It is currently May Thu 23, 2013 9:36 pm
 Post subject: I boughtCollaro changer on epay but what chart does it use?
PostPosted: May Wed 02, 2012 10:53 am
http://www.ebay.com/itm/170830618948#ht_2811wt_1396
The changer in my maganavox was beat up like the platter plastic was gone on it so I bought one on epay. I need help IDing the cart though. Aren't they usually ev-26?
REOPENED JOIN TODAY http://www.retroelectronics.com
 Post subject: Re: I boughtCollaro changer on epay but what chart does it u
PostPosted: May Wed 02, 2012 2:18 pm
That's not an EV-26 but if you drill out the rivets holding the cartridge mount to the part that screws onto the tone arm you can use about any 1/2 inch mount cartridge out there.
If the facts don't fit the theory, change the facts...Albert Einstein
KAƘSCR
PostPosted: May Wed 02, 2012 2:21 pm
Yes your right I am using a magnetic in my changer like it.... I wanna give the ceramic cart a chance
PostPosted: May Wed 02, 2012 4:40 pm
If the cartridge is bad, gary at VM has a replacement using the original bracket mount.
PostPosted: May Wed 02, 2012 4:54 pm
My loves I worded it wrong I want to know the cart so I can figure out what needle to use for it that way when it comes I can get right to work instead of waiting for the new needle to come when I order it.
PostPosted: May Wed 02, 2012 5:39 pm
if you buy the cartridge from gary it comes with your choice of needle, or you can just buy a needle/stylus for about 7 bucks. either way its easy to look it up yourself on the VM website.
PostPosted: May Thu 03, 2012 3:51 am
I think it is this one.
http://www.thevoiceofmusic.com/catalog/ ... ategories=
Brian McAllister
Sarasota FL
http://oldtech.net
PostPosted: May Thu 03, 2012 4:33 am
Incorrect.
The Magnavox in the ebay ad uses a specific EV cartridge.
Here is the correct stylus and info...
PostPosted: May Thu 03, 2012 11:33 am
You are right Matt. I only looked at the first picture, and not yet having been fitted with glasses after my cataract operations, I mistook the little arm sticking out for an EV 26.
Brian McAllister
Sarasota FL
http://oldtech.net
PostPosted: May Thu 03, 2012 4:04 pm
Ugh!
I can't imagine having my eyes worked on! :shock:
Post New Topic Post Reply  [ 10 posts ]  Moderator: Larry Hillis
Users browsing this forum: dberman51, Eickerman and 0 guests
