Page 1 of 1
[ 17 posts ] |
| Author |
gdehaan
Post subject: 12AX7 from 1980's RCA--Gr. Britain or Serbia? Posted: Apr Mon 30, 2012 3:16 pm |
Joined: Nov Sat 26, 2011 3:04 pm Posts: 113 Location: Marion, Michigan
I would like to know how a 12AX7 tube that has been stored in a barn in Michigan for over 20 years, having the standard, modern RCA logo and labeled as made in Gr. Britain, could have had its country of manufacture in Serbia? Any thoughts? Thanks very much. Gord DeHaan
| Top |
fvan
Post subject: Re: 12AX7 from 1980's RCA--Gr. Britain or Serbia? Posted: Apr Mon 30, 2012 3:49 pm |
| Member |
Joined: Mar Sat 01, 2008 10:02 pm Posts: 695 Location: Lillooet Canada
Do you have any more info on the tube, maybe pictures or markings?
It is quite common for distributors to source tubes in various places and relabel as their own.
I found this info on vacuumtube.com that might explain things.
Frank
EI Electronic Industries, Nis, Serbia
Former state-owned factory, makes all types of electrical products, still making tubes using some old Philips production tooling and equipment. Marketed outside of Serbia by Edicron Electronic Components Ltd, UK. Types in production: 6CA7, 6CG7, 12AT7, 12AX7, 12BH7, 12DW7, EL34, EL519, PL519, KT90, KT99, EL84, EL86, possibly a few others.
| Top |
928GTS
Post subject: Re: 12AX7 from 1980's RCA--Gr. Britain or Serbia? Posted: Apr Mon 30, 2012 8:03 pm |
Joined: Nov Thu 04, 2010 5:49 am Posts: 338 Location: Albany, NY
Some pictures would be very helpful. Look around the base of the glass, do you see any letters or numbers there?
| Top |
BigBandsMan
Post subject: Re: 12AX7 from 1980's RCA--Gr. Britain or Serbia? Posted: Apr Mon 30, 2012 8:45 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 6032 Location: Raleigh NC USA
A lot of "outsourcing" was going on at that time, not all of it "straight up." I have a pair of NOS "Amperex" "6L6GC" tubes from that time period. They carry a stamp of "GT BRITAIN" (not "made in Gt Britain," however), and they are USSR all the way. They won't hold up in 6L6GC service, either. The plates go cherry. More like 6L6GB's.  Larry
_________________ It don't make a go if it ain't got that GLOW!
| Top |
Alan Douglas
Post subject: Re: 12AX7 from 1980's RCA--Gr. Britain or Serbia? Posted: Apr Mon 30, 2012 10:29 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 23511 Location: Pocasset, Cape Cod, MA
I'd be surprised if any RCA tubes were ever made in Great Britain, and if I saw any so marked, I'd suspect the markings of being bogus.
| Top |
fvan
Post subject: Re: 12AX7 from 1980's RCA--Gr. Britain or Serbia? Posted: Apr Mon 30, 2012 10:43 pm |
| Member |
Alan Douglas wrote: I'd be surprised if any RCA tubes were ever made in Great Britain, and if I saw any so marked, I'd suspect the markings of being bogus. I think I have come across RCA branded audio tubes that also had the Mullard Blackburn code etched on the tube and had the tell tale Philips seams as well. Who knows who did the re-branding though, I have come across tubes labeled as made in a certain country, where the etched Philips/Mullard code did not agree. Frank edit: Lots of info on the net if you Google "RCA branded tubes made in Great Britain". Seems it was related to USA import restriction during the cold war, when importing from the Eastern Block was verboten. If the tubes are Mullard or Philips, they will have an etched date and factory code.
| Top |
swanson
Post subject: Re: 12AX7 from 1980's RCA--Gr. Britain or Serbia? Posted: Apr Mon 30, 2012 11:51 pm |
It's possible it could be a genuine Mullard.I have RCA branded ECF80/6BL8's that are actually Mullards.Also have a Siemens gold pin 6922 that is branded with the old style RCA logo. Regards, Swanson
| Top |
Alan Douglas
Post subject: Re: 12AX7 from 1980's RCA--Gr. Britain or Serbia? Posted: May Tue 01, 2012 2:11 am |
OK, I could believe a tube type that RCA or other US companies didn't make, but 12AX7s were pretty common and I'd expect several US companies like GE and Sylvania were set up to make them. Now whether they had all closed up shop by the 1980s, I don't recall.
| Top |
35Z5
Post subject: Re: 12AX7 from 1980's RCA--Gr. Britain or Serbia? Posted: May Tue 01, 2012 3:46 am |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 8651 Location: Chesapeake VA
RCA closed it's Harrison NJ tube mfgr plant in '76, everything after that point has to be from another source...
