It is currently Jun Tue 18, 2013 7:06 am
 Post subject: 1930's electrolytic question
PostPosted: Apr Fri 13, 2012 1:36 am
Okay I want to replace the electrolytics in my 1936 Silvertone 1970 console. It has the kind that look like tall, narrow cans (one of them has a cardboard sleeve over it) that sit on top of the chassis, and fasten on from underneath with a big nut. There is a smaller nut that threads on to a stud on the center bottom of each capacitor, holding a solder lug in place. What is the positive and what is the negative on this kind of capacitor?
 Post subject: Re: 1930's electrolytic question
PostPosted: Apr Fri 13, 2012 1:39 am
Hi
Smaller nut in center is positive. Large nut negative. You might have wet electrolytics? Once removed shake them, you may hear liquid inside.
PostPosted: Apr Fri 13, 2012 2:58 am
Some folks stuff the wet electrolytic. Others, remove the positive connection and install a tie strip to mount a modern electrolytic. Thus keeping the chassis looking the same and not exposing a large hole...
Be aware that sometimes the negative body of the electrolytic can be insulated with fiber washers and will not be at the same potential as the chassis. A replacement capacitor must be connected the same way.
"Don't find fault, find a remedy"
PostPosted: Apr Fri 13, 2012 4:08 am
Those are the kind that often have cardboard sleeves on them! Investigate closely...
--Bob
PostPosted: Apr Fri 13, 2012 4:22 am
Well, there is enough room under the chassis that I plan to simply disconnect the old caps and install a pair of 10uF, 450 volters under the chassis, leaving the old cans in place for appearance.
PostPosted: Apr Fri 13, 2012 7:25 am
If the old ones are still wet, they will eventually leak and corrode everything. Best take them apart and stuff them. Don't know if there is a safe way to drain 'em and leave in place for appearance.
PostPosted: Apr Sat 14, 2012 12:37 am
I thought the electrolyte was pretty innocuous in those caps.
Dave Wise
Post New Topic Post Reply  [ 7 posts ]  Moderator: Peter Bertini
Users browsing this forum: BobWeaver and 0 guests
