It is currently May Tue 21, 2013 2:42 pm
 Post subject: 1KHz to 33MHz Adjustable Oscillator Module Board
PostPosted: Apr Thu 12, 2012 2:01 am
Looks like this would be perfect for the AM transmitters.
http://www.ebay.com/itm/1KHz-33MHz-Adju ... 4714wt_982
 Post subject: Re: 1KHz to 33MHz Adjustable Oscillator Module Board
PostPosted: Apr Thu 12, 2012 2:21 am
Dave Doughty got one and ran some tests with it in the "Simple VFO for AM Transmitters" thread here
http://www.antiqueradios.com/forums/viewtopic.php?f=12&t=188261
PostPosted: Apr Thu 12, 2012 4:40 am
That one is different.
PostPosted: Apr Thu 12, 2012 6:09 am
It's not only the same one but he got it from the same Ebay store, electronics-salon.
PostPosted: Apr Thu 12, 2012 12:46 pm
Yeah - that's the same one I bought but Dave's cost $1.00 less. I think the confusion is because my thread started out experimenting with an ancient XR2206 chip but then went OT and discussed this module which definitely seems like an improvement.
PostPosted: Apr Thu 12, 2012 6:34 pm
Hi Dave. I see you mention the XR2206's drift in the other thread. What kind of drift did you encounter with the LTC1799? I see their quite cheap at digikey.
PostPosted: Apr Thu 12, 2012 11:41 pm
It was more like instability due to the adjustment pots rather than drift. It was hard to set an exact frequency but I think with a fixed resistor and a lower value fine tuning pot, it would be fairly stable. When I was finally able to zero beat a broadcast station, it stayed within about 50 Hz.
PostPosted: Apr Fri 13, 2012 3:34 am
Ok Dave. 50Hz isn't bad... I have 5 on order from digikey. I will do a little experimenting. Thanks for the info.
PostPosted: Apr Fri 13, 2012 3:12 pm
TubeNut:
If you have a good SA, I'd be curious what the phase noise/jitter looks like in the HF region.
Circuit looks like a RC oscillator with a divider chain.
Pete
A long journey always begins with the words, "I think I know a shortcut."
PostPosted: Apr Fri 13, 2012 4:37 pm
BTW, anyone have a link to Norm Leal's single tube "part 15" single tube AM transmitter??
I'd be willing to try one of these as a replacement for the fixed frequency crystal osc.
assembly he used in the original design.
Pete
PostPosted: Apr Fri 13, 2012 4:46 pm
Here ya go Pete, Norm's classic...
http://antiqueradios.com/forums/viewtopic.php?t=63310
PostPosted: Apr Fri 13, 2012 6:02 pm
Great! I will order a few of those modules today. By any chance do you have a link to to Norm's
12k5 space charge receiver project?
Pete
PostPosted: Apr Fri 13, 2012 8:15 pm
Here ya go Pete..
viewtopic.php?t=80109
PostPosted: Apr Fri 13, 2012 9:06 pm
Im purdy sure, without any filtering network on the output, the signal is probably full of harmonics. There is a divider inside too. I will fool with it when I get some time and let you guys know.
PostPosted: Apr Fri 13, 2012 10:02 pm
Perhaps a low-pass filter on the grid input would be the thing to do.
I just experimented with replacing the crystal on my 5-watt LPB college transmitter. It worked well and the output was a sine wave. But it uses a 6AL11 compactron where the pentode section was the oscillator and the power pentode section has a tuned output stage.
