| Author |
bhamham
Post subject: Burnishing tool to clean contacts? Posted: Apr Sun 22, 2012 12:21 pm |
Joined: Apr Fri 24, 2009 2:50 pm Posts: 157 Location: Austin, TX
I've seen several posts where folks are using a 'burnishing tool' to clean switches, etc on tube testers. Can someone point me to one of these please? Seems like a good idea not to use residue leaving cleaners on those contacts. Thanks for the help.
_________________ Regards,
Bruce
| Top |
wazz
Post subject: Re: Burnishing tool to clean contacts? Posted: Apr Sun 22, 2012 2:43 pm |
| Member |
Joined: Jun Wed 08, 2011 2:33 am Posts: 2126 Location: Ohio
I have one, a small burnishing tool in a red plastic pouch. It is labeled GC 9337. I suppose any place that carries the GC chemicals and such would maybe have it. I would think that a very fine abrasive could work as well but the tool is rigid whereas a strip of very fine abrasive paper is harder to work with. 1000 grit, maybe? Maybe a higher number?
| Top |
Mikeinkcmo
Post subject: Re: Burnishing tool to clean contacts? Posted: Apr Sun 22, 2012 3:16 pm |
HERE YOU GO You might also look at GC ELECTRONICS WEB PAGE, they have been manufacturing electronics tools for several decades now and make excelent quality merchandise. Buy 2 or 3 of them because 1, they don't last forever, and 2, they aren't very big and get lost easily.
| Top |
easyrider8
Post subject: Re: Burnishing tool to clean contacts? Posted: Apr Sun 22, 2012 7:52 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 6792 Location: Minnesota
I would be a bit leary about using anything abrasive on switch contacts. Burnishing tools were made for relays.
| Top |
markjd
Post subject: Re: Burnishing tool to clean contacts? Posted: Apr Sun 22, 2012 8:32 pm |
| Member |
Joined: Mar Tue 02, 2010 6:53 pm Posts: 298 Location: Virginia
Might try the cardboard stick part of a Q-tip, dipped in isopropanol, as a burnishing tool for fine contacts.
_________________ "No matter where you go, there you are." -BB
| Top |
Fred Scoles
Post subject: Re: Burnishing tool to clean contacts? Posted: Apr Sun 22, 2012 10:05 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1403 Location: Oswego, NY, USA
A crisp, new (like from an ATM machine) U.S. dollar bill works in some situations because it has just enough abrasiveness and durability to hold up for one set of cleanings. Regular papers do not work because they are not abrasive enough and they fall apart quickly, especially when they get soaked with cleaner solvent.
| Top |
oldgazelle
Post subject: Re: Burnishing tool to clean contacts? Posted: Apr Mon 23, 2012 5:13 am |
Joined: Jul Tue 06, 2010 7:28 pm Posts: 73 Location: Del Valle, TX 78617
| Top |
MarkPalmer
Post subject: Re: Burnishing tool to clean contacts? Posted: Apr Mon 23, 2012 1:20 pm |
| Member |
Joined: May Mon 18, 2009 5:55 pm Posts: 2027 Location: Erie, PA
Fred Scoles wrote: A crisp, new (like from an ATM machine) U.S. dollar bill works in some situations because it has just enough abrasiveness and durability to hold up for one set of cleanings. Regular papers do not work because they are not abrasive enough and they fall apart quickly, especially when they get soaked with cleaner solvent. This was (still is) the favored method of contact cleaning in old electromechanical jukeboxes and pinball machines- it works better than what you might think, and doesn't cause excessive wear to the contacts. -Mark-
_________________ My Current Projects: http://www.facebook.com/#!/pages/Marks- ... 4487855125
| Top |
Unusualdesigner
Post subject: Re: Burnishing tool to clean contacts? Posted: Apr Mon 23, 2012 5:45 pm |
| Member |
Joined: May Sun 08, 2011 10:45 pm Posts: 2942 Location: Southern Calif
MarkPalmer wrote: Fred Scoles wrote: A crisp, new (like from an ATM machine) U.S. dollar bill works in some situations because it has just enough abrasiveness and durability to hold up for one set of cleanings. Regular papers do not work because they are not abrasive enough and they fall apart quickly, especially when they get soaked with cleaner solvent. This was (still is) the favored method of contact cleaning in old electromechanical jukeboxes and pinball machines- it works better than what you might think, and doesn't cause excessive wear to the contacts. -Mark- What also works pretty good is a strip cut from a crisp business card, especially those that have a cloth like finish. Dip it in contact cleaner and rub it between the contacts. I used to finish car ignition points (dry, of course) that way after filing them.