I have a RCA branded 5AR4 from Great Brittan that I believe is a Mullard...
| Top |
AuroraOldRadios
Post subject: Re: 12AX7 from 1980's RCA--Gr. Britain or Serbia? Posted: May Tue 01, 2012 4:40 am |
| Member |
Joined: Jul Sun 09, 2006 3:11 am Posts: 1949 Location: Aurora, CO
I'd have to dig it out of the tube black hole, but I have an RCA branded 12AX7 made in Hungary.
| Top |
gdehaan
Post subject: Re: 12AX7 from 1980's RCA--Gr. Britain or Serbia? Posted: May Tue 01, 2012 12:24 pm |
Thank you all. It was news to me, but it looks like if someone were a fan of the 12AX7 then it is somewhat common knowledge. Gord
| Top |
wazz
Post subject: Re: 12AX7 from 1980's RCA--Gr. Britain or Serbia? Posted: May Wed 02, 2012 1:30 pm |
| Member |
Joined: Jun Wed 08, 2011 2:33 am Posts: 2056 Location: Ohio
You can sometimes determine who made a tube based on the internal construction and details. Sometimes tiny details, like if some tabs are square or round, the shape of the mica insulators, plate pattern, getter, etc. I have used photos on ebay of good resolution for comparison when I had no example at hand.
| Top |
davestp1
Post subject: Re: 12AX7 from 1980's RCA--Gr. Britain or Serbia? Posted: May Thu 03, 2012 12:24 pm |
Joined: Sep Wed 02, 2009 5:27 pm Posts: 111 Location: Ottawa, Canada
http://www.ebay.com/itm/221009555904?ss ... 1423.l2649The tube in question that the OP is asking about is identical in appearance and structure to the tubes listed in the auction above. There are no markings on the tube other than what you can see in the photos. No etched codes of any kind nor are there any markings on the base between the pins.
| Top |
swanson
Post subject: Re: 12AX7 from 1980's RCA--Gr. Britain or Serbia? Posted: May Thu 03, 2012 3:05 pm |
Those 12AX7's were definitely made by Ei in the former Yugoslavia.Back in the early 1990's I used to be able to buy those tubes for just a few dollars each.They are good tubes and are starting to get sort of expensive because they are no longer made and remaining stocks are getting scarce. Regards,
| Top |
fvan
Post subject: Re: 12AX7 from 1980's RCA--Gr. Britain or Serbia? Posted: May Thu 03, 2012 3:07 pm |
| Member |
The eBay seller claims the factory was destroyed, not the case, they are still operating. They have used a variety of Telefunken and Philips production equipment in the past. http://www.eierc.com/rc/who_we_are.htmFrank
| Top |
Alan Douglas
Post subject: Re: 12AX7 from 1980's RCA--Gr. Britain or Serbia? Posted: May Fri 04, 2012 1:17 am |
In the 1980s and 1990s I subscribed to several limited-circulation audio magazines, though I wasn't buying tubes myself (I had all I needed). I recall reports of hanky-panky by one or more distributors, one of which rebranded Eastern-bloc tubes for sale to the US military.
I don't know when RCA stopped distributing tubes, but I'd expect it was not long after closing the Harrison plant. Just a guess however.
| Top |
Jim Cross
Post subject: Re: 12AX7 from 1980's RCA--Gr. Britain or Serbia? Posted: May Fri 04, 2012 7:52 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 653 Location: Orlando, FL, USA
Alan, et al,
First, a bit of older history...
RCA did indeed import a few European types. RCA never made 5AR4s and sold either Sylvania's or Mullard's. RCA never made 6DJ8s or 6922s. Most of these are Siemens, but one also sees Holland and Great Britain. (RCA's own failed 6DJ8 was the 6FW8)
After RCA stopped making tubes in '76, they continued to sell tubes into at least the early 1980s. Alan, your suspicion of bogus tubes is almost on the mark. It appears to me in this late period, RCA's chief supplier of tubes of foreign origin was International Components Corp (ICC). ICC would print "Great Britain" or "Germany" on anything. The simple test is this... If the tube has a Mullard factory and date code, it is legitimate Mullard. Sometimes these late tubes have Yugoslavian factory codes. Other times they are uncoded. ICC appears to have been pretty indescriminant about what they supplied. Sometimes ICC supplied the "real" thing, but oftentimes not.
ICC appears to be the source of late RCA, Raytheon, and Westinghouse 6L6GCs that are Russian, but rebranded "Germany" or "UK".
| Top |
Users browsing this forum: FM Refugee and 2 guests |
