It is currently May Fri 24, 2013 1:28 am
 Post subject: ballast tubes (see photo) Purpose? Why? How do they work?
PostPosted: Apr Wed 11, 2012 11:14 am
I don't understand the idea behind ballast tubes. I own three radios with ballast tubes. All three run very hot and have a unique smell that my non ballast tube radios don't have.
What was the purpose of the ballast tube? The one in the photo below does not appear to be a tube.[img]
[/img]
 Post subject: Re: ballast tubes (see photo) Purpose? Why? How do they wor
PostPosted: Apr Wed 11, 2012 11:34 am
In the most basic form, it's just a series resistor to give the right voltage to series-string tube filaments. The filament material has a higher resistance when cold---thus limiting the startup current surge.
They are called "tubes" because they are often put in tube-like enclosures. Are any ballasts under vacuum??---not sure.
"It's always something". --Gilda Radner
"100%" on E-Bay is not IQ......
PostPosted: Apr Wed 11, 2012 12:20 pm
Do they always emit a smell? Not offensive, but definitely a different odor than what is emitted by non ballast tube radios.
PostPosted: Apr Wed 11, 2012 12:30 pm
The dust that has collected inside will smell when heated. Plus any other foreign matter that is in there. Effectively, they are 'fancy' resistors.
Gene
'The only thing constant is change'.
Member: TCA
PostPosted: Apr Wed 11, 2012 1:17 pm
How about if I need to replace a ballast tube? Are they the same or is each radio receiver serviced by a ballast tube with a specific resistance level?
Thank you, fellow ARF members.
PostPosted: Apr Wed 11, 2012 1:53 pm
I am working on an older set that used 3 6v and 2 25v tubes(300 ma) and a ballast tube that was burned out. I have replaced the ballast tube with 6.5 mfd mylar cap and a 50 ohm resistor for the dial light. This reduces the heat and should be more reliable.
PostPosted: Apr Wed 11, 2012 4:33 pm
Interesting!
PostPosted: Apr Wed 11, 2012 4:39 pm
Hi
Sometimes we post this. It explains ways to get around the hot ballast tube/resistor.
http://www.vintage-radio.com/repair-res ... calcs.html
PostPosted: Apr Wed 11, 2012 10:19 pm
A very interesting web site that I have placed in "my favorites."
Post New Topic Post Reply  [ 9 posts ]  Moderator: Peter Bertini
