| Author |
obbm
Post subject: E-caps in Parallel - Voltage in Half? Posted: May Tue 01, 2012 11:02 pm |
Joined: Jan Mon 04, 2010 2:25 am Posts: 812 Location: Finger Lakes of NY
I have been recapping filters in boat anchors and test equipment for two years now. Sometimes I have had advice to parallel them to get a certain value. Today I was recapping an Eico 950B cap tester and needed a 4 uf e-cap. So I used two 10 uf in series, which read 5 uf. That's probably OK. But in the course of reading up on the subject, I think I found that paralleling e-caps halves the voltage.
Is this correct?
If it is correct, where I paralleled caps in the filter of boat anchors (probably at least a couple of times), should I expect capacitor failures as a result of exceeding the voltage? Should I go through and re-re-cap those boat anchors?
Another question: The Eico 950B needs three precision caps, apparently to make the cap bridge more accurate. What passed for "precision" when this tester was built? Would 1% be OK?
Thank youo for your attention and help,
Bill
| Top |
Alan Douglas
Post subject: Re: E-caps in Parallel - Voltage in Half? Posted: May Tue 01, 2012 11:42 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 23527 Location: Pocasset, Cape Cod, MA
Putting them in series doubles the overall voltage rating. Parallelling them doesn't change the voltage.
2% is more than sufficient, and actually 5% would do, provided all of the caps were off by the same amount, since you could shift the dial to compensate.
| Top |
Dale Saukerson
Post subject: Re: E-caps in Parallel - Voltage in Half? Posted: May Tue 01, 2012 11:45 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 6186 Location: Minneapolis, MN USA
The voltage rating of the cap does not change regardless if they are in series or parallel.
In parallel, each cap will see the same voltage. Therefore, the applied voltage must not exceed that of the lowest rated cap. Two in series, each cap will see one half of the total applied voltage.
| Top |
obbm
Post subject: Re: E-caps in Parallel - Voltage in Half? Posted: May Wed 02, 2012 12:50 am |
Thanks for your answers, Alan & Dale. It makes sense now. I don't know where I got that idea and I can't find where I got it, didn't save it.
And thanks, Alan for the tolerance figures. I had no idea, I was going to try to find 1%.
Thanks again,
Bill
| Top |
easyrider8
Post subject: Re: E-caps in Parallel - Voltage in Half? Posted: May Wed 02, 2012 1:00 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 6768 Location: Minnesota
Alan Douglas wrote: 2% is more than sufficient, and actually 5% would do, provided all of the caps were off by the same amount, since you could shift the dial to compensate.
By shifting the dial you will throw your resistance readings off. It is not that difficult to match up some capacitors and resistors. Dave
| Top |
codefox
Post subject: Re: E-caps in Parallel - Voltage in Half? Posted: May Wed 02, 2012 1:59 am |
E caps in parallel, lesser of both . Series, sum of both if they are otherwise equal.
| Top |
Alan Douglas
Post subject: Re: E-caps in Parallel - Voltage in Half? Posted: May Wed 02, 2012 3:03 am |
Quote: By shifting the dial you will throw your resistance readings off. It is not that difficult to match up some capacitors and resistors. That's true, but who would ever use one of these to measure resistance? Anyhow the old resistors have probably drifted too.
| Top |
Sal Brisindi
Post subject: Re: E-caps in Parallel - Voltage in Half? Posted: May Wed 02, 2012 5:18 am |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 3616 Location: Central NJ
When you wire capacitors in series you should put a 330K (more or less) resistor in parallel with each capacitor to equalize the voltage between them.
Sal
_________________ Need capacitors--> http://www.tuberadios.com/capacitors
| Top |
obbm
Post subject: Re: E-caps in Parallel - Voltage in Half? Posted: May Wed 02, 2012 12:56 pm |
Sal, a very good point, I forgot about that and will do it. Thanks much for helping.
Bill
| Top |
easyrider8
Post subject: Re: E-caps in Parallel - Voltage in Half? Posted: May Wed 02, 2012 4:15 pm |
Sal Brisindi wrote: When you wire capacitors in series you should put a 330K (more or less) resistor in parallel with each capacitor to equalize the voltage between them.
Sal Electrolytics self equalize, resistors are not necessary. Dave
| Top |
Alan Douglas
Post subject: Re: E-caps in Parallel - Voltage in Half? Posted: May Wed 02, 2012 6:01 pm |
| Top |
Jack Shirley
Post subject: Re: E-caps in Parallel - Voltage in Half? Posted: May Thu 03, 2012 2:48 am |
| Member |
Joined: Mar Fri 14, 2008 1:40 pm Posts: 8416 Location: SE USA
True - but you know many ARFers and Newbies that will take a cap out of a burnt out CFL and buy another one at Radio Shack of the same value and put them in series. Best to use equalizing resistors unless you know that both are from the same 'batch'.
