Page 1 of 1
[ 15 posts ] |
| Author |
ketron281989
Post subject: When were Globe tubes discontinued Posted: Apr Mon 23, 2012 8:26 pm |
| Member |
Joined: Jul Mon 11, 2011 9:04 pm Posts: 404 Location: De Queen, AR
Hi guys, I have a RCA model 331 DUO, there are ST type tubes in it now, which came out after the globe style. Could anybody tell me if globe tubes were used up to the mid thirties or were they already phased out by then.
Also if I have a radio that takes 8 pin ST tubes and the rectifier tube is the 4 pin type, would it be period correct, in 1933, to have a globe type rectifier (Since they were 4 pin not 8 pin) and St type for the others in the set.
Jon
| Top |
35Z5
Post subject: Re: When were Globe tubes discontinued Posted: Apr Mon 23, 2012 8:37 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 8652 Location: Chesapeake VA
The first 8 pin octal tubes were the metal types introduced in 1935... By that time any set using big pin tubes(or a mix of) would have ST types...
| Top |
Scott
Post subject: Re: When were Globe tubes discontinued Posted: Apr Mon 23, 2012 9:31 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1220 Location: NJ, 07645
I am pretty sure that by 1932 globe tubes were gone.
| Top |
Burnt Fingers
Post subject: Re: When were Globe tubes discontinued Posted: Apr Mon 23, 2012 9:43 pm |
Joined: Oct Sat 20, 2007 3:36 am Posts: 13596 Location: New Hampshire
+1 for 32 and the 42 is a good contender.
| Top |
ketron281989
Post subject: Re: When were Globe tubes discontinued Posted: Apr Mon 23, 2012 10:59 pm |
| Member |
What do you mean by the 42 being a good contender?
| Top |
Burnt Fingers
Post subject: Re: When were Globe tubes discontinued Posted: Apr Tue 24, 2012 2:32 am |
That a globe 42 was introduced in 32.
Industrial tubes kept the shape a lot longer such as the 866 & 866A.
| Top |
Dave Doughty
Post subject: Re: When were Globe tubes discontinued Posted: Apr Tue 24, 2012 2:45 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 13656 Location: Utica, NY 13502 (USA)
If globe tubes were gone by '32, how then could a 42 have been introduced as a globe in '32?
| Top |
jkoebel
Post subject: Re: When were Globe tubes discontinued Posted: Apr Tue 24, 2012 4:33 am |
Joined: Aug Thu 27, 2009 7:47 am Posts: 1830 Location: Seattle
| Top |
35Z5
Post subject: Re: When were Globe tubes discontinued Posted: Apr Tue 24, 2012 4:57 am |
| Member |
What seems to be forgotten is a year is 12 months long and IF the 42 was introduced in Feb but globe bulbs were not phasing out till May, there would be some globe 42 production...
| Top |
Alan Douglas
Post subject: Re: When were Globe tubes discontinued Posted: Apr Tue 24, 2012 7:25 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 23519 Location: Pocasset, Cape Cod, MA
The changeover from S to ST took a while, several years for some types.
| Top |
David Roper
Post subject: Re: When were Globe tubes discontinued Posted: Apr Tue 24, 2012 8:12 pm |
| Member |
Joined: Apr Thu 20, 2006 5:36 pm Posts: 1508 Location: Holland, MI
| Top |
codefox
Post subject: Re: When were Globe tubes discontinued Posted: Apr Tue 24, 2012 8:39 pm |
There is no physical reason that I know of why a globe shaped tube could be produced today. Bits and pieces of folks fooling around and making tubes of all sorts have been seen many times. Don't have enough time left to try this.
| Top |
ketron281989
Post subject: Re: When were Globe tubes discontinued Posted: Apr Tue 24, 2012 9:14 pm |
| Member |
Wow, thanks for all the replies. Most of my sets are from the 20's and 30's so this information is very valuable to me, Thanks.
My last question: Could I use a globe type tube when all others are ST type?
| Top |
Burnt Fingers
Post subject: Re: When were Globe tubes discontinued Posted: Apr Wed 25, 2012 2:58 am |
Tube shapes are interchangable where they physically fit. You could have a 280, 380, 80 in globe, ST, GT, and baseless and its all the same tube for instance. For the nitpickers on here the later 80's were 5Y3's with a 4 pin base Carl
| Top |
ketron281989
Post subject: Re: When were Globe tubes discontinued Posted: Apr Thu 26, 2012 4:53 am |
| Member |
| Top |
Who is online |
Users browsing this forum: No registered users and 1 guest |
