| Author |
Salval
Post subject: Best Capacitors? Posted: Apr Wed 11, 2012 2:56 am |
| Member |
What do you guys suggest for replacement of capacitors? I'm just getting started and am not worried about parts looking original.
| Top |
Jack Shirley
Post subject: Re: Best Capacitors? Posted: Apr Wed 11, 2012 3:20 am |
| Member |
Joined: Mar Fri 14, 2008 1:40 pm Posts: 8563 Location: SE USA
Plain old yellow caps from any number of vendors.. There is no 'best'.
_________________ The beatings will continue until the morale improves
| Top |
Salval
Post subject: Re: Best Capacitors? Posted: Apr Wed 11, 2012 3:26 am |
| Member |
| Top |
Pbpix
Post subject: Re: Best Capacitors? Posted: Apr Wed 11, 2012 4:02 am |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 9334 Location: Haledon, NJ, usa
The green Mylar caps that are available from "www.justradios.com" are excellent .... and they are also the best bang for your buck. They are available in both 400v and 630v type. http://www.justradios.com/MYLARcapacitors.html
_________________ " To be a man, Be a non-conformist, Nothing is as sacred as integrity of your own mind." Emerson
| Top |
Burnt Fingers
Post subject: Re: Best Capacitors? Posted: Apr Wed 11, 2012 3:54 pm |
Joined: Oct Sat 20, 2007 3:36 am Posts: 13596 Location: New Hampshire
A quick glance thru common values at Mouser shows them to be the better deal.
| Top |
Brooklyn Antique Radios
Post subject: Re: Best Capacitors? Posted: Apr Wed 11, 2012 10:36 pm |
Joined: Jul Sat 04, 2009 7:45 am Posts: 331 Location: Brooklyn, NY
What makes the green Mylar a better deal? Price, performance, reliability? Vin
| Top |
Bob Masse
Post subject: Re: Best Capacitors? Posted: Apr Wed 11, 2012 10:49 pm |
Joined: Apr Thu 02, 2009 7:32 pm Posts: 807 Location: South Western Ontario Canada
They come in bulk. I've used them in test equipment, so far, and had good results. I contacted Dave at JR before I bought them. He told me they weren't as good as the yellow caps but were much better than the original paper caps that were used in the old radios.
| Top |
Pbpix
Post subject: Re: Best Capacitors? Posted: Apr Wed 11, 2012 11:01 pm |
| Member |
Vinny Adelfio wrote: What makes the green Mylar a better deal? Price, performance, reliability? Vin I like the price... they measure right at or darn close to stated value and I haven't ever had any of them fail.. So what's not to like? I like to use radial instead of axial too so they really are small and make it all look neater underneath. In most cases one end of caps go to ground. So in the old days the axial caps were big and long so they had to find a ground wherever they could at the end of the big ole cap. But it's best to always seek the nearest ground point so.. ground points are usually everywhere nearby or right on the same tube socket.. so why stretch the new cap to the old distant ground point? Radial's fit from the active point to the nearest ground so beautifully.
| Top |
Burnt Fingers
Post subject: Re: Best Capacitors? Posted: Apr Wed 11, 2012 11:22 pm |
Quote: They come in bulk. I've used them in test equipment, so far, and had good results. I contacted Dave at JR before I bought them. He told me they weren't as good as the yellow caps but were much better than the original paper caps that were used in the old radios. Which isnt saying very much. I use the Panasonic version when I want to get 1% or better tolerance. Quote: In most cases one end of caps go to ground. So in the old days the axial caps were big and long so they had to find a ground wherever they could at the end of the big ole cap. But it's best to always seek the nearest ground point so.. ground points are usually everywhere nearby or right on the same tube socket.. so why stretch the new cap to the old distant ground point? Radial's fit from the active point to the nearest ground so beautifully. Thats fine since all you work on is AA-5's, but in much older sets and those with SW the ground location and component dressing is often critical. Carl
| Top |
Pbpix
Post subject: Re: Best Capacitors? Posted: Apr Thu 12, 2012 12:44 am |
| Member |
Burnt Fingers wrote: Quote: In most cases one end of caps go to ground. So in the old days the axial caps were big and long so they had to find a ground wherever they could at the end of the big ole cap. But it's best to always seek the nearest ground point so.. ground points are usually everywhere nearby or right on the same tube socket.. so why stretch the new cap to the old distant ground point? Radial's fit from the active point to the nearest ground so beautifully. Thats fine since all you work on is AA-5's, but in much older sets and those with SW the ground location and component dressing is often critical. Carl That's not correct... the shortest path to ground with any capacitor in SW and older sets is always the better design. ...In fact in SW sets and especially at higher frequencies the shorter the leads the better.... right? lead dress might be critical where audio signals pass by other noisy points and such... but a cap to ground is almost never better than connecting it via the shortest path. If you don't agree Carl.. please show me a circuit where a cap connects to ground and it is BETTER to not make that path short.
| Top |
Tubenut
Post subject: Re: Best Capacitors? Posted: Apr Thu 12, 2012 2:08 am |
Joined: Oct Sun 11, 2009 10:06 am Posts: 1441 Location: British Columbia
The shortest path to RF ground. The area of your radio chassis can be viewed as lead length also. Of course there are inductive propertys too. This is why the design of RF circuity in the top end of HF, through VHF and higher, takes some experience to design. Most of the time, in MW and SW, the lead length isn't too particular.... Excluding the oscillator circuit. If you design an HF circuit like your building for VHF or UHF, sometimes you encounter parasitic oscillations. If you design a VHF circuit like an HF circuit, most of the time, it simply won't work. You have to have a feel for the area your working in. I think this relys a lot on experience. LF, HF, VHF, UHF...ETC, are all very different worlds.
