It is currently May Sun 19, 2013 11:17 am
Post New Topic Post Reply  [ 30 posts ]  Go to page Previous  1, 2
 Post subject: Re: How do you buy parts?
PostPosted: May Thu 03, 2012 10:51 pm
Nick D. wrote:
Mikeinkcmo wrote:
Fourteen cents apiece is ridiculous!!
Here we go again... :wink:
$100 divided into 7,200 units... that's 0.014 (0.01389) DOLLARS each.... or 1.4 cents.
Somebody needs learn'n in some advanced cipher'n, like gazintas.
100 gazinta 7200, 0.014 times
http://uncyclopedia.wikia.com/wiki/User:Ogopogo/Jethro_Bodine
If the women don't find you handsome, they should at least find you handy ! - Red Green
PostPosted: May Thu 03, 2012 10:58 pm
Naw, 100 gazinta 7200 72 times!!! :lol:
PostPosted: May Thu 03, 2012 11:29 pm
I guess ya went past the 6th grade ... Some kinda jeenyus, or sum-then.
PostPosted: May Fri 04, 2012 4:58 am
I like metal film one percent. Tolerance doesn't matter so much but metal film does not catch on fire. And I like sunspec for resistors. I bought an assortment of 1/2 1, 2, 3 and 5 watt for less than $150. I still need to but the occasional 25W Dale from mouser, but I rarely have to stop and order resistors.
Caps I get electrolytics from Mouser and Sal. Polyesters from mouser, Sal, Mark Oppat and just radios. Safety caps from Mouser and just radios and some cool combo electrolytics from Bob's capacitors.
Mark Oppat is the guy for almost everything else. Tubes, pots, you name it. If he doesn't have it, he can usually find it. Great guy. There are a couple of tube guys on the classified forum, genoo and alton that I had always got good testing well priced tubes from also.
Phono parts from Gary Stork at voiceofmusic.com. He is also a great guy and can figure out what you need when you don't even know.
There is a thread here that has links to all the great resources in the hobbyist community, though they will leave out Mouser and Digikey because they are monster companies not geared to the hobbyist. Maybe someone has a link.
PostPosted: May Fri 04, 2012 5:34 am
Deleted
I smell smoke.....
PostPosted: May Fri 04, 2012 2:13 pm
I hadn't heard of Sal. I would like to check out his E-caps. Does he have a web site?
Bill
PostPosted: May Mon 14, 2012 6:17 pm
mbear2k wrote:
(no affiliation) I've ordered a bunch of these over the past few years:
Deluxe 1/2W, 1W, 2W Resistor Kit, 340 Pieces Total, Values from 10 Ohm to 10M. $7.95
http://www.elexp.com/srp_qtr1.htm
Elexp also sells 10 different colors of hookup wire in 25' spools for only $1.45/spool. They have a minimum $20 order, so snagging all 10 colors doesn't even get you up to the minimum. But throw in an $8 resistor kit, and now we're in business. Thanks for the recommendation!
Rodney
PostPosted: May Mon 14, 2012 6:38 pm
Most early radios used resistors with 20% tolerance spreads.
So, if you end up with a drawer of 9100 ohm, or similar, resistors,
they may be gathering dust for a long time.
Pete
A long journey always begins with the words, "I think I know a shortcut."
PostPosted: May Mon 14, 2012 9:56 pm
Rodney
In fact I bought my hookup wire from them too in a kit - one each, stranded and solid:
http://www.elexp.com/cbl_ld25.htm
Not quite as good a deal, but worked well for me.
PostPosted: May Tue 15, 2012 1:33 pm
For many years, I have been stockpiling parts from hamfests and estate buyouts. Resistors, pots, and other parts get used slowly, but I am always replenishing the capacitor supply. I use Radio Daze, Bob, and Mark as my major suppliers, if I don't already have what I need.
http://www.radiodaze.com/
http://www.radioantiques.com/supplies.html
http://www.oldradioparts.net/
