It is currently May Sat 25, 2013 11:21 pm
Post New Topic Post Reply  [ 30 posts ]  Go to page Previous  1, 2
 Post subject: Re: Fender Champ guitar amp: Need diagnostic tips/hints.
PostPosted: Apr Tue 24, 2012 1:37 pm
moving a ground near capacitors shouldnt create hum. I would check the ground connections from there all the way-back to where it should be terminated. ground loops can cause hum. you want to eliminate double grounding as much as possible so not to have hum possibilities. a single ground buss is ideal. when chassis is reference ground a loose control mounting nut could be an issue if the control is contact ground depending on the tightness of the nut.
CAUTION: Im no expert
PostPosted: Apr Tue 24, 2012 2:00 pm
The original AA764 didn't even have shielded cable from the VC to driver 12AX7. If you added shielded cable you must have introduced a ground loop or something. Using shielded cable properly should reduce 60 Hz hum, but using it improperly can make it worse.
Can you post a picture of your chassis, so we can see the lead dress and how you connected the shield?
Chuck D. KB9UMF
PostPosted: Apr Wed 25, 2012 10:35 pm
@Cdoose
I will post a pic and voltage/resistance measurements later this evening when I find some time.
I think I may have mislead you about the chassis. This is a 1977 silverface champ. I have never found an AB764 schematic for the champ but I do have a schematic for the CBS-era champ (approval dates on the schematic 1972). However, the voltage don't match those of this amp. For instance the CBS champ schematic has 420v B+ and 260v on the plates of the 12ax7a. Also it has 40 mf filter cap and the 330 pf cap on the 6v6gta. My voltages are ~360v and ~210v respectively which I think are closer to the AA764/blackface values but it also has the 40 mf and the 330pf caps.
PostPosted: Apr Thu 26, 2012 5:05 am
@tubeAMP
I checked all the grounds for loose connections. Nothing changed. I thought the tranny bolts were tight enough but I really reefed on them. Hum gone. It's like my vibro champ now. Thanks.
@Cdoose
Here's what I've done now:
Return everything to stock values, components, and circuitry (no grid stopper nor screen resistors on the power tube) except for
a) all eletrolytics are new but the 2mf/25vdc is now 25mf/25vdc (another site suggests this will reduce the "fartiness" of the bass response)
and the 25mf/25vdc bypass cap (in parallel with the 2W 470 ohm cathode resisitor) is now 25mf/50vdc
b) the 470 ohm cathode resistor is still the 2W pot set to 470 ohms (for measurements as suggested)
c) no 330pf cap on the power tube
Note: this restoration includes
a) removing an extra leg of filtering using a 270 ohm 10W resistor in parallel with a 20mf/450vdc cap immediately after the rectifier
b) reusing the old coupling capacitors (because I want to compare them to the new ones when the bias is set right)
Measurements:
OT primary resistance: 288ohms
After 15min of warming the amp up, (voltages measured to ground unless noted)
red wire of OT -- B+: 378v
pin 3 -- plate: 364v
pin 4 -- screen: 374v
pin 8 -- cathode: 22v
voltage across cathode resistor: 22v
Please let me know if you need more info and note that I will likely put back the extra leg of filtering, use grid-stopper (1k as you suggested) and screen resistors (??) unless you strongly think otherwise. I'm assuming its more important to get the bias set properly first but I'd really like to get the screen voltage down below plate.
I appreciate you taking the time out to help.
The other thing I'm planning to (re)do is to reduce the voltages going to pins 1 and 6 of the 12ax7a. I read that the champ has a "sweet spot" distortion-wise (ie. more blackface like) when the voltages are around 180v. Currently they are 225 and 230, respectively, but were at 183 when I used a pair of 180k resistors instead of the 100k ones. Comments anyone?
PostPosted: Apr Thu 26, 2012 11:40 am
The extra leg of filtering was probably done to rduce the B+ some so it may be good to put it back. It is ok for the screen voltage to be a little higher than the plate.
Be careful as to what you do to the amp as changing voltages could affect the sound of the amp.
PostPosted: Apr Thu 26, 2012 5:32 pm
I found that changing value of one load resistor effects all the other load voltages on the same leg as well :shock:
PostPosted: Apr Fri 27, 2012 3:03 am
willard wrote:
@tubeAMP
@Cdoose
Measurements:
Willard,
Sounds like everything is fine with the output stage of your amp. Don't worry that the screen voltage is higher than the plate. From your voltage readings it appears that the screen is drawing about 2 to 3 mA and that is what you should expect from a good 6V6GT. I just checked an NOS RCA and found the screen current to be 3 mA with plate, screen and grid voltages the same as what you have. The voltages on the Fender schematic are approximate, and are not going to be exactly what you have.
I wouldn't add any additional screen resistance, just the original 1 kOhm 1 Watt. You could add a g1 stopper of maybe 1 to 10 kOhm, but it really isn't needed with a SE output stage. It might reduce blocking distortion a bit.
As far as the plate voltage on the 12AX7's go ahead and play with those values all you want. Maybe put pots in and adjust them to get the tone you like, it won't hurt anything. If you install 180k plate resistors, the 2nd order distortion would be about half of what it is with 100k. The gain would be about 20% higher per stage with 180k plate resistors.
Regarding the original caps, I'd be concerned about the coupling cap feeding the grid of the 6V6. If it's leaky, it will increase the grid bias and plate current. It doesn't look like it's much of a problem now because your plate current is about right with the correct 470 Ohm cathode resistor. An easy way to see if the caps are leaky is just lift the end not connected to the plate and measure the DC voltage with a high impedance meter. If you have more than a volt or two I'd replace it. If you know the input impedance of the meter you can calculate the leakage resistance by knowing the voltage drop across the cap.
About the additional RC filtering, I don't see any problem with that at all it will just lower the B+ by about 10 to 15 V.
Have fun hope you get the sound you want. I've always found that the speaker makes the most difference with combo guitar amps. I'm a big fan of Weber speakers.
Chuck D. KB9UMF
PostPosted: Apr Fri 27, 2012 4:19 am
Isn't it the Mallory 150s that sound a lot like the vintage capacitors?
PostPosted: Apr Sat 28, 2012 3:03 pm
Thanks Cdoose. Reading the stuff from the guitar amp forums can make you too fussy :) But they also say that the easiest mod/improvement is the speaker. I have the Jensen C8R (Italian re-issue) but I'd like to try the Weber Sig series alnico. Good value and sound people say for around $35 but it cost around another $35 to get it shipped to Canada ... (now if some here in the US were buy it with free shipping to them and then decide to sell through this site for a reasonable shipping cost, I'm all ears :) I found one site in California that would ship to Canada for $10 then the next day they said they couldn't ship Webers internationally. Something strange going on here.
@Tube Radio
I installed new coupling caps but they were generic ones from the local electronics, polypropylene it think. I have some Mallory 150's and some Sprague orange drops on order. Others seem to think the same of the 150's. I wonder if my ears will be able to tell the difference.
PostPosted: Apr Sat 28, 2012 5:17 pm
More than likely you will not be able to tell a difference. I have used many different film capacitors and have never heard any difference.