_________________ The beatings will continue until the morale improves
| Top |
Sal Brisindi
Post subject: Re: E-caps in Parallel - Voltage in Half? Posted: May Thu 03, 2012 5:43 am |
| Member |
| Top |
BigBandsMan
Post subject: Re: E-caps in Parallel - Voltage in Half? Posted: May Thu 03, 2012 12:32 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 6040 Location: Raleigh NC USA
I agree with using balancing resistors with series caps, and I'll tell you why. I've never seen balancing resistors left out of commercial practice, particularly in heavy-duty amplifiers such as some of the larger and later Fender units (Showman and Dual Showman, Super Reverb, and some of the later Bassman series, all of which I owned at one point or another). At a time when manufacturers were shaving out every possible part in the interest of saving every possible penny of production cost, balancing resistors were not abandoned, and I find that noteworthy. On the other hand, I had become aware of the balancing resistor controversy by the mid-1970's, when I began building gear seriously. The ARRL handbooks, for example, stressed balancing resistors; Orr's Radio Handbooks took the opposite point of view. Then I found this: Quote: The condensers used in filters must be capable of continuously withstanding a direct-current voltage that is equal to the crest alternating-current voltage applied to the rectifier. Ordinarily a single condenser should be used to withstand the entire voltage, rather than several condensers in series. When condensers are in series, the direct-current voltage stress divides between them in proportion to their leakage resistances rather than their dielectric strength, and the leakage resistances are variable and uncertain. If filter condensers are to be connected in series, it is advisable to shunt them with high resistances proportioned to divide the voltage in the correct ratios..." This was Frederick Terman, Sc.D, Dean, School of Engineering, Stanford University, and Past President of Institute of Radio Engineers, in his Radio Engineers' Handbook (New York: McGraw-Hill, 1943), First Edition, p.611. With all due respect to those who hold the opposing point of view, that clinched things for me (and still does). I build and repair this way; I have done so since the mid-1970's; and I have yet to experience anything to suggest that I took the wrong tack. Hope this helps.  Larry
_________________ It don't make a go if it ain't got that GLOW!
| Top |
threeneurons
Post subject: Re: E-caps in Parallel - Voltage in Half? Posted: May Thu 03, 2012 5:17 pm |
| Member |
Joined: Jul Sun 17, 2011 1:11 am Posts: 1785 Location: Los Angeles
Cornell Dubilier's take on balancing resistors: Attachment:
They recognize the equalizing effect of leakage changing with voltage, but still recommend the resistors. "Pencil whipping" their formulas for determining the resistor values, indicates to me anyways, that they are the largest the resistors should be. For example, if the formula yields 1M for the value, then using 470K, or 330K resistors would be better.
_________________ If the women don't find you handsome, they should at least find you handy ! - Red Green
| Top |
BigBandsMan
Post subject: Re: E-caps in Parallel - Voltage in Half? Posted: May Thu 03, 2012 5:37 pm |
| Member |
Agreed in full, and many thanks for the info  . I stick with 330K 1-watters for the balancing resistors when I'm working with voltages in the 450-600 range, and elevate the resistance proportionally with voltage above that range. And by the way, I've "whipped" many a pencil on math over the years. They always wear out before I finish the math... Larry
| Top |
Norm Leal
Post subject: Re: E-caps in Parallel - Voltage in Half? Posted: May Thu 03, 2012 7:10 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 28973 Location: Livermore, CA
We will never have agreement on this subject. Agree leakage will increase with voltage and tend to cause equalization.
What happens it one cap has little leakage at 600 volts but is rated 450? Voltage could punch through insulation and cause it to short. This would put all voltage across the remaining cap. Adding resistors doesn't cost much and they act as bleeders, discharging caps when the radio is turned off.
_________________ Norm
| Top |
BigBandsMan
Post subject: Re: E-caps in Parallel - Voltage in Half? Posted: May Thu 03, 2012 8:15 pm |
| Member |
+1.  L
| Top |
Alan Douglas
Post subject: Re: E-caps in Parallel - Voltage in Half? Posted: May Fri 04, 2012 12:54 am |
| Top |
BigBandsMan
Post subject: Re: E-caps in Parallel - Voltage in Half? Posted: May Fri 04, 2012 2:48 am |
| Member |
Alan Douglas wrote: Quote: New York: McGraw-Hill, 1943), In a nutshell. Get with the program. There have been considerable improvements in electrolytic capacitor technology since the 1930s. Read this: http://antiqueradios.com/forums/viewtopic.php?t=153805Alan, I saw the thread at the time it was current, and while I appreciate your qualifications and effort, and mean no offense, I stand by my position. Had I been privy to a test run involving multiple samples in comparison, including pairs with the balancing resistors and without, all tested over a considerable period of time, then I could be persuaded by the results. But a single shot over a few seconds simply doesn't hit the target for me. As for technology, certainly, lytic cap technology has improved since Dr. Terman's day. I haven't overlooked that fact. However, the availability of this technology is, in itself, NO guarantee that it is being employed, or at least properly employed, let alone universally employed. Frankly, I am far more suspicious of lytic caps in general today (and not just lytic caps!) than I was, thirty, twenty, or even ten years ago. In view of the hordes of suspect offshore caps running around in all sorts of drag these days, I'm sure my skepticism on this score is understandable. I have to take my chances with the caps at hand like anyone else, and I prefer to play it as safe as possible. And that includes balancing resistors in series stacks.  Larry
| Top |
Users browsing this forum: No registered users and 2 guests |
