It is currently May Sun 19, 2013 9:35 pm
 Post subject: Is this Cap too close to the tube?
PostPosted: Apr Mon 30, 2012 11:28 pm
Give me your honest opinion, but be gentle…
Is this cap too close to the output tube for safety? If it makes any difference, it's rated at 85 degrees C.
…and it didn't fix my low-level hum, either…
Thanks in advance -
Dan
 Post subject: Re: Is this Cap too close to the tube?
PostPosted: Apr Mon 30, 2012 11:33 pm
Yes, the life of the cap will be shortened with it mounted right next to the tube like that. It needs to be in the same physical position as original, or else moved under the chassis.
Best to always purchase 105 degree caps, they cost very little more than the 85 degree types, but even one of those wouldn't survive when mounted nearly touching a tube. Ideally you want to keep it a couple of inches away, unless it is mostly located below the tube like it was originally.
PostPosted: Apr Mon 30, 2012 11:37 pm
The ones in the brown striped jackets look like likely suspects, to me.
PostPosted: Apr Mon 30, 2012 11:54 pm
Ah, the ability to think out of the box…
The cap is already happily residing under the chassis now.
And I will get working on those other caps soon enough - just wanted to take care of the electrolytics first.
Thanks again -
Dan
PostPosted: Apr Mon 30, 2012 11:56 pm
8)
PostPosted: May Tue 01, 2012 1:01 am
How about that small blue Lytic there in the front of pic.
Don't forget that one.
PostPosted: May Tue 01, 2012 2:12 am
and the dirt and the wax capacitors. PCB chassis. got an Emerson with PCB chassis. modular component blocks. pretty cool design. simple. performs very well. probably exact same tube lineup. 12BE6 12BA6 35W4 etc.
CAUTION: Im no expert
Post New Topic Post Reply  [ 7 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: fifties, Oldbear, Pbpix, Philco Fan and 11 guests