_________________ It's easier to make a steam powered lobster trap than a lobster powered steam trap
| Top |
Dean Huster
Post subject: Re: Burnishing tool to clean contacts? Posted: Apr Wed 25, 2012 4:19 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 3196 Location: Harviell MO USA 63945 (12 miles S of Poplar Bluff)
But don't dare to use a burnishing tool on gold-plated contacts such as those used in Tektronix scopes. One swipe and there's no gold left and the contact is ruined.
_________________ Dean, Electronics Curmudgeon Contributing editor emeritus in Poptronics magazine, R.I.P.
| Top |
Mars
Post subject: Re: Burnishing tool to clean contacts? Posted: Apr Wed 25, 2012 2:58 pm |
| Member |
Joined: Apr Fri 06, 2012 3:36 pm Posts: 261 Location: 42° 7' N/ 80° 5' W
bhamham wrote: I've seen several posts where folks are using a 'burnishing tool' to clean switches, etc on tube testers. Can someone point me to one of these please? Seems like a good idea not to use residue leaving cleaners on those contacts. Thanks for the help. Good contact /de-oxidizing cleaners do not leave improper residues. A slight conductive film is all that's need to further inhibit the return of oxidization. Burnishing tools can worsen the unwanted effects of poor electrical contact by creating micro pits/grooves that foster conditions for poor electrical transfer. Having worked in the vending industry with both vending machines and arcade items employing heavy use of electromechanical contacts, etc., I was very judicous in using any abrasive type of contact burnishing tool. I also never used the dollar bill method either, since often I had to service machines in the slums, "projects", and inner-city war zones... a person gets mugged real fast when pulling out a dollar or a wallet... it was job enough just keeping track of my tools and spraying the roaches out before servicing a unit!
| Top |
Monarke4
Post subject: Re: Burnishing tool to clean contacts? Posted: Jul Tue 10, 2012 1:17 am |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 217 Location: los angeles, california, usa
MarkPalmer wrote: Fred Scoles wrote: A crisp, new (like from an ATM machine) U.S. dollar bill works in some situations because it has just enough abrasiveness and durability to hold up for one set of cleanings. Regular papers do not work because they are not abrasive enough and they fall apart quickly, especially when they get soaked with cleaner solvent. This was (still is) the favored method of contact cleaning in old electromechanical jukeboxes and pinball machines- it works better than what you might think, and doesn't cause excessive wear to the contacts. -Mark- The standard practive I have read about from the seasoned jukebox experts (and used in a pinch) from on Jukebox technical list: http://lists.netlojix.com/mailman/listinfo/jukebox-listUse a non-colored white business card. It can be moistened with a little Caig DeOxit if you wish. The business card stock is abrasive enough to clean without damage.
_________________ Donald R. Resor
N6KAW
www.hammondorganservice.com
| Top |
Radiosmoker
Post subject: Re: Burnishing tool to clean contacts? Posted: Jul Wed 11, 2012 4:00 am |
| Member |
Joined: Oct Thu 18, 2007 11:34 am Posts: 2615 Location: Pacific Northwest ;)
I have used toothpicks, both round and flat. Toothpaste also on rotary switches using toothbrush and then rinsing, followed by iso alcohol soaking.
