Page 1 of 1
[ 10 posts ] |
| Author |
J4AMDX
Post subject: Zenith G500 plastic dial and grill removal Posted: Mar Fri 30, 2012 5:05 pm |
Joined: Jul Sun 25, 2010 10:56 pm Posts: 80 Location: Medford, Oregon
Hello, I want to start the cabinet restoration on my Zenith G500. I would appreciate any tips on removing the plastic grill and dial from the cabinet. I read that there are some clips holding it that can be a problem. Thanks.
| Top |
Ed Morris
Post subject: Re: Zenith G500 plastic dial and grill removal Posted: Mar Sat 31, 2012 3:25 am |
| Member |
Joined: Jan Sun 06, 2008 3:28 am Posts: 2186 Location: Richmond, VA
Yes, the plastic grill front is secured by tinnerman nuts over plastic studs. It's very easy to snap off the studs. I don't know of any easy way to get them off except to take your time and work carefully.
_________________ Ed
| Top |
Bugman
Post subject: Re: Zenith G500 plastic dial and grill removal Posted: Mar Sat 31, 2012 2:11 pm |
Joined: Mar Sat 14, 2009 5:56 pm Posts: 2050 Location: RI, 02885
I've had success in the past rotating the metal retainers slowly and more or less forming threads on the plastic posts. You could describe it as 'unscrewing them'. Use extreme caution though. If you pry them you are almost certainly going to break the posts. Later, I just screw them back on very gently. As stated above, they break off very easy and you can't simply glue them back on.
| Top |
Ed Morris
Post subject: Re: Zenith G500 plastic dial and grill removal Posted: Mar Sat 31, 2012 2:51 pm |
| Member |
| Top |
J4AMDX
Post subject: Re: Zenith G500 plastic dial and grill removal Posted: Apr Mon 02, 2012 5:55 am |
Thank you for the information. When I pulled the chassis and could see the four clips, I remembered that I had worked with these spring clips before in my other Trans-Oceanics. I use a very sharp awl that looks like an ice pick. The sharp end is angled at 90 degrees . I very very carefully take the pressure off the post. These spring clips have two fingers that grip the post. This awl lets you take the pressure off the clip fingers while very carefully putting a little upward pressure on the clip. Carefully go back and forth between the two fingers of the clip. With great care and patience I was able to remove all four clips with no damage to any of the post. I also used the same method to remove the two clips holding the speaker cloth. Maybe I'm just lucky. Proceed with caution.
| Top |
Ed Morris
Post subject: Re: Zenith G500 plastic dial and grill removal Posted: Apr Mon 02, 2012 1:44 pm |
| Member |
Good work! Could you post a picture of the awl you used? I might want to make one. I'm always running in to those tinnerman nuts on old radios and rarely get them off without breaking something.
| Top |
J4AMDX
Post subject: Re: Zenith G500 plastic dial and grill removal Posted: Apr Tue 03, 2012 1:54 am |
Hi Ed. I'll try to post a couple pictures next weekend. Thanks
| Top |
Bugman
Post subject: Re: Zenith G500 plastic dial and grill removal Posted: Apr Tue 03, 2012 4:50 am |
HF sells a set of picks/awls with hooks, right angles, etc.. I keep a set on my bench. Check their website. They're cheap but useful. I just received the latest flyer and they are #66836-FCH.
| Top |
Ed Morris
Post subject: Re: Zenith G500 plastic dial and grill removal Posted: Apr Tue 03, 2012 11:26 pm |
| Member |
Bugman wrote: HF sells a set of picks/awls with hooks, right angles, etc.. I keep a set on my bench. Check their website. They're cheap but useful. I just received the latest flyer and they are #66836-FCH. I looked those up, they look pretty handy and on sale for $1.99. http://www.harborfreight.com/4-piece-pick-and-hook-set-66836.html
| Top |
J4AMDX
Post subject: Re: Zenith G500 plastic dial and grill removal Posted: Apr Wed 04, 2012 7:34 pm |
Hi Ed. I looked at the posting of the four tool set. The fourth one on the right is very very close to what I use. between the two on the far right, they should be able to get the job done. Its very important to move the clips up the post very little at a time. Sometimes you can hear the spring fingers click when they are released by the tool on the post. Thanks.
| Top |
Page 1 of 1
[ 10 posts ] |
Moderator: Peter |
Who is online |
Users browsing this forum: No registered users and 1 guest |