| Top |
Bob Masse
Post subject: Re: Best Capacitors? Posted: Apr Thu 12, 2012 2:10 am |
Which isnt saying very much. I use the Panasonic version when I want to get 1% or better tolerance. Carl[/quote]
Why would you need 1% tolerance caps in an old radio? All 1% means is that the cap will be within 1% of the value stated on the cap. Not necessary for most circuits in old radios.
| Top |
Alan Douglas
Post subject: Re: Best Capacitors? Posted: Apr Thu 12, 2012 2:19 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 23691 Location: Pocasset, Cape Cod, MA
If a circuit was designed to use an "inferior" distant ground, it may be unstable with a "better" one.
| Top |
Pbpix
Post subject: Re: Best Capacitors? Posted: Apr Thu 12, 2012 3:09 am |
| Member |
Alan Douglas wrote: If a circuit was designed to use an "inferior" distant ground, it may be unstable with a "better" one. C'mon Alan ... take a breath.. get real: No engineer worth his degree purposely designs a circuit with an inferior connection to any part of a circuit. .. c'mon guys stop trying to stretch a weak screwy point. We are dealing with AM radio here after all... so let's cut the silly ridiculous hair-splitting...lol For all intents and purposes.. the best ground... is the closest ground....
| Top |
Tubenut
Post subject: Re: Best Capacitors? Posted: Apr Thu 12, 2012 3:27 am |
Peter..... .....Alan
| Top |
Pbpix
Post subject: Re: Best Capacitors? Posted: Apr Thu 12, 2012 3:01 pm |
| Member |
Tubenut: What? ...You don't agree?
| Top |
Bruce Hagen
Post subject: Re: Best Capacitors? Posted: Apr Thu 12, 2012 3:22 pm |
Joined: Jun Thu 15, 2006 1:21 am Posts: 3813 Location: NE Ohio
RF is an art as well as a science. Ground points do matter especially as we go up infrequency. Otherwise why did Ford, Crown, Sherwood, and others call in a particular RF engineer to design certain products?
_________________ Bruce
| Top |
Burnt Fingers
Post subject: Re: Best Capacitors? Posted: Apr Thu 12, 2012 3:24 pm |
Seems like nobody agrees with you Peter. The ONLY way you will understand is to get some large pin 30's radios and see for yourself. Trying to show your ignorance by flaming others is a poor defense. Carl[/quote] Quote: Why would you need 1% tolerance caps in an old radio? All 1% means is that the cap will be within 1% of the value stated on the cap. Not necessary for most circuits in old radios. Where did I say I always use 1%? Its stricty on an as wanted basis. There are several communications sets that use very low frequency IF's and switichable selectivity using LC circuits. Going to even higher tolerance caps than new can make an amazing difference. Another uses a CT transformer product detector with 1000pf either side and 10K resistors. Going to 1% helps clean up a long known distortion problem. Tube type test equipment also can benefit from 1% tolerance if you care about accuracy and actually want to use and believe them. I also use that level of tolerance in other areas such as building audio filters. With some of todays components it only takes a very small sample of 5% to achieve 1%. Carl
| Top |
Pbpix
Post subject: Re: Best Capacitors? Posted: Apr Thu 12, 2012 10:50 pm |
| Member |
Burnt Fingers wrote: Seems like nobody agrees with you Peter.
The ONLY way you will understand is to get some large pin 30's radios and see for yourself. Trying to show your ignorance by flaming others is a poor defense. Carl OMG.. Carl... c'mon! Flaming?? ...lol What flaming? I invited you to simply show me the circuit that is designed for a more distant ground to work properly. Or that longer capacitor paths to ground are "better" for older radios. That's a simple technical request discussion statement... no "flaming" there. And what makes you think I only work with AA5 radios? Where did you get that from? I have many upon many dozens of restored "large pin 30's radios" ... and I've restored them ALL by choosing a shorter ground in every place a cap goes to ground.. And I assure you they play flawlessly. Put your technical-supporting facts-money on where your claims are! You should be able to demonstrate your point by simply producing a schematic that indicates more distant ground connects... and then shorten that ground and show how it failed... ok?That's just a plain and very simple technical request to demonstrate your claim. .. certainly no "flaming?" to that ..right? Or do you define "flaming" as any things you are questioned about? I mean no ill will... pure technical stuff here Carl. Simply show some schematic support.. ok? Don't get "huffy" .. just get technical... show the facts.. just the pure technical facts... No.. suppositions or loose claims or bench-talk -old tales... .. Just please explain the pure technical reasoning and show a schematic to make the demonstration valid....ok?
| Top |
Burnt Fingers
Post subject: Re: Best Capacitors? Posted: Apr Thu 12, 2012 11:30 pm |
Youre far from technical Peter, you repeat the word too much, and I seldom see a component layout in Riders. I do remember GE Fishmouths being particularly fussy and those are octals. I guess you never read old handbooks, QST, etc that stressed grounding for receiver stages.
How come you waited so long to claim youve done more than AA5's, I certainly cant remember you showing any? Just repainted plastic, etc AA5's. How about some chassis photos Peter?
I dont need any silly colors in your diatribes either, black is fine.
| Top |
Who is online |
Users browsing this forum: No registered users and 3 guests |
