Page 1 of 1
[ 12 posts ] |
| Author |
amyotte
Post subject: My 2 Tube 1924 Reflex radio sounds like this... Posted: Apr Wed 18, 2012 1:49 am |
Joined: Jun Sat 02, 2007 1:37 pm Posts: 1341 Location: Ennismore, Ontario
Been working on a 2 tube reflex radio from a 1923-24 Radio Broadcast publication and thought I would share what I now hear. Just 9 seconds though, click on the picture.
_________________ Brian
I came into this world with nothing...
I have been able to keep most of it.
| Top |
RadioRowBoy
Post subject: Re: My 2 Tube 1924 Reflex radio sounds like this... Posted: Apr Sat 21, 2012 5:46 am |
Love it! Hank
| Top |
Tube Radio
Post subject: Re: My 2 Tube 1924 Reflex radio sounds like this... Posted: Apr Mon 23, 2012 12:58 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 8043 Location: Warner Robins, GA
| Top |
Rich K.
Post subject: Re: My 2 Tube 1924 Reflex radio sounds like this... Posted: Apr Mon 23, 2012 9:11 pm |
| Member |
Joined: Aug Tue 30, 2011 11:25 pm Posts: 975 Location: Charlevoix, Michigan, USA
Sounds great! What sort of sensitivity are you getting from it, as far as DX stations?
| Top |
amyotte
Post subject: Re: My 2 Tube 1924 Reflex radio sounds like this... Posted: Apr Mon 23, 2012 9:15 pm |
Rich K. wrote: Sounds great! What sort of sensitivity are you getting from it, as far as DX stations? I can pull in a lot of stations at night but the selectivity is bad. Looking at building a 2 tube Doerle to replace this - just have not found the coil data for MW.
| Top |
wrnewton
Post subject: Re: My 2 Tube 1924 Reflex radio sounds like this... Posted: Apr Tue 24, 2012 11:52 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 5536 Location: Cleona, PA
Great, and how appropriate that you tuned in KDKA, that station being a pioneer and about four years old when your radio plans were published.
_________________ Reece
| Top |
err ducks
Post subject: Re: My 2 Tube 1924 Reflex radio sounds like this... Posted: Apr Wed 25, 2012 1:37 pm |
| Member |
Joined: Mar Wed 26, 2008 3:06 pm Posts: 437 Location: Cave Springs, AR
amyotte wrote: Rich K. wrote: Sounds great! What sort of sensitivity are you getting from it, as far as DX stations? I can pull in a lot of stations at night but the selectivity is bad. Looking at building a 2 tube Doerle to replace this - just have not found the coil data for MW. The 2 tube Doerle is a sweet perfomer. Good sensitivity and selectivity. I can listen to a strong station across the room using 45V B+. Calculate your coil to fit your variable capacitor. To tune MW you will need at least 365pF. 400 pF would be better.
_________________ Mark
| Top |
Burnt Fingers
Post subject: Re: My 2 Tube 1924 Reflex radio sounds like this... Posted: Apr Wed 25, 2012 9:38 pm |
Joined: Oct Sat 20, 2007 3:36 am Posts: 13596 Location: New Hampshire
The higher the C the higher the Q and selectivity, even 1000pf for the low BCB isnt excessive and Cardwell made them in the 20's with a fairly small .030" spacing so they arent for big transmitters.
Of course a 2 or 3 gang 365-400pf BC style could be wired in parallel.
| Top |
radioterry
Post subject: Re: My 2 Tube 1924 Reflex radio sounds like this... Posted: Apr Wed 25, 2012 10:35 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1872 Location: Central VA
amyotte wrote: Rich K. wrote: Sounds great! What sort of sensitivity are you getting from it, as far as DX stations? I can pull in a lot of stations at night but the selectivity is bad. Looking at building a 2 tube Doerle to replace this - just have not found the coil data for MW. Brian: Do a Google search for Bill "Exray" Meacham's contact information. He built some 2 tube Doerle's in the past and can probably provide you with all of the information, coil and otherwise, that you'll need. In fact, Bill built quite a few homebrews...that you'll see once you've located his webpage. BR, Terry
| Top |
BobWeaver
Post subject: Re: My 2 Tube 1924 Reflex radio sounds like this... Posted: Apr Thu 26, 2012 12:03 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1411 Location: Saskatoon
| Top |
err ducks
Post subject: Re: My 2 Tube 1924 Reflex radio sounds like this... Posted: Apr Thu 26, 2012 2:41 am |
| Member |
BTW there are at least 2 different 2 tube Doerle circuits out there. One uses a throttle capacitor another uses a pot on the B+ to control the regen.
I prefer the B+ control because pots are cheaper (especially if you are using vintage components), easier to mount, not sensitive to hand capacitance and I have found they are less touchy, and require less adjustment as you change frequency.
I also omit the antenna capacitor or winding and just use a "gimmick" capacitor by wrapping an alligator lead around the antenna lead in. (Antenna length is a factor here.)
Kevin "krystallo" can verify that my 2 tube Doerle works best with an alligator clip simply clipped onto the insulation of my 300' longwire lead-in.
Your mileage may vary.
| Top |
amyotte
Post subject: Re: My 2 Tube 1924 Reflex radio sounds like this... Posted: Apr Thu 26, 2012 12:49 pm |
BobWeaver wrote: radioterry wrote: Do a Google search for Bill "Exray" Meacham's contact information... Bill's website is here: http://sparkbench.com/A contact email address is there. His 2-tube Doerle is shown on this page: http://www.sparkbench.com/homebrew/homebrew.htmlI have visited Bill's site many times. Thanks for the link
| Top |
Page 1 of 1
[ 12 posts ] |
