It is currently May Thu 23, 2013 9:49 am
 Post subject: Finished my first cabinet.
PostPosted: Apr Fri 06, 2012 8:35 pm
It has taken me a while but I finally finished the cabinet for my first restoration. It's a General Electric LC-628. I'm not 100% pleased with it but I think I did pretty decent for a beginner. I might have stripped it if it wasn't for the photo finish and the decals.
 Post subject: Re: Finished my first cabinet.
PostPosted: Apr Fri 06, 2012 9:31 pm
Nice job, hopefully you have many more in your future to share before and afters with us. I am currently working on mine also, a small Howard console. I've decided to concentrate on consoles because there seems to be a megaton of cheap, sad sacks out there to learn woodworking on. I'll have to get my camera out for some before and afters of my own.
Truth is stranger than fiction.
PostPosted: Apr Mon 09, 2012 6:16 pm
Nice job! How did you repair the broken grill? What process/materials did you use to get those results?
PostPosted: Apr Mon 09, 2012 6:27 pm
I intentionally broke it apart the rest of the way. I then put it all back together again using liquid nails. It took me longer to finish the grille than anything else.
PostPosted: Apr Mon 09, 2012 7:00 pm
Very nice. What process/materials for refinishing the veneer?
PostPosted: Apr Mon 09, 2012 7:16 pm
I used Howards Restor-a-finish and Minwax lacquer. I would have liked to strip it and start fresh but it has a strip of photo finish on it and I didn't want to ruin it.
PostPosted: Apr Wed 11, 2012 11:31 am
Very creative grill repair, thanks for the walk through.
PostPosted: Apr Sat 21, 2012 11:04 pm
That looks great. Howards does save the day sometimes. If you have a good base that brings it back to life
Do you plan on recovering the platter. If so leave the sides and about 1/8 inch on top un covered and paint black gloss. I like the way that looks
DIGITAL CIRCUITS ARE MADE WITH ANALOG PARTS
PostPosted: Apr Sun 22, 2012 6:51 pm
Nice job!
Did you apply Restor-A-Finish before or after the Lacquer? (I assume after?) I tried Restor-A-Finsh on the damaged top of my console phonograph, but the damage was thru the finish in one area, so had to sand entire top down to bare wood. I'm about to apply (gel) stain, then using shellac, topped by several coats of Minwax brushing lacquer. After that, hand sanding,pumice stone abrasives, & ending with rottenstone. (via YouTube step-by-step method used on a handmade chessboard that looks like it has a glass top!)
I'm interested in what others are doing/have done! I'm a novice so testing on a small table first. I tried Minwax Tung Oil Finish & hated result, so trying the YouTube method, but might stop where he says (you can stop here if you just want a satin finish) but after seeing him do the hand-sanding and then the pumice abrasives and rottenstone, I'm amazed by the glass-like finish he got. I'm not sure my 68" long mid-century modern cabinet needs that glassy look but I'm tempted!
If you want to check it out, put in "chessboard" or "Steve Marlin chessboard" on You Tube. He says he's not pro, but after watching his painstaking methods and the resultant (handmade) chessboard, he sure looks like a pro to me. He admits some of his methods aren't the way the pros do it, but he likes his results, and I do too!
Lynn
PostPosted: Apr Sun 22, 2012 9:20 pm
Looks great nice job!
We were all green once....
PostPosted: Apr Mon 23, 2012 1:33 am
Lynnster1952 wrote:
Nice job!
Lynn
I used Restor-a-finish first then went over it with lacqeur.
PostPosted: Apr Tue 24, 2012 2:41 am
It looks real nice . Better than a total restrip . Its a long hard job to get the grain filled after a whole strip job .
BTW ... wood stain is cheaper than howards .
Post New Topic Post Reply  [ 12 posts ]  Moderator: Peter
