It is currently May Thu 23, 2013 11:36 pm
 Post subject: Ever gotten so mad that you destroyed cast iron?
PostPosted: Apr Tue 17, 2012 6:33 pm
I just did...
 Post subject: Re: Ever gotten so mad that you destroyed cast iron?
PostPosted: Apr Tue 17, 2012 6:54 pm
I did that once.
PostPosted: Apr Tue 17, 2012 7:37 pm
Nick D. wrote:
I just did...
You shouldn't bang yopur head against a wall, son. :wink:
Then, who else has ast iron walls... :twisted:
PostPosted: Apr Tue 17, 2012 8:44 pm
I finished beating an old cast iron boiler to pieces with a sledge a couple of weeks ago. Felt great and relieved a lot of tension!
PM me for my email address
PostPosted: Apr Tue 17, 2012 8:50 pm
i wasn't mad but i've broke up a lot of cast iron sewer pipes to get them out of the way.i've also cut a lot of them off with my cast cutter and tied new pvc onto them.i didn't think it was much fun but it paid well.butch
PostPosted: Apr Tue 17, 2012 9:10 pm
Yes.
Nick
Nick
Life without music would be a mistake-Nietzsche
I am not accountable for any damage this causes
PostPosted: Apr Tue 17, 2012 11:03 pm
I've broken quite a few cast iron tubs. It's much easier than trying to remove them in one piece.
Bryan at Spacekat Designs, Unique Musical Instruments
~Will work for parts~
PostPosted: Apr Wed 18, 2012 8:03 pm
Never broke cast iron, but did cut into cast iron sewer pipe with a grinder to repair it. Had to cut a section of it out that had split down the middle, and section it back in with PVC.. No clue how it got split down the center, but it had to be fixed before the bathroom could be used. It wasnt very easy cutting it out either.
BEN K. Always enjoying the sound of a tube radio warming up... and i say phooey on solid state! LOL
PostPosted: Apr Wed 18, 2012 8:10 pm
I have broken the mounting lugs on flange mount motors and pumps because I was too
lazy to deal with the gland seal properly, and hoped more tightening would stop leaks.
de
VE7ASO VE7ZSO
Steve Dow
ve7aso@rac.ca
PostPosted: Apr Wed 18, 2012 8:23 pm
Have sawzalled cast iron sewer pipe, and have beat the living daylights out of stuck iron pipe fittings with a BFH while heating with a torch until they busted into smitheens. That's about all my cast iron adventures.
Reece
PostPosted: Apr Wed 18, 2012 8:47 pm
When I was maybe 7 or 8 years old I had a great toy John Deere combine; not cast iron, I guess they're cast pot metal? Anyway, frustrated by how the head didn't rotate like it was supposed to I threw it on the ground and it broke off. I have thought about that many, many times and that lesson has helped me keep my temper.
PostPosted: Apr Wed 18, 2012 10:39 pm
Stomped on a really nice Zenith clock radio one Christmas eve. Had an RF stage, 6BJ6, too, dammit... :oops:
Not cast iron. At least cast iron has scrap value, but not busted up plastic radios.
"There Is Nothing Finer Than A Stromberg-Carlson"
PostPosted: Apr Thu 19, 2012 12:37 am
wrnewton wrote:
Have sawzalled cast iron sewer pipe, and have beat the living daylights out of stuck iron pipe fittings with a BFH ...
Same here, under a house, on my side, in the summer, with little light, with a 6oz ball pein. Actually the 6oz hammer is better than a sledge hammer or single jack under a house because it's shock/impact rather than brute force that's needed on a pipe held firmly in place. After my helper tried with a 16oz ripping hammer for 15 minutes, we bet lunch. I had the hub broken on 4" C.I. in 3 swings. He absorbed all my practical demonstrations and later became my partner in a plumbing company.
PostPosted: Apr Thu 19, 2012 7:55 pm
i have used a sawzall on cast iron pipe but if its the heavy wall type you will use a lot of blades unless you use the carbide grit blades which take forever.i bought a cutter which has a heavy chain with cutting wheels every inch or so.this wraps around the pipe and when tightened snaps it off in a circle.it also works good on the clay tile pipe.butch
PostPosted: Apr Thu 19, 2012 8:43 pm
You need to work on that Nick............... All that stress and hostility will lead to early heart disease...............
JG Jackson
"Uva Uvam Videndo Varia Fit"
Users browsing this forum: blacksmith, Ed Engelken, fifties, Flinx, FrankB, PICTUREROLL, terry h, WB8WZK and 7 guests
