It is currently Jun Wed 19, 2013 12:19 pm
 Post subject: GE TC-2 tube tester need schematic!
PostPosted: Apr Mon 16, 2012 3:36 am
Hi, Just spent a while browsing and can't find a schematic or data for a GE TC-2 (NOT Heathkit) Tube tester. Seems to work OK except for the line adjust being off.
If I adjust the line adjustment to give me the correct filament voltage the unit seems to work fine but line adjust meter reads around 34% vice 50%. I'm thinking it's a resistor that changed value. The unit does use a 171A tube for the rectifier. Will try a known good one and see if that helps. A schematic would be greatly appreciated! :!:
COrby
 Post subject: Re: GE TC-2 tube tester need schematic!
PostPosted: Apr Fri 20, 2012 4:05 pm
Send me your email and I'll send it to you.
Bob
PostPosted: Apr Fri 20, 2012 5:25 pm
I think you're right about the resistor.
I believe you can check the 71A in the tester, as it's only used for leakage and line-adjust, not for the emission measurement.
PostPosted: Apr Wed 25, 2012 12:07 am
Got it working! Looks and works great. Can't test modern tubes but I tested a pile of 4/5/6 pin while testing it. Main problem was resistors drifted. I did replace the 171A with a 1N4007.
I still would like a copy of the manual. The TC-3 manual I was sent helped me troubleshoot but is quite a bit different.
Corby
Users browsing this forum: Exabot [Bot] and 3 guests
