It is currently May Sat 18, 2013 10:53 pm
Post New Topic Post Reply  [ 49 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Best Capacitors?
PostPosted: Apr Mon 16, 2012 7:45 pm
Can someone explain why there is a difference in mounting a capacitor in a vertical versus horizontal orientation? Beginning minds want to know?
PostPosted: Apr Mon 16, 2012 8:30 pm
If you are speaking of the common type that would be used in radio/TV sets there is no requirement as to horizontally or vertical positioning.
Bruce
PostPosted: Apr Tue 17, 2012 12:20 am
In the old days of point to point wiring, they were all axial-lead (horizontal mounting), save for the multi-capacitance units that mounted on top of the chassis.
PCB construction caused radial (vertical mounting) single value caps to become the majority style.
Any electronic component can be mounted in any position (unless there is a unique item or two from the twenties I'm not aware of).
PostPosted: Apr Tue 17, 2012 12:32 am
Tubes ( not a component per se) do have orientation specs in the tube manual
PostPosted: Apr Tue 17, 2012 1:18 am
Code:
Only some tubes. It depends often on construction and filament style. Some can be mounted base up or down, others with filament pins aligned so the filaments are in the the vertical plane, and most miniature and octal/Loktal tubes it doesnt matter.
PostPosted: Apr Tue 17, 2012 1:58 am
Thh
Anks
PostPosted: Apr Tue 17, 2012 1:59 am
PostPosted: Apr Tue 17, 2012 2:05 am
Burnt Fingers wrote:
...........It depends often on construction and filament style. Some can be mounted base up or down, others with filament pins aligned so the filaments are in the the vertical plane........ Carl
Which is why you should look in a tube manual before you tilt a chassis over on it's side. You may get a surprise if a filament sags the wrong way.
RRM
PostPosted: Apr Tue 17, 2012 2:15 am
I stand corrected then, AFA certain tubes, lol. When I posted, I was thinking about the numerous portable tube sets having the chassis attached at the top of the cabinet, with the tubes mounted to it, upside down.
Post New Topic Post Reply  [ 49 posts ]  Moderator: Peter Bertini Go to page Previous  1, 2, 3
Users browsing this forum: BobWeaver, Chris108, radiotechnician and 2 guests
