It is currently May Thu 23, 2013 2:57 am
 Post subject: How does it function ~ F & H Capacity Aerial Eliminator
PostPosted: Mar Tue 27, 2012 7:02 pm
Hi Everyone,
I received the F & H capacity Aerial Eliminator from one of our members Brian.
I replaced all the wires. Has anyone ever used these gizmos? I was curios to know how it used to be wired to the radio since the advertisement says "No Power required". Any help will be great. Thanks.
Ash
~ The radio was the Internet of its time ~
 Post subject: Re: How does it function ~ F & H capacity Aerial Eliminator
PostPosted: Mar Tue 27, 2012 7:08 pm
Hi Ash,
If it works the same as the newer ones (and it appears much the same) then the end with two leads would hook to the AC wiring of the house, through the eliminators internal capacitor, using the wiring as sort of a long antenna. Obviously the capacitor was to bypass RF, stopping the AC component from getting through. :idea: Hope I was of some assistance. Good luck! Mike
 Post subject: Re: How does it function ~ F & H Capacity Aerial Eliminator
PostPosted: Mar Tue 27, 2012 8:36 pm
Hi Mike,
I'm confused as the advertisement says as follows
Ash
PostPosted: Mar Tue 27, 2012 9:08 pm
The brown wire that looks like AC line cord... where does it connect?
PostPosted: Mar Wed 28, 2012 1:58 am
Well, just a guess--I THINK it might connect inside the radio itself. As I mentioned before, to the AC circuit but possibly to the cord of the radio itself. Without the original instructions it's just a guess, any chance of getting those?
http://www.freepatentsonline.com/1922335.pdf
I found this, might help. There is more with a google search of 'aerial eliminator' just have to dig!
PostPosted: Apr Sat 07, 2012 11:07 pm
A pic of the guts would be helpful. It is definitely not a AC line antenna eliminator.
My guess would be coil and fixed cap antenna tuner that would work well with a short indoor antenna or the set's internal loop antenna.
PostPosted: Apr Sun 08, 2012 3:49 am
Hi,
Thanks! I have received all 4 emails with attachments.
The one I have is totally different from all these.
Let me open it and take some pics.
Ash
PostPosted: Apr Mon 09, 2012 6:32 pm
I predict..... 2 capacitors inside. (thats it)
PostPosted: Apr Mon 09, 2012 8:36 pm
Two caps and a coil in a balanced tuner set up would increase selectivity.
Only two high value caps could tune a short antenna or loop closer to the broadcast band. Same as the one with a coil but not nearly as well.
Post New Topic Post Reply  [ 9 posts ]  Moderator: Peter Bertini
Users browsing this forum: Usually Lurking and 1 guest
