| Author |
ensignoftheunit
Post subject: What is Push-Pull? Posted: Apr Wed 18, 2012 1:15 pm |
I'm fairly new to the hobby; I have a 50s Magnavox console and another Magnavox tube tabletop. I'm looking to aquire a nice pre-war table top set and I keep seeing the term push-pull in regards to the amp.
What's the audio difference between a push-pull amp vs a single ended amp? Was the P-P standard on radio models during the 30s, or only found on higher end models?
| Top |
Indiana Radios
Post subject: Re: What is Push-Pull? Posted: Apr Wed 18, 2012 2:13 pm |
| Member |
Joined: Sep Thu 14, 2006 3:27 pm Posts: 3511 Location: Carmel, Indiana
| Top |
ggregg
Post subject: Re: What is Push-Pull? Posted: Apr Wed 18, 2012 2:17 pm |
Joined: Aug Sun 01, 2010 1:12 am Posts: 5214 Location: Minnesota
In a regular circuit with one output tube, the tube amplifies the entire waveform. In push pull, one tube amplifies the top half of the waveform while another amplifies the bottom half. It's important that the tubes are biased equally and are a close match to each other. Push pull, because it uses an extra tube, wasn't used in bottom end sets but can be found in many others. Some record players with only three tubes had two as push pull outputs. Some table radios are also push pull output.
EDIT, Micheal beat me to it but I already had it typed out so I added it anyway.
| Top |
TA Forbes
Post subject: Re: What is Push-Pull? Posted: Apr Wed 18, 2012 3:36 pm |
Joined: Jan Wed 26, 2011 5:42 am Posts: 480 Location: Clayton, NC
Speaking of bottom-end sets with push-pull outputs, I recently acquired a small two band, three-knob, six tube Silvertone model 7144 (1936). The dial is the round "gold dial" variety that came just before the "green dial" sets. Controls are: band switch, on/off/volume, and station select. There is no tone control. Tube line-up is 6A7, 6D6, 75, 42, 42, 80. The SW band is 5.5-15 MHz. An odd but interesting set!
| Top |
pixellany
Post subject: Re: What is Push-Pull? Posted: Apr Wed 18, 2012 4:23 pm |
Joined: Jul Mon 26, 2010 8:30 pm Posts: 5365 Location: Annapolis, MD
bottom end with Push-Pull: http://www.radiomuseum.org/r/eca_132.htmlPush-Pull 25L6s driven by a 6SL7 driver/inverter AND--it has TWO 25Z6 rectifiers
_________________ "It's always something". --Gilda Radner "100%" on E-Bay is not IQ......
| Top |
Peter Bertini
Post subject: Re: What is Push-Pull? Posted: Apr Wed 18, 2012 4:59 pm |
| Moderator |
Joined: Jan Thu 01, 1970 1:00 am Posts: 12197 Location: Somers, CT
I'd like to add that push-pull can be run in Class A as well, were both tubes are in conduction over the full AC cycle. Philco and others used Class A push-pull amps in their higher end table and console sets.
Pete
_________________ A long journey always begins with the words, "I think I know a shortcut."
| Top |
azenithnut
Post subject: Re: What is Push-Pull? Posted: Apr Wed 18, 2012 5:01 pm |
| Member |
Joined: Jan Mon 18, 2010 2:13 am Posts: 4361 Location: Dayton Ohio
ggregg wrote: In a regular circuit with one output tube, the tube amplifies the entire waveform. In push pull, one tube amplifies the top half of the waveform while another amplifies the bottom half. It's important that the tubes are biased equally and are a close match to each other. Push pull, because it uses an extra tube, wasn't used in bottom end sets but can be found in many others. Some record players with only three tubes had two as push pull outputs. Some table radios are also push pull output.
EDIT, Micheal beat me to it but I already had it typed out so I added it anyway. This is true for Class B Push-Pull output circuits, but most radios use Class A where both tubes handle the entire waveform. Class B (As well as the similar Class AB) is more efficient and allows more power handling for the same tubes than Class A Either way, not only do you get greater power handling, the push pull circuits automatically cancel second harmonic distortion. Another benefit, with a center tapped audio output transformer, the DC current going to each tube is equal and opposite, therefore the DC magnetic fields cancel. This keeps the core from being saturated and gains better fidelity. Single-ended output transformers have an air gap and usually have bigger cores to reduce this issue. Still, the core can saturate reducing its effectiveness on transferring the audio energy. -Steve
_________________ Radio Interests -Zenith -Sparton -Pre-War FM Consoles and floor models, the bigger, the better!
| Top |
panther
Post subject: Re: What is Push-Pull? Posted: Apr Wed 18, 2012 5:54 pm |
People, please he said he was NEW to electronics. You are giving him explanations for someone with a very detailed knowledge of electronics theory. KISS. Top/bottom half of the waveform, tubes are biased, the core can saturate, conduction over the full AC cycle, close matched, air gap, class A, class B, class A/B????? Are these terms the best way to explain a paper clip to an alien ? Just explain it in simple terms rather, then try to impress the rest of the group. Really guys you are looking at the question through 20 to 30 years of practical experience. This poor guy is new and probably looking into a tube radio for the first time and doesn't even know what all the parts are yet. Dan
| Top |
azenithnut
Post subject: Re: What is Push-Pull? Posted: Apr Wed 18, 2012 6:02 pm |
| Member |
Ok, Two tubes in the output stage instead of one?
Ok, that doesn't explain parallel...
More power?
That doesn't seem to describe much either.
Oh skip it... I get walked on anytime I try to answer technical questions so I'll stop doing so.
