Page 1 of 1
[ 8 posts ] |
| Author |
digitalbt
Post subject: Need help identifying 2 Transistors for a TEAC A-1250 Deck Posted: Mar Sun 25, 2012 7:00 pm |
| Member |
Joined: Mar Fri 14, 2008 3:18 pm Posts: 40 Location: Missouri
I have two suspicious transistors. What's marked on them is as follows:
1. 693GS (it has a round head on it) 2. MPS 6518 or 651B (There is a Motorola M just before the MPS)
These were taking from the preamp board of my TEAC reel to reel tape recorder.
I am getting a static low volume roar out of the left channel.
Thanks for your help identifying these!
| Top |
Johnnysan
Post subject: Re: Need help identifying 2 Transistors for a TEAC A-1250 De Posted: Mar Sun 25, 2012 11:19 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 11441 Location: Albuquerque, NM 87123
The 693GS can probably be replaced with an NTE 123AP. The MPS6518 can be subbed with aN NTE 159.
| Top |
arbilab
Post subject: Re: Need help identifying 2 Transistors for a TEAC A-1250 De Posted: Mar Mon 26, 2012 1:01 am |
Joined: May Sat 14, 2011 5:42 am Posts: 2567 Location: Ft Worth TX
96% probablility the Motorola was a service substitute. I don't recall ever seeing a US semiconductor brand in Japanese electronics. The originals were most likely Toshiba.
| Top |
digitalbt
Post subject: Re: Need help identifying 2 Transistors for a TEAC A-1250 De Posted: Mar Mon 26, 2012 1:17 am |
| Member |
Thanks so much! On order!
| Top |
Fred Longworth
Post subject: Re: Need help identifying 2 Transistors for a TEAC A-1250 De Posted: Mar Tue 27, 2012 6:04 pm |
Joined: Jun Fri 22, 2007 12:54 am Posts: 680 Location: San Diego
Always use 2SC2240 for NPN replacements and 2SA992 for PNP replacements.
The NTE123A is suitable for troubleshooting applications, but I would NEVER install it in a low-noise circuit.
Also, most technicians would squirt some freeze-mist on a transistor suspected of being noisy. If this reduces the noise audibly, it corroborates your suspicion that the device is defective. Finally, you can measure transistor leakage with an ordinary ohmmeter.
Fred owner Classic Audio Repair
_________________ www.repairaudio.com
| Top |
Mark D
Post subject: Re: Need help identifying 2 Transistors for a TEAC A-1250 De Posted: Apr Tue 03, 2012 8:25 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 4528 Location: Litchfield Minnesota USA
A bit off topic for this thread, but related, I have a question. Is there any similarity between the A-1250 and the A-1200U? Wondering. Mark D.
| Top |
Jim L.
Post subject: Re: Need help identifying 2 Transistors for a TEAC A-1250 De Posted: Apr Fri 06, 2012 7:12 pm |
Joined: Mar Sun 28, 2010 10:15 pm Posts: 39 Location: Sacramento, CA
The A-1250 is a much newer machine than the A-1200U. The "U" stands for "Universal" export model which works on many line voltages and 50/60 Hz. The A 1200 series is from the late 1960's.
Jim L.
| Top |
Mark D
Post subject: Re: Need help identifying 2 Transistors for a TEAC A-1250 De Posted: Apr Sat 07, 2012 6:18 pm |
Never knew what the U stands for, but my Teac is an A-1200U, according to the model number on it. But it is only 120VAC. (117) There is no provision (that I know of) for it to operate on different voltage or frequencies. Maybe there are taps inside on a transformer. I wouldn't know about that. I didn't know about the years of difference between the A1200 and the A1250, thought I'd ask, on the chance that there might be some similarities. Thanks Mark D.
| Top |
Page 1 of 1
[ 8 posts ] |
Who is online |
Users browsing this forum: Chuck and 1 guest |
