It is currently May Tue 21, 2013 11:37 pm
 Post subject: Expected life of 6G5 tube
PostPosted: Apr Thu 05, 2012 7:18 pm
I recently purchased a new 6G5 tuning indicator "magic eye" tube for my hallicrafters SX-11 receiver as the old one was dim. I got to wondering about the life span of these type tubes and if I should buy another one to have for a spare while they're still available. Does anybody have any idea on how long these type tubes last before starting to go dim?
"Why don't you knock it off with them negative waves?"
 Post subject: Re: Expected life of 6G5 tube
PostPosted: Apr Thu 05, 2012 8:02 pm
All I cn tell you is that if you have your set in a dark room and only fire it up once a week for a couple of hours, you'll likely not need a spare. I have some test stuff with bulbs older than the hills that are still quite bright. If you do get a spare, keep it in the dark.
PostPosted: Apr Thu 05, 2012 8:59 pm
Guess you've never seen this....
http://dialcover.com/eyetube.html
PostPosted: Apr Thu 05, 2012 9:27 pm
It takes around 1000 hours of operation to notice green has dimmed.
Unusual to find a new 6G5. The 6G5 was often used in radios but most were replaced by 6U5, straight sided tube. Although some 6U5 tubes were marked 6U5/6G5 don't remember seeing new 6G5 (ST tubes).
PostPosted: Apr Thu 05, 2012 10:35 pm
Actually the replacement tube I got is a 6U5 NOS tube, not a 6G5.
Post New Topic Post Reply  [ 5 posts ]  Moderator: Peter Bertini
Users browsing this forum: Usually Lurking and 0 guests