_________________ Me repair, Smoking radios. Visit our Webpage: http://antique-radio-lab.forumotion.com/
| Top |
Ron Pond
Post subject: Re: Burnishing tool to clean contacts? Posted: Jul Thu 12, 2012 11:54 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1573 Location: Armadale, WESTERN AUSTRALIA. Tel; 61-8-9399-4978
Try these; http://www.radioparts.com.au/ProdView.a ... odDesc=MSCAvailable on eBay Australia as well. When I worked as an electronics technician for the PMG, the Oz equivalent of Ma Bell in the early 1970s, microscrub was the only contact cleaner used to clean the many millions of relay, uniselector and other contacts throughout the organisation. One strip is reusable hundreds of times and is gentle on contacts. Strips are double sided and when the end tip has eventually lost its effectiveness after much use, you just snip that section off and you have a new unused section. Some additional info here from the US International Trade Commission; http://www.faqs.org/rulings/rulings1992HQ0950122.htmlRon.
| Top |
Scott
Post subject: Re: Burnishing tool to clean contacts? Posted: Jul Fri 13, 2012 12:31 am |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1268 Location: NJ, 07645
1500 and 2000 grit wet/dry sandpaper is readily available these days. I guess you could use a strip cut from one of those sheets. Probably as fine as any burnishing tool. I prefer to stay away from anything abrasive.
| Top |
Dean Huster
Post subject: Re: Burnishing tool to clean contacts? Posted: Jul Fri 13, 2012 3:40 am |
Quote: I also never used the dollar bill method either, since often I had to service machines in the slums, "projects", and inner-city war zones... a person gets mugged real fast when pulling out a dollar or a wallet... it was job enough just keeping track of my tools and spraying the roaches out before servicing a unit! That's silly! All you do is cut the dollar bill into 1/4-inch-wide strips and put them in a small envelope. Then there's no problem with getting mugged. By the way, did you know that research has found that the higher denomination the bill, the better it is at cleaning, remaining durable, etc.? So get out your scissors and a C-note and get ready for a great burnishing party! Quote: Toothpaste also on rotary switches using toothbrush and then rinsing, Surprisingly, if you use a floride toothpaste, you'll have reduced contact pitting on relays and such.
| Top |
mescalero
Post subject: Re: Burnishing tool to clean contacts? Posted: Jul Fri 13, 2012 5:03 am |
Joined: Feb Thu 24, 2011 1:29 am Posts: 2817 Location: Dallas, TX - in the city but with bobcats and coyotes
Dean Huster wrote: .. By the way, did you know that research has found that the higher denomination the bill, the better it is at cleaning, remaining durable, etc.? So get out your scissors and a C-note and get ready for a great burnishing party!.. It is made from the same stock but some does undergo different processes such as watermark, security thread, the new window thread ($100.00), and the like. However, more valuable notes simply last longer because they tend to be handled (and spent!) less. I was at a customer's facility and they were talking statistics. One dollar bills tend to be rather filthy. You don't want to know where they've been! I design sensors for authenticating banknotes. It can be a reasonable day job.
_________________ In a triode, no one can hear you screen.
| Top |
extraclass
Post subject: Re: Burnishing tool to clean contacts? Posted: Mar Mon 25, 2013 6:11 am |
Look on ebay for Key Contact Cleaner or check at www.aa4f.com Find the cloth and the metal contact burnisher. I can be contacted at AA4F.
| Top |
Dawn
Post subject: Re: Burnishing tool to clean contacts? Posted: Mar Tue 26, 2013 11:09 pm |
I've posted this before, but a camera repair trick for a very mild abrasive is to use a soft lead pencil directly or pencilled heavily on thin paper strips. The graphite can safely remove fine oxidation and in some case used as a lubricant. With contacts, follow with iso alcohol to remove the graphite and maybe cramolin if it's still around or deoxit using the capillary action of a fine pair of needlenose tweezers as a point oiler.
Jonard burnishers both flat and rod types otherwise.
| Top |
Monarke4
Post subject: Re: Burnishing tool to clean contacts? Posted: Mar Wed 27, 2013 12:21 am |
| Member |
Dawn wrote: With contacts, follow with iso alcohol to remove the graphite and maybe cramolin if it's still around or deoxit using the capillary action of a fine pair of needlenose tweezers as a point oiler. Jonard burnishers both flat and rod types otherwise. Cramolin Red was replaced with Caig DeOxit D5 which is also slightly red in color.
N6KAW
| Top |
Users browsing this forum: No registered users and 4 guests |
