Page 1 of 1
[ 8 posts ] |
| Author |
MM
Post subject: Probe for a monster F Counter Posted: Apr Thu 26, 2012 6:49 am |
Joined: Nov Wed 15, 2006 7:56 am Posts: 544 Location: germany
hello friends, I got a Systron Donner Counter/Multimeter 6130. What kind of probe is to use at the SMA plug please ? I dont know if SHF will be useful to me, but I need it complete. This machine is fast enough to count the microwave in the kitchen greetings Martin
| Top |
K7MCG
Post subject: Re: Probe for a monster F Counter Posted: Apr Thu 26, 2012 7:30 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2053 Location: Seattle WA US
Microwave counters generally have 50 ohm coax inputs. No probe is used. Just a 50 ohm source within the required level range. Whatever you do, don't exceed the maximum signal input level specified for your counter.
-Chuck
| Top |
MM
Post subject: Re: Probe for a monster F Counter Posted: Apr Thu 26, 2012 12:06 pm |
hello Chuck, thank you,
data, input C,
range, 500MHz to 26.5GHz input sensitivity -25dBm 10GHz to -10dBm 26.5GHz maximum input load +20dBm
I have no Voltmeter what can work at so extremly high frequencys. The counter works perfect on Input A, B up to 500MHz. I have no useful idea for the microwave range.
it have a GPIB Interface for computers. I never owned a gear like that.
greetings Martin
| Top |
MarkPalmer
Post subject: Re: Probe for a monster F Counter Posted: Apr Thu 26, 2012 1:10 pm |
| Member |
Joined: May Mon 18, 2009 5:55 pm Posts: 2027 Location: Erie, PA
It's more likely to be a type N female connector on the counter for the microwave input above 500 MHz. Very few hobbyists have any use for anything above 500 MHz, but there still aren't any special considerations if you want to use the range, (I'll probably get ARF'ed about shielding by others for very low level inputs, but I'm talking layman's terms here) and you can use a type N male to BNC adapter on that input. SD made good counters, although their service data can be hard to come about. Now you have to build yourself an interface bus computer LOL!
-Mark-
_________________ My Current Projects: http://www.facebook.com/#!/pages/Marks- ... 4487855125
| Top |
Mars
Post subject: Re: Probe for a monster F Counter Posted: Apr Thu 26, 2012 1:14 pm |
| Member |
Joined: Apr Fri 06, 2012 3:36 pm Posts: 261 Location: 42° 7' N/ 80° 5' W
MarkPalmer wrote: (I'll probably get ARF'ed about shielding by others for very low level inputs, but I'm talking layman's terms here) -Mark- CORRECTION: I think you meant to type BARF - Boat Anchor Radio Forum
| Top |
MarkPalmer
Post subject: Re: Probe for a monster F Counter Posted: Apr Thu 26, 2012 2:14 pm |
| Member |
Mars wrote: MarkPalmer wrote: (I'll probably get ARF'ed about shielding by others for very low level inputs, but I'm talking layman's terms here) -Mark- CORRECTION: I think you meant to type BARF - Boat Anchor Radio Forum It's a fact that using anything other than a nixie display counter on a BA can severely upset the applecart. -Mark-
| Top |
K7MCG
Post subject: Re: Probe for a monster F Counter Posted: Apr Thu 26, 2012 4:19 pm |
Two quick comments: remember that +20dbm is 2.5 volts (approx) across 50 ohms. Anything higher will destroy the counter input. If in doubt of what levels you have, keep a 10 or 20 db attenuator on the input for protection.
More important - if the microwave input is working, you probably can sell that counter for enough cash to equip an entire radio workbench.
--Chuck
| Top |
MarkPalmer
Post subject: Re: Probe for a monster F Counter Posted: Apr Thu 26, 2012 4:37 pm |
| Member |
K7MCG wrote: More important - if the microwave input is working, you probably can sell that counter for enough cash to equip an entire radio workbench.
--Chuck That is very true. -Mark-
| Top |
Page 1 of 1
[ 8 posts ] |