This is why I stay out of the Electrical/Mechanical Restoration forum...
| Top |
Peter Bertini
Post subject: Re: What is Push-Pull? Posted: Apr Wed 18, 2012 6:18 pm |
| Moderator |
Explanations shoud be technically accurate.
But, if it helps... the two tubes work by opposing each other. While one tube is going in one direction, the other tube is going in the other. In effect, one tube is pulling more current, while the other is pullling proportionally less current. Whether a tube is pushing or pulling depends on the polarity of the input signal at that instant. How much they are pushing or pulling depends on the signal level.
The tubes are sharing the work, but they are 180 degrees out of step with each other.
| Top |
ensignoftheunit
Post subject: Re: What is Push-Pull? Posted: Apr Wed 18, 2012 6:22 pm |
Peter Bertini wrote: Explanations shoud be technically accurate.
But, if it helps... the two tubes work by opposing each other. While one tube is going in one direction, the other tube is going in the other. In effect, one tube is pulling more current, while the is pullling proportionally less current. Whether a tube is pushing or pulling depends on the polarity of the input signal at that instant. How much they are pushing or pulling depends on the signal level.
The tubes are sharing the work, but they are 180 degrees out of step with each other. So how does this relate to fidelity? I mean whats the benefit that makes it desirable? Louder music, or clearer music?
| Top |
Peter Bertini
Post subject: Re: What is Push-Pull? Posted: Apr Wed 18, 2012 6:27 pm |
| Moderator |
ensignoftheunit wrote: Peter Bertini wrote: Explanations shoud be technically accurate.
The tubes are sharing the work, but they are 180 degrees out of step with each other. So how does this relate to fidelity? I mean whats the benefit that makes it desirable? Louder music, or clearer music? Two tubes doing twice the work means twice the power. As Azenithut mentioned push-pull inherently cancels even order harmonics when they are combined at the output. So, it should sound cleaner. Also, the requirements for the output transformer are lessened in Class A as was mentioned by Azenithnut due to the cancellatiion of the DC magnetic field in the primary winding. Pete
| Top |
Indiana Radios
Post subject: Re: What is Push-Pull? Posted: Apr Thu 19, 2012 12:21 am |
| Member |
Let me see how simple I can explain it.
Class A (Single Tube)...Single tube does all the work, low wattage output, power hog especially when the tube is sitting idle, cheap to build.
Class B (Two Complementary Tubes)...Each tube does half the work, high wattage output, power efficient especially when the tubes are at idle, more costly to build.
Hopefully I've got the facts right on this otherwise I'm sure someone will correct me.
_________________ Michael Feldt
www.indianaradios.com
| Top |
dberman51
Post subject: Re: What is Push-Pull? Posted: Apr Thu 19, 2012 12:37 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2307 Location: Boston, MA USA
No, that's not right. Class B *requires* push-pull using two tubes but most push-pull output circuits in home radios and phonographs use Class A or AB, as was posted previously. The advantage is much lower distortion, that is why all true high-fidelity amplifiers run push-pull outputs.
Class B is usually used when the maximum in efficiency is required, such as the modulator section of a high-power AM transmitter. Class B can result in *higher* distortion (crossover distortion) than even Class A single-ended outputs.
Class A is least efficient, Class B more efficient, Class AB in the middle. Class C is most efficient but it applicable only for RF circuits, not audio.
-David
| Top |
Nick D.
Post subject: Re: What is Push-Pull? Posted: Apr Thu 19, 2012 2:01 am |
| Member |
Joined: Jun Wed 01, 2011 9:05 am Posts: 6729 Location: "Amish Country", PA
Ugh.... You guys need to explain in layman's terms, not 'simpler' terms. I'll try to think of something.
_________________ Majestic - Crosley - Zenith ~CONSOLE FREAK~ Philco - American Bosch - RCA
| Top |
panther
Post subject: Re: What is Push-Pull? Posted: Apr Thu 19, 2012 2:42 am |
This is very typical of seasoned hobbyists trying to help newbies. They have problem relating in lay terms. Dan
| Top |
dberman51
Post subject: Re: What is Push-Pull? Posted: Apr Thu 19, 2012 3:45 am |
I try not to talk down to people. Boiled down to essence, the comparison might be something like:
"Push-pull sounds better than the alternative "single-ended" amplifier output. It has both lower distortion for cleaner, more natural sound, as well as more power for loudness. But it costs more (uses more tubes or transistors), so it was used in higher-end models of radios and phonographs. Push-pull amplification is one of the foundations of hi-fi."
Better?
-David
| Top |
Eickerman
Post subject: Re: What is Push-Pull? Posted: Apr Thu 19, 2012 4:03 am |
| Member |
No analogy is perfect...
"Push Pull" is pedaling a bicycle with both feet. You get pretty smooth forward motion and lots of power.
"Single Ended" is pedaling a bicycle with one foot. You still move forward, it can be an acceptable answer, but it's not as smooth and maybe half the power.
Curtis Eickerman
_________________ http://curtiseickerman.weebly.com
| Top |
Nelson in Winnipeg
Post subject: Re: What is Push-Pull? Posted: Apr Thu 19, 2012 6:48 am |
Joined: Feb Fri 05, 2010 6:14 am Posts: 907 Location: Winnipeg, Canada
Analogy: Two guys on a crosscut saw. One's pushing while the other's pulling. They'll get through a log twice as fast. (Probably more class AB in practice... you can't really push a crosscut very well.) -well, I tried.  Nelson
_________________ "Never get between electricity and where it wants to go." -Red Green
| Top |
Ken G
Post subject: Re: What is Push-Pull? Posted: Apr Thu 19, 2012 9:00 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 14568 Location: ID 83301
Skip all that . It is something you do when trying to get a console radio into a small car .
| Top |
