Page 1 of 1
[ 8 posts ] |
| Author |
al puggy
Post subject: Circuit board question Posted: Apr Tue 17, 2012 12:59 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 558 Location: new hyde park ny usa
Hi all.....When replacing caps or transistors on a circuit board, and the solder joint is gone......besides hard wiring from point to point...Is there a way to repair the joint? thanks AL
| Top |
tubeAMP
Post subject: Re: Circuit board question Posted: Apr Tue 17, 2012 1:27 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2756 Location: Gainesville, Florida
the solder trace is gone or the pad is gone ? a piece of wire could replace a trace. solder adheres to existing trace if clean. the tiny pad can be replaced by solder. you can do a lot with just the solder
_________________ CAUTION: Im no expert
| Top |
majoco
Post subject: Re: Circuit board question Posted: Apr Tue 17, 2012 1:30 am |
| Member |
Joined: Mar Mon 17, 2008 5:05 am Posts: 3277 Location: Palmerston North, New Zealand
What do you mean - gone? Do you mean the glue has separated the copper track from the board and the 'eyelet' has then broken off?
I would poke the lead of the new component through the hole then bend it to where you can solder it on to the remaining track. If it's quite a distance then cover the lead with a bit of sleeve and maybe a drop of glue to give some mechanical support to the component on the other side. Professional boards often have a dab of white silicon sealant (non-acidic) under larger components to prevent movement.
The usual cause of the track separating is overheating - especially if using solderwick to remove the excess solder - or pushing down on the component while it is still soldered on the other side.
_________________ Cheers - Marty ZL2MC
| Top |
al puggy
Post subject: Re: Circuit board question Posted: Apr Tue 17, 2012 1:40 am |
Yes the eyelet is gone. Your right, it was caused by pulling the component through the hole...after using solder wick...I traced board, and hardwired that connection of a switching transformer to its connections...thanks AL
| Top |
Rich, W3HWJ
Post subject: Re: Circuit board question Posted: Apr Tue 17, 2012 1:49 am |
Joined: May Tue 30, 2006 4:46 pm Posts: 4812 Location: Santa Rosa, CA
| Top |
Radiosmoker
Post subject: Re: Circuit board question Posted: Apr Tue 17, 2012 5:52 am |
| Member |
Joined: Oct Thu 18, 2007 11:34 am Posts: 2596 Location: Pacific Northwest ;)
If you want to replace a damaged trace, you can use some #22 gage solid copper wire(depending on the size of the trace of course), flatten it out and overlay the trace. solder it over and drill a hole where the pad was then insert a wire or component lead and solder. Then lay a bead of epoxy over the repair.
_________________ Me repair, Smoking radios. Visit our Webpage: http://antique-radio-lab.forumotion.com/
| Top |
tubeAMP
Post subject: Re: Circuit board question Posted: Apr Wed 18, 2012 3:36 pm |
eyelets do come off sometimes for me as well. I make sure that the solder extends past the the component lead onto the trace dragging the solder with the iron. works for me
| Top |
al puggy
Post subject: Re: Circuit board question Posted: Apr Wed 18, 2012 6:39 pm |
Thanks to all...very helpful! AL
| Top |
Users browsing this forum: No registered users and 1 guest |
