs Posted: Apr Thu 05, 2012 7:24 am |
Thanks, you rocked my brain.
I just took your obviously excellent advice and it sure worked but, I could not cut the nylon bristles with scissors and had to resort to a sharp knife and cutting board. LOL
_________________ No Bull !
| Top |
Users browsing this forum: No registered users and 0 guests |
