Page 1 of 1
[ 10 posts ] |
| Author |
WA8RVD
Post subject: SX-28 Power Transformer Posted: Apr Wed 04, 2012 3:57 pm |
Hello All, I have a bad power transformer in my SX-28. The manual says it should have a 580 volt center tapped @ 185 ma secondary. I have found Hammond transformers - one with a 550 v @ 230 ma secondary and one with a 600 v @ 230 ma secondary. Which would be the better choice?
Mike WA8RVD
| Top |
Ancient_Hacker
Post subject: Re: SX-28 Power Transformer Posted: Apr Wed 04, 2012 5:25 pm |
You can always drop the voltage a bit with a resistor, but you can't easily raise it, so maybe go with the higher voltage one.
Then again, there's no need to push the voltage limits, the radio has plenty of gain and audio output power, so going a few volts low isn't going to hurt things significantly.
| Top |
hbr nut
Post subject: Re: SX-28 Power Transformer Posted: Apr Wed 04, 2012 6:36 pm |
Either one should work okay. Personally, I'd go with the 550VCT since the transformer will not be fully loaded and the measured voltage will likely be a bit higher than stated.
Darrell
| Top |
K7MCG
Post subject: Re: SX-28 Power Transformer Posted: Apr Wed 04, 2012 6:43 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2038 Location: Seattle WA US
Check the line voltage for which the Hammond transformer is specified - and your local line voltage. If Hammond specs at 117v and your line voltage is 125 volts (for example) you may want the lower of the two transformer output voltages.
--Chuck
| Top |
WA8RVD
Post subject: Re: SX-28 Power Transformer Posted: Apr Wed 04, 2012 6:54 pm |
Thanks all for your advice - I ordered one - I'll let the list know if it works. Be nice to know a replacement xfmr for an SX-28. It's a Hammond 270HX
| Top |
WA8RVD
Post subject: Re: SX-28 Power Transformer Posted: Apr Wed 18, 2012 10:38 pm |
UPDATE: The transformer fit well and functions well. Hammond now has a tap on the primary so that it can be set up for 115 volts or 125 volts. This SX-28 lives again!
| Top |
Johnnysan
Post subject: Re: SX-28 Power Transformer Posted: Apr Wed 18, 2012 10:49 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 11441 Location: Albuquerque, NM 87123
| Top |
WA8RVD
Post subject: Re: SX-28 Power Transformer Posted: Apr Sat 21, 2012 8:15 pm |
Sorry - no photos - it's back in its place on the shelf under everything else! The transformer went in with no new holes (of course) - there is a rectangular hole in the chassis for the old transformer and the mounting bolts for the new one captured the edge of this hole. Looks nice but not original! It does work fine. I removed a S.S. bridge rectifier that was soldered into the tube socket and it has a tube again! Paper caps and electrolytics replaced. I need to repaint the cabinet later this summer along with several others. Lots of fun.
| Top |
Dougj
Post subject: Re: SX-28 Power Transformer Posted: May Mon 14, 2012 4:40 pm |
where did you order the transformer from,
who has the best deal on transformers? , that 270hx looks like a good choice for my dead HQ-145A
my receiver isnt worh throwing a 100 dollar transformer in, maybe Ill find a good deal in Dayton...
Doug
| Top |
WA8RVD
Post subject: Re: SX-28 Power Transformer Posted: May Wed 16, 2012 11:12 pm |
Hello, Doug I got mine from Radio Daze but AES and Fair Radio among others carry them.
| Top |
Page 1 of 1
[ 10 posts ] |
Moderator: Sandy |
Who is online |
Users browsing this forum: azenithnut and 2 guests |
