It is currently Jun Wed 19, 2013 1:53 am
 Post subject: Admiral 6C 23A
PostPosted: Apr Wed 11, 2012 9:45 pm
Any advice on my problem with this Admiral radio. I turned it on and it played for several minutes and then stopped . Three of the tubes on the right I can see are on. I can't tell about the others. Any help would be appreciated. I am a novice so make it simple. Ha!
 Post subject: Re: Admiral 6C 23A
PostPosted: Apr Wed 11, 2012 10:11 pm
Before applying power, did you do any of the normal restoration things, like replacing capacitors and testing tubes for shorts?
PostPosted: Apr Wed 11, 2012 11:14 pm
Hi
Since you see 3 tubes the rest will also be lit. Tubes are wired in series so if one goes out none will light.
Here is the schematic:
http://www.nostalgiaair.org/PagesByMode ... 000136.pdf
Agree with Johnnysan. Especially caps C15A and B. (70 mf @ 150 volts and 30 mf @ 150 volts.)
PostPosted: Apr Wed 11, 2012 11:45 pm
Thanks for all the help. Great to have very knowledgeable radio guys around. will post if I get it going.
Post New Topic Post Reply  [ 4 posts ]  Moderator: Peter Bertini
