| Author |
fwdstuck
Post subject: Re: Admiral 20x122 scored Posted: Mar Fri 23, 2012 7:35 pm |
Joined: Dec Fri 23, 2011 2:24 am Posts: 194 Location: Whitwell, TN
Started checking voltages and they look good. Turned the brightness down a little and got a distorded picture. The brightness was wiping out the picture. I have to turn it up high cause the tube is almost dead. Here is a video of what is doing:
| Top |
Bill Cahill
Post subject: Re: Admiral 20x122 scored Posted: Mar Fri 23, 2012 9:39 pm |
| Member |
Looks like your horizontal oscilator is way off frequency. Bill Cahill
_________________ http://www.tuberadioforum.com/ PLEASE visit Tube Radio Forums-The best forum in the World!
| Top |
bandersen
Post subject: Re: Admiral 20x122 scored Posted: Mar Fri 23, 2012 10:41 pm |
Joined: May Fri 29, 2009 4:35 am Posts: 1068 Location: Chicago, IL USA
Congratulations on making it this far  There's a horizontal oscillator adjustment slug on the back of the set. On the other side of the same coil, under the chassis there's another adjustable slug for setting the synchroglide lock. It's best to have a scope handy for making that adjustment. The Riders and Sams service info describes how to do it.
| Top |
fwdstuck
Post subject: Re: Admiral 20x122 scored Posted: Mar Sun 25, 2012 2:18 am |
I got a scope. But its an older 1970s B&k. So it doesn't show the frequency like newer scopes. So I need to adjust it to match the wave forms in riders?
| Top |
philsoldradios
Post subject: Re: Admiral 20x122 scored Posted: Mar Sun 25, 2012 4:10 am |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 3700 Location: Woodinville, WA USA
Yes, you will use the scope to view the horizontal waveform. I use an older B & K, too -- works fine.
As bandersen noted, both Riders (page 20) and Sams (page 12) describe the procedure.
| Top |
fwdstuck
Post subject: Re: Admiral 20x122 scored Posted: Mar Sun 25, 2012 4:46 am |
I hooked up my scope. And got it adjusted and got a great picture now. I'll post pics later. But my horizontal will not come out of hold when i adjust the horizontal hold, full left or right. I know thats not a bad thing. But its weird.
| Top |
philsoldradios
Post subject: Re: Admiral 20x122 scored Posted: Mar Sun 25, 2012 4:57 am |
| Member |
Yay!
Some early horizontal systems are indeed that stable. My DuMont RA-103 doesn't even have a horizontal hold control in front. It's located on the rear of the chassis, which struck me as hubris on the designer's part until I played the TV.
| Top |
Bill Cahill
Post subject: Re: Admiral 20x122 scored Posted: Mar Sun 25, 2012 6:20 am |
| Member |
It uses the synchro-phase circuit, which is very stable. At it's best, throw horizzontal hold off, try switching channels. Picture should go into lines. At peak adjustment, middle setting of control is most stable.
On the '50 models they had a different phase circuit, with a single coil on back. You adjust that coil for stability while changing channels. It also works amazingly well. My 21D1 chassis uses this circuit, and, it's amazingly stable. I think RCA was the first of a more difficult version in their '46 models. Bill Cahill
| Top |
fwdstuck
Post subject: Re: Admiral 20x122 scored Posted: Mar Mon 26, 2012 12:40 am |
Here is a pic of it after adjusting the horizontal pots with the scope hooked up: Better look at the picture. The tube is about dead and I have some shadow problems. But I will fix that latter. I have a good 10BP4 coming in week or two. I have another issue. It hums a little from the speaker. But I touch the chassis or hook up the ground from the scope the hum goes away. What is causing that?
| Top |
philsoldradios
Post subject: Re: Admiral 20x122 scored Posted: Mar Mon 26, 2012 1:55 am |
| Member |
What is your signal source?
| Top |
fwdstuck
Post subject: Re: Admiral 20x122 scored Posted: Mar Mon 26, 2012 1:56 am |
Quote: What is your signal source? VCR
| Top |
fwdstuck
Post subject: Re: Admiral 20x122 scored Posted: Mar Mon 26, 2012 1:57 am |
I need to hook a dvd player and rf modulator like my porthole
| Top |
fwdstuck
Post subject: Re: Admiral 20x122 scored Posted: Mar Wed 28, 2012 1:29 am |
I haven't hooked up a dvd player yet. But the hum only happens when I have a video playing. When i hit the stop button on the vcr the hum goes away, but the vcr stays on. I didn't have the hum problem before I adjusted the horizontal oscillater, Could it be a intercarrier buzz problem like I had on my porthole?
| Top |
fwdstuck
Post subject: Re: Admiral 20x122 scored Posted: Apr Thu 05, 2012 1:51 am |
I got me a good 10BP4, high voltage cage, and a couple knobs. I have done some cleaning on the bakelite cabinet today. I hope to have the chassis back in the cabinet this weekend.
| Top |
bandersen
Post subject: Re: Admiral 20x122 scored Posted: Apr Thu 05, 2012 4:49 am |
Cool, I hope you get a nice bright picture.
| Top |
philsoldradios
Post subject: Re: Admiral 20x122 scored Posted: Apr Thu 05, 2012 5:53 am |
| Member |
I would hook up the DVD player this time, to eliminate the VCR as a trouble source. My son loves to collect old VHS tapes, and I have heard some awful sounds when the tape or the player (or both) are funky.
| Top |
fwdstuck
Post subject: Re: Admiral 20x122 scored Posted: Apr Sun 08, 2012 1:24 am |
| Top |
Mal Fuller
Post subject: Re: Admiral 20x122 scored Posted: Apr Sun 08, 2012 10:53 pm |
Joined: Oct Fri 02, 2009 7:05 pm Posts: 1099 Location: Wolfeboro, NH
The following is all moot conjecture if you'll be replacing the CRT in any event, but it strikes me as doubtful that the transformer added on to the rear apron of the chassis constitutes a "homemade brightener." I'm betting that it was added to isolate the CRT's filament connection from ground to eliminate the effects of a heater to cathode short in the CRT. Brighteners were a dime a dozen, but not all provided isolation. The add-on transformer would have to have had some weird windings to make an effective brightener.
| Top |
hi_volt
Post subject: Re: Admiral 20x122 scored Posted: Apr Sat 28, 2012 5:54 am |
| Member |
Joined: Oct Mon 03, 2011 5:33 am Posts: 294 Location: Tucson, Arizona
Nice set! I just picked up one of these today. 100% complete, but with a big crack down the right side of the bakelite case. Any suggestions for how I might go about doing a decent looking repair on the crack? I thought perhaps a careful application of JB Weld and a belt clamp. Comments?
| Top |
oldtvnut
Post subject: Re: Admiral 20z1 chassis model 12x12 redplate 5u4 tube Posted: Aug Thu 23, 2012 6:15 am |
Hi all !! I jsut bought this Admiral 12" tabletop tv for $10 It has 2 problems:1, the 5u4's plates get hot unless I pull the seaker plug then it goes back to normal.also the main filter can gets rather warm . help! love this nic lady
| Top |
Who is online |
Users browsing this forum: Exabot [Bot], M3-SRT8 and 2 guests |
