| Author |
35Z5
Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic) Posted: Apr Mon 16, 2012 9:57 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 8652 Location: Chesapeake VA
Blustar1 wrote: Bill: You could use a hand wound toroid for L3 like I did, but it's hardly worth the effort and expense. Most builders of these Tx don't want to hassle with winding coils... Tom
| Top |
bill hamre
Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic) Posted: Apr Tue 17, 2012 3:29 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2540 Location: aston, pa, usa
-------------------------------------------------------------------------------------- I'll just make it an option
_________________ "All glory is fleeting" - George Patton
KB3QNN 73
| Top |
Blustar1
Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic) Posted: Apr Tue 17, 2012 11:55 pm |
Bill: For L3 (470uH), I used a FT-82-61 Ferrite Toroid which I purchased from Amidon. This required exactly 70.875" of #27 magnet wire wound 82 turns and allowing for 1.125" lead lengths.
| Attachments: |
| Top |
rocketeer
Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic) Posted: Apr Wed 18, 2012 3:10 am |
| Member |
Joined: Mar Tue 30, 2010 2:24 am Posts: 5144 Location: Lehighton, PA.
As I sit here listening to Nick Carter, Master Detective, on my Stromberg-Carlson 535M it occurs to me I have never thanked 35Z5 and all the folks who helped me through my construction process building this great little xmitter. Sooo, THANK YOU!!
_________________ kb3wbb
My radio files free download page: http://www.enter.net/~rocketeer/radio/radio2.html
| Top |
Peter Bertini
Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic) Posted: Apr Wed 18, 2012 4:56 am |
| Moderator |
Joined: Jan Thu 01, 1970 1:00 am Posts: 12215 Location: Somers, CT
bill hamre wrote: Bluestar,
Give me the spec that worked and I'll start supplying toroid as L3. Core #, wire size, number of turns.
Bill Suggestion, it might be cheaper to use a molded 470uH choke for L3. A lot of modern equipment uses them for resonant LC circuits. They have pretty decent Q. Pete
_________________ A long journey always begins with the words, "I think I know a shortcut."
| Top |
bill hamre
Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic) Posted: Apr Wed 18, 2012 7:09 pm |
Blustar1: thanks for the toroid specs
Pete: I'll stock what you suggest for L3, have you a source and parts #?
KB3QNN 73
| Top |
Peter Bertini
Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic) Posted: Apr Wed 18, 2012 11:34 pm |
| Moderator |
Bill, I'd feel better if someone tried one first before you invest funds in a bunch of them. You get molded 470uH chokes on eBay, free shipping for cheap prices. http://www.ebay.com/itm/10-x-1-2W-470uH ... 0530156745 For 99 cents for ten, shipped, it is worth a shot. Pete
| Top |
rocketeer
Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic) Posted: May Tue 01, 2012 4:22 pm |
| Member |
Halfway there on #2. I need one 7 pin tube socket and a 12CS6 tube yet. I'm hoping to find what I need at Kutztown in a couple of weeks. Attachment:
Here's a quick rough mockup of the front panel. That will be an ammeter in the upper left. Attachment:
| Top |
Tube Radio
Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic) Posted: May Tue 01, 2012 4:59 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 7881 Location: Warner Robins, GA
Very nice work there. What piece of test equipment was originally in that case? That is similar to what I did with my 6GY6 two tube broadcaster. I used an old automotive tester for my chassis.  I plan to add at least one meter to measure 6GY6 cathode current.
| Top |
rocketeer
Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic) Posted: May Tue 01, 2012 7:50 pm |
| Member |
| Top |
Tube Radio
Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic) Posted: May Tue 01, 2012 8:00 pm |
| Member |
| Top |
Blustar1
Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic) Posted: May Sun 13, 2012 4:59 pm |
Impressive, and very creative! What a neat job!
| Top |
rocketeer
Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic) Posted: May Sun 13, 2012 10:06 pm |
| Member |
| Top |
rocketeer
Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic) Posted: May Fri 25, 2012 3:07 pm |
| Member |
Finished, up and running. Ignore the ammeter, it's a bad unit that's in there basically for looks. Attachment:
| Top |
rxradio
Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic) Posted: May Fri 25, 2012 4:13 pm |
| Member |
Joined: Jun Tue 10, 2008 6:06 pm Posts: 272 Location: Edmond, OK
DYN O MITE. Drool! It looks totally commercially made.
Dale
| Top |
Blustar1
Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic) Posted: May Fri 25, 2012 4:58 pm |
Sacre bleu! It looks totally awesome! Nice job!
| Top |
35Z5
Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic) Posted: May Fri 25, 2012 7:26 pm |
| Member |
Agreed, that's nice construction...
Since the meter is bad, sick a toothpick in the movement jamming it at around 2A, that'll have em talking...
| Top |
rocketeer
Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic) Posted: May Fri 25, 2012 9:37 pm |
| Member |
35Z5 wrote: Agreed, that's nice construction...
Tom  , yep, that'll work. Reminds me of back when computers were running at 100Mhz (486). I installed a digital display on the front of mine and hard-wired it to display 400Mhz. It drove people nuts trying to figure out what proc I was running. Larry
| Top |
Flipperhome
Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic) Posted: May Sat 26, 2012 12:24 am |
| Member |
Joined: Nov Sat 26, 2011 4:09 am Posts: 947 Location: Texas. USA
rocketeer wrote:  , yep, that'll work. Reminds me of back when computers were running at 100Mhz (486). I installed a digital display on the front of mine and hard-wired it to display 400Mhz. It drove people nuts trying to figure out what proc I was running. Larry I did something similar with my 300 MHz Celeron machine overclocked to 475 Mhz, except it was also a BP6 DUAL PROCESSOR (gasp, wow) so the 'speed' display was jumpered for a 'technically valid' 950, which raised a few eyebrows because there were no 950 MHz processors at the time. I've still got that machine in service.
| Top |
Tube Radio
Post subject: Re: 12AV6-12CS6 Transmitter(Revised Schematic) Posted: May Sat 26, 2012 6:01 am |
| Member |
Flipperhome wrote: rocketeer wrote:  , yep, that'll work. Reminds me of back when computers were running at 100Mhz (486). I installed a digital display on the front of mine and hard-wired it to display 400Mhz. It drove people nuts trying to figure out what proc I was running. Larry I did something similar with my 300 MHz Celeron machine overclocked to 475 Mhz, except it was also a BP6 DUAL PROCESSOR (gasp, wow) so the 'speed' display was jumpered for a 'technically valid' 950, which raised a few eyebrows because there were no 950 MHz processors at the time. I've still got that machine in service. Would be nice if computer cases still had a display for the processor speed.
| Top |
Users browsing this forum: No registered users and 1 guest |
