Page 1 of 1
[ 13 posts ] |
| Author |
murf
Post subject: philco 38-116 resistors Posted: Apr Tue 17, 2012 3:33 am |
Joined: Jan Wed 11, 2012 4:21 pm Posts: 120 Location: Elko, MN.55020
Hi Guy's, Checking and replacing some resistors on my 116 and found that one of the wire wound resisters is checking out of tolerance. Should be 14,000,checks about 9.5k. Don't know what watt this resistor is.Not specified in the parts list. Looked at antique electric supply and they have either 5 watt or 10 watt. But they don't list a 14k ohm. What combination of resistors would I need to get to come up with 14k? And what watt would I want. THis is listed on the parts list as schematic number 79. Could this out of tolerance resistor be causing my floating volume problem I am noticing?Seems to drift up, then down. Thanks for the help guy's. I learn a little more everyday. murf
| Top |
glasdave
Post subject: Re: philco 38-116 resistors Posted: Apr Tue 17, 2012 4:06 am |
| Member |
Joined: Feb Tue 24, 2009 8:20 am Posts: 7727 Location: Aurora Colorado
Hi, murf, when I need odd resistors, I go here, http://www.surplussales.com/sitemap2/Rlist.html, lots of variety, and fairly fast shipping. They do have a 10.00 minumum, but I always order a few of the values I see fairly often, or will have in a set coming up.
_________________ I move the world just one step on...
| Top |
Norm Leal
Post subject: Re: philco 38-116 resistors Posted: Apr Tue 17, 2012 1:32 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 28941 Location: Livermore, CA
Hi Murf R79, 14K wire wound, is in parallel with R78. Are you sure you aren't reading combination of both? Unusual for wire wound resistors to change value. Also this resistor may have been selected and changed at the factory? Unusual to see two different values paralled in a radio. http://www.nostalgiaair.org/PagesByMode ... 013234.pdf
_________________ Norm
| Top |
Tube Radio
Post subject: Re: philco 38-116 resistors Posted: Apr Tue 17, 2012 1:57 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 7846 Location: Warner Robins, GA
If you need this resistor try mouser electronics.
if R78 is a 70K resistor with R79 being as 14K resistor the combined resistance should be 11.7K.
| Top |
murf
Post subject: Re: philco 38-116 resistors Posted: Apr Tue 17, 2012 3:07 pm |
I am only seeing the 79 wirewound resistor.Has 2 solder terminals. Do not see 78 in parallel. When checking 78 I am reading 9.5-10.0. Still don't have a clue what watt resistor this would be. Thanks murf
| Top |
Dale Saukerson
Post subject: Re: philco 38-116 resistors Posted: Apr Wed 18, 2012 1:32 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 6181 Location: Minneapolis, MN USA
As noted by Norm, unusual for radio schematic to show parallel resistors. Wattage needed depends upon actual resistance value expected in that location.
Parallel resistors means voltage across them is identical and dissipation for each is a ratio of their Ohmic values.
# 79 is 1/5 the Ohmic value of # 78. # 79 would be subject to 5 times the wattage dissipation of # 78
# 78 is rated 1 Watt # 79 would see a max of 5 Watts A single resistor instead of two parallel would see a max of 6 watts.
Order a ten Watt resistor. But you still need to determine which Ohmic value is correct.
| Top |
Dale Saukerson
Post subject: Re: philco 38-116 resistors Posted: Apr Wed 18, 2012 3:17 am |
| Top |
Peter Bertini
Post subject: Re: philco 38-116 resistors Posted: Apr Wed 18, 2012 5:06 am |
| Moderator |
Joined: Jan Thu 01, 1970 1:00 am Posts: 12202 Location: Somers, CT
murf wrote: I am only seeing the 79 wirewound resistor.Has 2 solder terminals. Do not see 78 in parallel. When checking 78 I am reading 9.5-10.0. Still don't have a clue what watt resistor this would be. Thanks murf Did you remove the wires from the terminals when checking the resistance? That would be the first step that I'd try. Also, there were two revision codes for that chassis, 121 and 125. That might explain the differences in wiring you are seeing??? Pete
_________________ A long journey always begins with the words, "I think I know a shortcut."
| Top |
Trent
Post subject: Re: philco 38-116 resistors Posted: Apr Wed 18, 2012 6:55 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 622 Location: Kenosha, WI, US
Quote: Do not see 78 in parallel. When checking 78 I am reading 9.5-10.0. Yes, they're reading the same because they're in parallel as others have mentioned. If you remove one leg of 78 and then remeasure each, you'll find what their true values are.
_________________ Trent Nicol
| Top |
SteveJB
Post subject: Re: philco 38-116 resistors Posted: Apr Thu 19, 2012 12:17 am |
Joined: Apr Sun 05, 2009 2:48 pm Posts: 339 Location: New Jersey
I just started working on my 38-116 code 125 and noticed that several of the carbon resistors are swollen in the middle. Is the first time I have seen this. Is it a flaw in the resistors manufacture or sign of an electrical problem that occurred at some point?
I will be replacing them anyway, but I am curious.
Steve
| Top |
murf
Post subject: Re: philco 38-116 resistors Posted: Apr Thu 19, 2012 3:58 am |
Trent wrote: Quote: Do not see 78 in parallel. When checking 78 I am reading 9.5-10.0. Yes, they're reading the same because they're in parallel as others have mentioned. If you remove one leg of 78 and then remeasure each, you'll find what their true values are. Hi guy,s I must have had a brain fart going on when I wrote the previos 1 or 2 posts. I kept refering to checking the R78. All I have is the R79(14k wirewound). Do not have the R78 in my 121 code radio chassis. The R79 checks 10k un-soldered. I think that covers it. I will have to do a little research and see if that could have been changed by Philco. HAve a great evening guy's murf
| Top |
Tube Radio
Post subject: Re: philco 38-116 resistors Posted: Apr Thu 19, 2012 4:06 am |
| Member |
Maybe they changed to a single resistor of the proper value.
| Top |
Usually Lurking
Post subject: Re: philco 38-116 resistors Posted: Apr Thu 19, 2012 4:43 am |
Joined: Jan Tue 16, 2007 7:02 am Posts: 626 Location: Lexington, KY USA
murf,
10k sounds pretty close to the correct value.
You might put everything back and check voltages.
Measure the voltage at each end of the suspect resistor while you wait for the problem to occur. Does either voltage change then?
Ted
| Top |
