It is currently May Fri 24, 2013 4:29 pm
 Post subject: National Electronics NL-770L
PostPosted: Apr Thu 12, 2012 4:34 am
I have a National Electronics NL-770L NOS tube. Can anyone tell me what this tube was for? It is quite large and instead of having pins, it has 'u' shaped connectors.
 Post subject: Re: National Electronics NL-770L
PostPosted: Apr Thu 12, 2012 6:19 am
I think you have an obsolete gas thyratron.
http://www.rell.com/products/Electron-T ... ml?q=nl770
These were used in motor controls before the days of thyristors.
PostPosted: Apr Sat 14, 2012 4:21 am
Great! What do I do with it?
PostPosted: Apr Sat 14, 2012 6:11 pm
Make a desk lamp out of it?
It would make a really nifty light dimmer, but would be rather large.
Sell it in the Radio Classifed section?
Not much practical use for something like this today.
PostPosted: Apr Sat 14, 2012 7:55 pm
2.5V 25A filament ! That's 63W ! 0.1ohm, hot !
Unless you've got a boat anchor of 2.5V transformer lying around, a desk lamp ain't gonna happen. Then again, if you got an old unused PC sitting in a back corner, you might be able to light it up. If it has an ATX type supply, you might be able to open it up and tweak the 3.3V supply down to 2.5V. A 0.032 ohm 50W series resistor is an alternative to tweaking the supply. PCs suck serious juice. 30A or more, available on the 3.3V rail, is normal.
Easiest solution is just to sell it. Don't know the demand on this particular tube. If you had one of its cousins, an ignitron, then you'd have something. A lot of metal shops around here still use spot welders, with those in them.
If the women don't find you handsome, they should at least find you handy ! - Red Green
PostPosted: Apr Sat 14, 2012 11:15 pm
I meant using it as a base for a standard 120VAC bulb. I have seen lamps made from big transmitting tubes, but it would be a shame to let the gas out of this one (argon, hydrogen?) to drill it for a lamp stand.
rich
Post New Topic Post Reply  [ 6 posts ]  Moderator: Peter Bertini
Users browsing this forum: codefox, Lou deGonzague, rondoc and 0 guests
